Question about Emerson Audio Players & Recorders
I have an emerson ht-100 home theater system a dvd player and a rca flat screen, how do i connect the three. and also does the red, blue, yellow -vs- red, yellow, white make a difference
4 Suggested Answers
SOURCE: what would be the best,correct
Hook the tv with rca cables that says audio out and then into the back of the reciever that says audio in. then put the blue-ray player(audio out) into the tv in aux. inputs. Then u r ready 2 go.
Posted on Apr 08, 2009
SOURCE: RCA LCD Flat Panel HDTV and RCA Home Theater System--No sound
Video comes from external device to TV - OUT on device and IN on TV.
Sound connects by the red/white cable set (or HDMI). Place set in Audio OUT ports on TV and Audio IN ports on DVD. Then select AUX IN on DVD.
Posted on Apr 05, 2010
Connecting my new samsung blu-ray player (bd-fm57c) to my toshiba theaterview tv.
I don't think that cord will work. HDMI carries video and audio signals, you might get video but probably no sound. You might as well try anyway though so here goes... The red green and blue plugs are your video and the other red plug and the white plug is for stereo sound. The yellow plug is just a lower quality video plug. So plug in the red blue and green plugs into the component video inputs on the TV then the red and white plugs into the audio inputs. DON'T plug in the yellow plug. If this doesn't work go to your local home theater store and ask for a receiver or switcher that will downscale high def HDMI to component video and stereo audio. You can probably pick up a cheap one for around $100. Good luck!
Mar 29, 2014 | Toshiba 50 Inch Big Screen Flat Tv Theater...
I just bought an L G DP122 DVD player from WalMart--where I purchased my Emerson flat screen TV--and I CANNOT hook up the DVD player to my TV--the DVD will NOT play. My DVD Player has three (3)...
Make sure tv input is set for the slot you plugged the DVD
into.On the tv remote you will find inputs.Just change for the right one.
Most of the time DVD player is working when TV is on channel 2 or 3 .
Mar 02, 2017 | Emerson Televison & Video
I cant get my lg ht303su system to play sound from my television how do i do this?
Connect the RCA cables ( red, white, yellow cables) to the necessary jacks o the DVD player and tv..the DVD player should have an "AUX" input amongst the other inputs eg DVD,USB etc..this allows you to play sound from the TV through the DVD HT
Jan 05, 2013 | LG HT303SU Theater System
Have lenoxx ht 500 surround sound speakers & dvd but dvd is broken, need to purchase another dvd player but can't source lenoxx model, what other models can i connect surround sound to? or whe
If your surround sound receiver unit has rca audio inputs(red/white), you can hook up any brand of DVD player that has rca outputs. You would hook the yellow output from DVD player to yellow input on TV. Hook red/white output from DVD player to red/white input on surround receiver. Hope this helps.
Jan 03, 2012 | Audio Players & Recorders
Can I connect a Sony DVD Player DVP-SR90 to the Panasonic Home Theatre SC-HT75 to achieve surround sound without direct SCART connection - and how?
You can connect your Sony DVD player to your Panasonic HT using an analog RCA audio cable (white and red) for stereo sound. Connect to the AUX inputs on the HT and select AUX. Since the Sony DVD player only has SCART, you would need an adapter, scart to RCA. Like this one:
http://www.maplin.co.uk/scart-to-3-phono-plugs-with-in-out-switch-28102
Check for compatibility. Use the red and black RCA plugs for the audio into the HT.
Your Panasonic HT does not have a digital audio input which would be required for multi-channel surround sound (Dolby Digital 5.1)
Mar 14, 2011 | Panasonic SC-HT75 System
We need to connect a wii and a dvd player up to our 32 in Emerson? Unsure of which jacks to use?
First, you must figure out If your TV has component video inputs. This is a set of five cables (red, blue and green for video and red and white for audio) and will give you the best picture on an hdtv
Then, If your TV does not have the component video cables, you will be using the red white and yellow composite yellows the system came with. A very simple connection.
Last, If your TV does have the component video inputs, you will need to buy a set of the Nintendo Wii Component Video cables from Walmart, Target or any other gaming store. These will enable widescreen view and the best picture quality.
To connect your DVD player, you need to located the composite video inputs and s-video. Composite video is a yellow, female RCA jack, normally found next to two audio jacks, one red, the other white. The three jacks together provide an interface for audiovisual connections. The red RCA jack connects the right channel of a stereo system, while the white RCA jack connects the left. The yellow composite video jack rounds out the set.
When playing the Wii, you will need to be on the correct video input "Component"
When playing the DVD, you will be on "Composite/Svideo."
Dec 29, 2010 | Emerson LC320EM9 32 in. LCD HDTV
I Listen to my xbox or regular tv/sky through my samsung HT-TZ225
your xbox wire is three white red or yellow tv also three option to w r y to put in theas to play
Oct 06, 2009 | Samsung HT-X40 System
HOW DO I CONNECT MY DVD THEATER SYSTEM TO MY FLAT PANEL TV?
just either use rca jacks from the dvd to the tv,,u know ..the red,yellow,and white cables,,,,that will do it,,,using the rca jacks ,,make sure to set the the dvd/reciever settings to anolog
May 17, 2009 | Durabrand Televison & Video
What would be the best,correct sequence to wire these three sony products together. sony home theater system ht-ss2300 and a sony blue ray dvd player and a sony 46" flat screen
Dec 29, 2008 | Sony DAV-DX255 System
109 people viewed this question
Top Emerson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
