Question about De Dietrich Ovens
SOURCE: My oven keeps turning itself off
the oven may be trying to protect itself because of a faulty device that says "I'm too hot". As electric clothes dryers have a thermal high temp limit switch to protect them, look for this device (may be 1 inch round with 2 wires connected) and replace it
Posted on May 24, 2007
SOURCE: Oven Light does not turn off
The problem is due to a faulty door switch, this is part of the door lock mechanism. The reason is that the oven thinks the door is open , this puts on the light and stops some of the oven functions ie the fan the fan element and probably the bottom element.
The answer is to fit a new door lock mechanism.
Posted on Jun 16, 2008
SOURCE: De Dietrich Oven - Clock tripping back to 00:00 means I cant turn on my oven!
its a fix more than a solution but you can bypass the clock thus allowing the oven to operate again
unplug at the mains and remove the oven from the housing remove the two fastening screws from the metal lid on the top of the oven ,and remove the lid
you will see the timer back panel with 3 wires coming to it, 2 are black (switching line) and 1 is red (Live feed to timer )
If you pull the connectors from the 2 black wires from the timer board and connect the ends together using a connector block, the timer switch becomes inactive and allows the oven functions to operate again.
you will have no timer functions but its a cheap fix and who uses the timer any way
good luck Andy B
ps if anyone has a set of operating manuals for ths oven i would be glad of a copy
Posted on Sep 26, 2008
SOURCE: Why does my De Dietrich oven trip the RCD fuse?
You need to replace the oven element, as this is what is causing the prob.
Please rate my solution.
Thanks.
Posted on Nov 06, 2009
SOURCE: De Dietrich electric oven has power but no heat
hi it is probably the timer not making the switch properly even though it looks like its on stopping power going to the thermostat
Posted on Dec 11, 2009
Dec 11, 2016 | De Dietrich Ovens
Feb 25, 2016 | De Dietrich Ovens
Sep 01, 2011 | De Dietrich Ovens
Sep 25, 2017 | De Dietrich Ovens
Dec 11, 2009 | Ovens
Nov 06, 2009 | De Dietrich DOC310 Electric Single Oven
Mar 19, 2009 | De Dietrich UMP404 Powerclean Stainless...
May 13, 2008 | De Dietrich DOC310 Electric Single Oven
Mar 08, 2008 | De Dietrich DOP390 Pyrolytic Electric...
May 24, 2007 | De Dietrich UMP404 Powerclean Stainless...
Nov 02, 2017 | De Dietrich Ovens
Oct 30, 2017 | De Dietrich Ovens
122 people viewed this question
