Question about Altec Lansing ACS 295 Computer Speakers
Where does the green cord get hooked into on the cpu
    President:
  • 1,851 Answers
The green jack goes to the green jack on the back off your tower.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Sep 05, 2010
I only got one power cord when i purchased my acer veriton and i have to hook it up to my LG flatron...how do i hook it up so both the computer and the moniter work??
You should have get two cords, if you bought the monitor and the cpu, if you just only bought the cpu then you must buy a new cord .
Here you can buy it. POWER CORD
Aug 29, 2011 | Acer Veriton 5200D PC Desktop
How i could get sound from monitor speakers Do I need to connect cord between cpu and monitor
Hi
Yes you will nned to connect the cord between th monitor and CPU, on the cPU you will need to plug the cord into the light green connector
Regards
Shauqat
Sep 26, 2010 | Nokia 500 XA Monitor
Hook up to the CPU
Two cables are needed, Power and Data signal (VGA). Most monitors take the same type of power cord as computer power supplies. (Some computers will allow you to plug in a slightly modified cable that will power the monitor off the computer's power supply. This cord has similar ends on both sides (with the prongs inside a rubber housing). The only issue with this is it makes the power supply work harder and thus can fail sooner.) Most computer supply shops (online and brick-and-mortar) will have the power cables, if you don't have extra cables hanging around.
I hope this helps.
Mar 20, 2010 | Gateway 7004618 (Black) 17 in. Flat Panel...
I tried to hook up my dvd player and i get picture but no sound. when i put the cords in the back of the monitor there is yellow red blue green holes no white spot. Do i need different cords. I have tried...
That could be a result to that TV either not having the ports you need, or you may need different cords. On my TV. With the 360 they have two cords. Red,white, and yellow and also green blue and i think red but im not 100% sure. You may need to find a different port on your TV for your cords, or do what I do and have your VCR hooked up to your tv, and your DvD player hooked up thorugh your VCR. Hope this helps and don't forget to rate ^^
(and yes that yellow and white are a necessity)
Feb 23, 2010 | Computers & Internet
Need to install a 4-wire/ prong dryer cord strain relief assbly
The green wire attaches to the dryer cabinet. There should be a green screw in the cabinet for attaching the wire. If not, you can always drill a hole for a ground screw.
The loose green wire you see is the reason the code was changed to a 4-wire cord.
May 06, 2009 | Kenmore 62602 Electric Dryer
Kenmore dishwasher power cord.
The green is the ground wire. Attach it to the screw inside the junction box.
Feb 20, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Why does the screen turn green when i hook hdmi cord up
I had the same problem.... Occasionally when I changed stations, the screen went totally green.
What fixed the problem was to NOT use a HDMI cord at all! Instead I got a cord made up of five separate "prong" cords (like we use to hook up the old VCR's with ), all with different color-coded prongs that individually get inserted into the corresponding colored holes in the back of the Cable box and into the TV. I got this special cord from my cable company Comcast.
Dec 14, 2008 | Televison & Video
4 wire power cord connection
The difference between a 3 and 4 wire cord is the 4 wire cord separates the ground and neutral, where the 3 wire grounds through the neutral. The 4 wire cord gives an extra safety against electric shock. The red and black wires on the cord go to the red and black wires on the terminal block. Then you have to determine where the green wire on the dryer goes, if it has one. Some dryers have the green wire spliced into the white wire maybe 6 inches from the terminal block. If this is the case you will hook both the green and white wires on the dryer to the nuetral (middle) terminal with just the white wire on your cord. Some dryers have a ground strap, a flat narrow peice of metal that goes from the neutral of the terminal block to the cabinet just below it. If this is the case then remove the screw securing it to the cabinet and bend it back up onto the nuetral terminal, or remove it completely. Then hook the green ground wire from the cord to the cabinet of the dryer. Make sure all of your connections are tight, but be careful not to strip them. It's also important to hook up the strain relief to prevent any possible tugs on the cord from pulling on the terminal block connections.
Jul 21, 2008 | Hotpoint Dryers
Need help connecting pc to tv.
on some tvs you can use the cord that goes from the cpu to the moniter and use the tv like a monitor but for tvs that cant use that cord u need some special cord that hooks the cpu up to the tv like you would hook up a PS2 or some other video game to a tv. If this doesn't work and u want help from other ppl i sugest u specify what tv and pc ur using and if u mean using the tv like a monitor or having the monitor and the tv hooked up to the cpu
May 11, 2008 | Televison & Video
69 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jerry Umali
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
