Question about Kenmore 5.7 cu. ft. Coin Operated Electric Dryer
Kenmore large capacity clothes dryer
Dryer won't come on at all. Checked breaker- not the problem.
  • BusyMom2009 Dec 28, 2008
    I'm having the same problem. The dryer worked perfectly the last time I used it (Christmas Eve) and now won't start at all. I've checked the circuit breaker, unplugged and replugged it and still nothing. The particulars for this unit are: Mod - C1108560290, Ser - ICEA951172, Type - DR-6
    I thought about checking the door switch next but am unsure about where to locate it. Thus far, I have removed the back panel from the unit and am just looking for the next step!
    If anyone can help, I'd really appreciate it!
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    You may have a blown thermal fuse. Please post back with your model number (located around the door opening) and I can check to see how your dryer is configured.
SOURCE: Kenmore Elite Oasis Dryer 6705 not start
I take the timed approach with appliance problems. If they occur 10 years after purchase, I buy a new one. If five years, I call a repair service and measure the cost of repair against the purchase of a replacement. If one year or less after purchase, I pile the expensive, offending, useless lump of an example of the decline of American workmanship into the back of my pickup and push it out on the doorstep of the store where I purchased it.
I find this method to be the most cost-effective and least troubling. And costs me about the same as calling the repair service.
In fact, right now I'm loading up my Kenmore Elite Oasis 6705, purchased March 13, 2007, (note that the problem began one month AFTER the warranty ran out) in the back of my pickup and I will make at quick stop at Sears to push it off the back of my truck (I find if I don't stop, but keep the truck rolling it makes for a much louder and attention grabbing drop off) then find the nearest hardware store so I can purchase some strong nylon line to string across my backyard so I can dry my clothes. I also purchase a bit of extra line so that I have enough to string up any Sears or Kenmore representatives who might stop by to inquire about the appliance they found on their doorstep.
Posted on Apr 12, 2008
Jimster
  • 240 Answers
SOURCE: What is the capaity of 2005 Kenmore Elite Washer and Dryer, models 110?
Starting in early 2002, the capacity sizes were changed around a little bit. A normal sized washer now all have the same sized tubs (pretty much) in the 110 series (Whirlpool Manufactured) washers. The capacity is now rated somewhat by the agitator action the washer comes with. Depending on the type of agitator you have, will determine the capacity. King size capacity means you have a pretty good capacity (size wise) than others. You have normal capacity, large capacity, super capacity, king capacity, and I even think they have canyon (yes canyon) capacity. Capacity sizes dont really mean to much though. In order for you clothes to get clean, the must have room in the tub to move. The must be able to float up, then get pulled down by agitator action. That should determine the size of what goes in the washer. Always use same type clothing when doing laundry (i.e. towels with towels, sheets with sheets, etc, this will keep the load balanced better). Watch what you load, comforters are ok (per manufactures ok) but I do not tlike the idea unless its a front loader, and only by itself. Let me know if this helps you out any.
Posted on Jun 01, 2008
SOURCE: KENMORE ELITE OASIS HE CANYON CAPACITY DRYER
My dryer is doing the same thing... I wonder if this dryer needs to be recalled.... I did call a dryer technician from sears- 1-80-469-4663, ask customer service for a dryer tech, and she told me to unplug my machine for a minute or two and plug it back in and press cancel 2 times, this resets the computer inside, so I did, and guess what, almost immediately it started flashing CF 01,02,03- the lady said that I have a electronic control board problem and she could set up an appointment to have a tech come and figure it out for me, and she could sell me a warrenty for 2100 bucks.... good job sears! You made great appliances and when they break people are out tons of money!!!!
Keep up the good work!
Posted on Jul 08, 2008
SOURCE: kenmore cloths dryer will not heat up
I have a Kelvinator cloths dryer about 15 years old takes to long to dry even smaller loads, gets very hot at back end of dryer it is free of lint
Posted on Apr 13, 2009
  • 1122 Answers
SOURCE: kenmore 64672 dryer gets hot but clothes still wet
you have a clogged wall vent or clogged dryer vent or a clogged lint trap,you are trapping all the hot wet air in the dryer and that's why it's taking so lont to dry-mike
Posted on Apr 23, 2009
This is an update to my previous problem with my electric Kenmore Dryer Model #88042700. The dryer appeared to have no power. I had checked the breakers and thought the one for the dryer was on. But it...
There is a reason it's tripping..First I would have the dryer cleaned out it sound like the unit is full of lint and is holding heat also bad ventilation in dryer exhaused. If it's tripping it's electrical
hydeparkappliancerepair.com
Sep 08, 2013 | Kenmore Dryers
GE gas dryer won't start
you need a new motor
Apr 11, 2012 | Dryers
Sears Large Capacity dryer will tumble, and blow air, but it's cold air and won't dry the clothes.
Hi Jill,
This is probably the heater coil inside the dryer. If you have someone around that is handy with tools, they can get the front of the unit off, and replace it, or if not, you can call a service person in to do it ( it will cost a bit more than having someone that can do it for you ) The part usually isn't that expensive, nor is it difficult to install, but that's my opinion. If you wish more information, don't hesitate to ask
Joe
Sep 06, 2011 | Kenmore Dryers
Dryer will not turn on at all, checked the breakers and looked to see if the plug was loose but still won't turn on.
I think it might be broken. The same thing happened to me, my dryer doesn't work anymore.
Aug 04, 2011 | Dryers
My Admirlal drier will not turn on. Checked breakers and they are good. Checked the door switch and it is good. Could it be the timer?
All admiral dryers ain't the same but if the thermal fuse/limit is gone out the dryer won't run on electric models.
May 09, 2011 | Kitchen Ranges
Washing Machines Logo
353 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
