Question about Maytag Neptune MDE5500AY Electric Dryer
The drum partician, or the tumbler bars are plastic and one of them broke off. I would like to replace it. Can I lift the top of the dryer off to access the screws on the outside of the drum?
  • 10 Answers
I had the same problem but it's the FRONT Panel you need to remove. Before you start, unplug the thing first. BTW I did the whole proceedure in 10 minutes using an electric screwdiver / philips bit and a socket set with an 8mm socket with my leg in a cast. You can do better, I'm confident!
Two 8mm hex head bolts hold each fin on the drum. They can be replaced. You need to open the dryer front since they bolt from the outside of the drum. To open the dryer front you first take the door off by removing the two philips head screws, then slightly lift the door and pull toward you (the door hinges have little hooks on the end that inserts into the slots (this little design keeps the door from falling off during removal and install-nice). Then remove the two philips screws on the other side of the door opening (opposite the door hinges). These screws hold two plastic brackets (be sure to see how they are aligned before you remove them so you know how they go back on.
Now the front frame panel looks like an "H" . Grab the top two arms of the 'H" and give a quick pull. The top arms of the 'H" will come loose. The bottom part is held by a couple of clips, just pull up and the front panel comes off.
You will be able to spin the drum until the hex bolts for the fin(s) in question are visable / reachable from the right side (just above the heater unit-hope you unplugged the dryer earlier). I replaced it using an 8 mm socket.
Now reverse your steps: put the front panel back on the bottom clips and snap the top "H" arms back in place. Reinstall the plastic clips / screws and then put the door back on.
Posted on Sep 09, 2010
  • buysellgb Jan 23, 2011
    DnC Sourcing is to make an Expert of developing products. ---> www.artdnc.com (82) 70-7893-2100)http://www.sourcingbuysell.com
    We have 15 years developing experiences and will implement the advanced products to our customer.
    Electronics, home appliances, sporting goods, medical products, smart phone, General Phones, machine equipment, cattle. Midsize engine
    * Mechanical design, tooling, product design, machine design, reverse engineering (image), product design, MOLD Analysis
    * Processor: AVR series, DSP, FPGA, ARM7, ARM9, etc.
    * Circuit design, PCB ARTWORK Use Program: ORCAD, PADS
    70% Motor Sales ---> www.buysellmotor.net, sourcing everything ->http://www.sourcingbuysell.com
Getting to the drum by taking the back off
you have to take top off first then , usually two screws and slide top forward , then about ten screws on back panel and lift up and that should give you access
Jan 16, 2012 | Maytag Dryers
Hi i went into my dryer and pushed the tumbler the wrong way and heard something pop and now the tumbler doesnt rotate how do i get to the belt this dryer is very old but looks like this one .thank you oh...
You broke the belt. To replace it, pop the top ... use a screw driver. Remove the screws at the top of the front, remove the front, the drum will fall free. Take Pictures.
Feb 14, 2011 | Kenmore 65924 Electric Dryer
How to repair paddle inside drum paddle that fell off
To replace this "paddle" (It's callde a baffle), you'll need to access the outside of the tumbler (drum), by lifting the top.
Begin by removing the door. Remove the two hinge screws. You will then be able to rock the door and hinge out of the slot in the front panel. Next, remove the cover plates just opposite the hinges.
Now you can pull the front panel off the retaining clips and rock it downward, away from the rest of the cabinet. Once it clears the top, you can lift it off the bottom hooks. Just set it aside.
You will now see two screws (hex-head, 5/16 inch), just under the corners of the dryer top. Remove them and rotate the brackets that hook into the top. Removing the brackets will allow you to now swing the top upwards to expose the tumbler.
Just turn the tumbler until you can see the screw holes for the babble holding screws. You may get lucky and find the three baffle screws in the bottom of the cabinet. Re-install, check the others, and re-assemble the dryer in reverse order, and you're done!
Dec 27, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
I have a Maytag MDE4700A electric dryer. It quit working (turning) but still heated up. I took the cabinet apart and found that the belt was broke. Need some assistance on beginner steps for replacing...
Disconnect power to the dryer then open the door and remove the center screw of each hinge secured to the inner flange of the front panel in the door opening. Grasp the door with both hands and lift the door in the hinge area then draw the door assembly away from the dryer to disengage the hinges from the slots in the front shroud.
Remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top cover lip.
Disconnect the wires from the door switch, sensor bar, and the lamp holder then unsnap the lamp holder wire harness from the front shroud wire retaining clip.
Remove the four perimeter screws holding the shroud and tumbler front assembly to the cabinet. Remove the lowest outside screw at each corner then the top screw on each side.
Pull the shroud and tumbler front assembly out and away from the tumbler while slightly lifting the top cover.
Kneel near the front of the dryer and reach your left hand inside the dryer at 8 o'clock position and your right hand under the tumbler as close as possible to the blower then grasp the idler puller with your left hand and pull the idler upward and to the left.
Slip the belt off the motor pulley and the back of the tumbler then pull the tumbler out of the cabinet while lifting the top cover.
Place the belt onto the outside of the tumbler and position it 1 1/2 inches in front of the rear baffle mounting screws with the ribbed side facing the tumbler.
Position the tumbler into the rear felt seal and resting it onto the rear rollers then lower the front of the tumbler onto the blower housing.
Kneel near the front of the dryer and reach your left hand inside the dryer at 8 o'clock position and your right hand under the tumbler as close as possible to the blower then locate the belt and create a small loop with your right hand, ensuring the belt is free of twist.
Position the open end of the loop onto the motor pulley with your right hand. Grasp the idler pulley with your left hand then pull the idler upward and to the left to clear the drive belt.
Relax your left hand and allow the idler pulley to rest down onto the belt. Grasp the baffles with both hands and rotate the tumbler clockwise for the belt to align itself.
Reinstall the shroud and tumbler front assembly in reverse of the removal steps. Lift the front inner edge of the tumbler to allow the front of the tumbler to rest on the teflon bearings on the shroud and tumbler front assembly. Check the felt seal to ensure that it is outside the lip of the tumbler.
Secure the top cover with the hold down brackets then push the front panel posts against the clips in the cabinet until it engage.
Insert the door hinge tabs into the slots in the front shroud and secure the hinges with the screws removed previously to complete the procedure.
Aug 22, 2010 | Dryers
Can I replace the tumbler bars inside my dryer's drum?
Yes,but you will have to find screws that fit the holes in the back of the paddles and a washer to fit the screws
Access the outside of the drum by lifting the top Panel.
if this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 02, 2010 | Kenmore 63942 Dryer
How do I replace a broken belt around the tumbler on my Maytag LDG612? Thank you.
remove front cover and access top cover screws and remove top. lift up drum and string belt around drum,set drum down and string around remaining belt around motor and idler pullys and hand manually rotate to align belts before putting top and front covers back on
Sep 24, 2009 | Dryers
Tumbling bar is loose and getting looser
youll need to lift the top of the unit, and and form there youll gain acees to the outside of the drum assembly, the "tumbler bars" are secured by 5/16 screws from the outside ofthe drum assy
Feb 12, 2009 | Maytag MDG7600AW Gas Dryer
Fins fell off tumbler on Whirlpool Ultimate II dryer
Remove 2 screws under the lint filter cover, then using a spatula or similar, prize apart the top cover from the cabinet, lift top cover and support it.Turn drum by hand until the drum baffles are at the top, and refasten the baffles one at a time.
Then lower cover down and press until it is closed, replace 2 screwa under lint cover.
Job done.
Plz rate this soution.Thanks.
Jan 01, 2009 | Whirlpool Dryers
Repair on Kenmore dryer
lift the top cover, remove the front panel, remove the belt, remove the drum, then replace the rollers.
Jan 22, 2008 | Kenmore 62602 Electric Dryer
Loud Grinding Noise when Tumbler Rotates
Ok, these GE's sometimes have a problem with the front guides bearings going bad, and then the drum starts to eat into the top of the door hole and sides. That is probably what is making your noise. Before you spend a lot of time fixing something that cant be fixed, open the dryer door and look up in each top corner of the opening. Look to be sure the drum hasnt eaten its way through that area. If so, scrap it, because it will eat your clothes badly, and the front panels are to expensive. If not, UNPLUG YOUR MACHINE PLEASE, then standing facing the dryer, open the door, and remove the two screws that are in the top of the door housing area (not the door itself, these would be up by where I told you to look for damage). These screws hold down the top. After removing these screws, lift up on the cabinet top, and pull GENTLY towards you until the top clears the console guide posts in the top rear. After removing the top, inside the cabinet, on either side and at the top, you will see a phillips head screw that holds the front to the cabinet. Remove these screws, and fold the front towards you slowly, removing any wires that may be holding up the swing out (i.e. door switch, light wires, etc., be sure you remember the way the wires reattach). When you look at the top of where the drum rides, you will see a plastic ring with smaller like plastic flat peices that the drum rides in. More than likely, you will have to replace both parts. The ring separates in the center, and is replacable (you should only have to replace the top half). The drum guides are the smaller plastic type guides that just slide in. Reassembly is reverse. Let me know if you need further help. Jim
Nov 22, 2007 | GE DBXR463EBWW Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
55 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
