Question about Troy MIG100 90-Amp. Wire Feed Welder
Kende 150R gas/nogas mig welder - Troy MIG100 90-Amp. Wire Feed Welder
  • leesilk55 Nov 12, 2010
    hi i have bought a kende weld mig-105f welder from ebay its new but the problem i have is it wont feed the copper welding flux when the trigger is pressed the unit clicks as it wants to feed but nothing happens. Im new to mig welders always had ark welders so i thought id chance my luck. when iopen the top of the welder when the trigger is pressed the wheel stays still i realy dont know what im looking for please can you advise me thanks in advance
    lee silk uk england
Hi I have the same welder with the same problem, I've striped it down and found that there are a few teeth missing on the gears that run the wire feed,
Had no luck finding any replacement parts though
Posted on Dec 19, 2010
What is the tip thread size of kende 150 mig welder . It's not standard euro torch
are you sure it's not a 1/4" 28 national fine? check the tip by threading it in a thread die
Apr 27, 2016 | Welding Tools
I have a kende mig 105 gasless welder,but the wire isn't getting fed through on the feed wheel,tried different welding wire and also turned the wheel,tried tightening the wheel,slackening it as well,i
Here's a few things you can check:
When gun trigger is pulled, do the drive wheels turn? If they aren't, pull the trigger again; do you hear anything within the machine (contactors closing, gas solinouds opening, any clicking, etc.) that would indicate the trigger circuit is functional?
If the drive wheels are turning, but wire isn't being pushed thru the mig gun, check for proper drive roll vs. wire size. If that is correct, check gun liner for obstructions. Flux cored wire tends to stop up a wire liner fairly quickly.
Dec 21, 2014 | Welding Tools
Rossi 220BZ Gas/Gasless Inverter Welder MIG MAG ARC Portable Welding Machine
The Rossi 220bz mig welder comes set up to use gas welding, that is with the Mig electrode connected to the positive terminal, inside the machine.
To use gasless mig wleding, the mig wire must be disconnected from the positive terminal inside the machine and reconnected to the Negative terminal - inside the machine. Open both the side coveres of the welder using a phillips screwdriver. Use a 13mm spanner to undo the hex nut holding the thick copper Mig lead to the terminal named positive, then lead it through the machine to the terminal on the oppisite side of the machine, labelled negative and screw it in place there with a 13mm hex screw. Be carefull not to bump any of the many electric parts inside the machine.
If you run the Mig welder in gasless mode with positive earth and positive elecrode it will blow the household electric fuse.
If you run the Mig welder in gasless mode with negative earth and positive electrode it will work, but the end of the Mig gun tip will get very very hot and start smoking abnormally from excessive heat.
But if you take the side covers off and rewire it (takes about 10 minutes) to negative Mig Electrode, the Mig gun tip remains cool and does not overheat. You will have to cut just one white cable tie, to get an extra inch or so of free Mig cable, so the thick copper Mig lead will reach accross to the terminal on the other side of the machine named negative. Stick the earth lead at the front in the positive terminal.
I did this on my Rossi 220bz mig welder.
http://www.weldequip.com/gasless-mig-wire.htm
Jun 25, 2013 | Welding Tools
Kende weld no arc
make sure your work-piece has a proper ground. and maybe check your gas connection. no leaks. maybe turn gas down.
Mar 27, 2013 | Welding Tools
Kende mig wel103 keeps breaking welding wire?
If it is breaking at the drive roller, chances are your spool of wire is too tight. It has to be able to spin freely as the drive roller pulls, but not too freely or you will end up with quite a mess inside there. Loosen the wingnut that holds the spool of wire and see if that remedies your problem.
If it is breaking somewhere else, let me know and I will try to help you.
Jan 06, 2011 | Welding Tools
What is required to switch from steel to gas on light duty mig welders
if you mean from flux core wire to gas shielded wire you will need a tank and regulators,and feed hose from the welder to the tank
Sep 06, 2009 | Lincoln Electric LE 83180 Century...
Flux wire on Dual Mig Welder not feeding.
Change the contact tip.This is the most common problem. The tip gets burned and keeps the wire from feeding. You should always have extra tips on hand.
Aug 03, 2009 | RTO Flux Wire Welder Dual Mig 131 Ti 1 Gas...
Mig welder powers up but only clicks when trigger is squeezed
1] Remove the power cable from the power. (socket on the wall) remove the top cover there should be a fuse located on the wiring panel.
2] perform all your house keping- like, all plugs and socket are tight, the correct contact tip with the the right wire size, roller/s are also the correct ones for the wire size and are turning if they are turning but not feeding the wire, then, the rollers need to be tightend , get back to us.
Oct 29, 2008 | Clarke Power Products Welding Tools
Troy MIG100 90-Amp. Wire Feed Welder Logo
1,552 people viewed this question
Top Troy Welding Tools Experts
Bill Boyd
Are you a Troy Welding Tool Expert? Answer questions, earn points and help others
