Question about Tristar SB Steam Buggy Vacuum
Steam escapes Steam Buggy
The steam just started escaping where the top is screwed down. My husband said the seal has deteriorated. Can this part be replaced?
  • 2 more comments
  • clo1957 Sep 07, 2008
    We seem to have a similar problem, The steam is coming out of the lid, therefore there is very little steam coming out from the hose. We are looking for a place to buy a new lid (near Montreal, Quebec, Canada) but we can't seem to find where it is sold. Can anyone help?
  • Anonymous Oct 21, 2008
    rubber seal for cap needed as steam is escaping i cant find one to fit .i miss this super cleaner,im lost without it.please help
  • Anonymous Jan 11, 2009
    The seal cap on my steam buggy (ST) is locked. I cannot turn the lid off with doing damage to my ST. Is there a solution other than pruchasing a new buggy?
  • sand050
    sand050 Apr 18, 2013
    does anyone know how much water to use in the steam buggy? or how much the measuring cup holds?
I've faithfully used by little yellow Steam Buggy to clean tight corners in my replacement windows and was always to get them looking new again and many other small places that needed blown out with steam when wiping or even scrubbing with a toothbrush doesn't work. I started to use it today and the steam started to come out around the black cap. After searching for a solution on the net I was very disappointed to find everyone else was having the same problem with no real solution. I had my hubby look at it and he said the gasket was worn and slip an o-ring on top of the gasket and now it back to working fine.
Just wanted to pass it along. A 10cent O ring will fix it.
Posted on Dec 30, 2008
  • Christina Lammond Oct 24, 2011
    Hi I have just read your comment about steam coming out of the inlet cap. I presume the gasket is the screw part of the cap once you take it off.( sorry to sound a bit dim) One other thing I have been tightening the large screw on top of the black inlet cap, in the instructions there is no mention what this is for. Have you any idea and should I have tightend it down. regards Christina
  • shir3579
    shir3579 Jul 19, 2012
    Thank you so much! The gasket on mine didn't look worn, but steam was coming out of the cap. I bought a rubber O ring for 40 cents, slipped it on top of the gasket and it worked! I really appreciate your post! It was extremely helpful with an easy solution!
This happened to me also and I checked the hose and found it to be hot but the steam seemed to be trapped and exhausted through the seal cap. I then found the hose had hardened. I shut the machine off and waited until it was safe to re-open the seal cap and poured out what water was left over. I discovered there was a significant amount of sediment built up (perhaps inside the hose) that was the likely source of the steam being trapped. I LOVE the quality of this machine when it's working but need access to helpful resources to solve these kind of problems.
Posted on Aug 18, 2008
Shark steam cleaner sc 505
you need a new seal to put on the lid
Mar 17, 2014 | Vacuums
Steam buggy inlet cap will not unscrew it just keeps on turning
I had same problem, but after fiddling with the top for a while, after it had gone cold, some slight movement occurred, and I was able to gently unscrew - I've also greased the thread - I think there seems to be a grub screw which might need tightening. good luck
Nov 04, 2011 | Tristar SB Steam Buggy Vacuum
Hi. my mop is leaking water where the steam should be coming out, although the device is producing steam (which is escaping from the water reservoir)
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the
Shark Manuals that you need.
heatman101
=-=--0
Feb 19, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
The steam is escaping from the handle and is not coming out of the floor pad.
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Nov 10, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop. The steam is escaping from the unit but not going into the mop which is staying or the unit will not steam at all
I had the same issue. It was the water hose that goes out of the top of the heating element to the floor unit. Replace the silicone hose and works great again. No part on Sharks website.
Oct 08, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Steam leaking from screw cap. can i get a new one?
you dont need a new steam cap if steam is coming out of the top, that is supposed to happen when the hose is clogged, it would be very dangerous if that didnt happen, the amount of pressure that thing holds is unreal if you think your cap is leakin steam take a second look. if the cap is not physically damaged then it should be working fine, 9 times out of 10 your hose is clogged
Oct 27, 2009 | Tristar SB Steam Buggy Vacuum
How much water do I add to the steam buggy
I measured it for you, from my cup.
It's 18 Fl ozs or 500 ml (1/2 litre)
Anybody know where I can buy a spare nozzle.
Jul 01, 2009 | Tristar SB Steam Buggy Vacuum
STEAM BUGGY INSTRUCTIONS
its been awhile since I've used the steam buggy and when I went to use it -it put out a little steam and them quit. what can I do.
Feb 24, 2009 | Tristar SB Steam Buggy Vacuum
STEAM BUGGY PARTS
Hi, try to purchase on amazon Chemical Free Whole Home Steam Cleaners. If can't find exact part, you can contact sellers (probably someone can provide parts) Hope this was helpful.
Dec 09, 2008 | Tristar SB Steam Buggy Vacuum
Polti vaporetta - steam escaping from valve
Are you sure it is not escaping from the top? if so replace top.I have had this myself
May 11, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Tristar SB Steam Buggy Vacuum Logo
1,436 people viewed this question
Top Tristar Vacuums Experts
Chris Nomland
Chris Nomland
Charles T Nevin
Charles T Nevin
Are you a Tristar Vacuum Expert? Answer questions, earn points and help others
