Question about AOC Computers & Internet
I dropped my monitor and my controls will not work.lights not on either
  • sgbruce Sep 05, 2010
    The monitor is only 1 day old!!!! It works fine but I cannot use the controls that adjust contrast etc and the power button will not work. The plastic frame came off when it fell and I just put it back on. Would I see anything if I took the frame off?
  • AOC Master
  • 11,800 Answers
If the buttons don't work then take the monitor apart and reset them, most likely they were taken out of position by the shock.
Posted on Sep 05, 2010
    President:
  • 1,566 Answers
Do you know any technical how to in dealing with hardware servicing? Most likely, something got damaged inside the monitor when it was dropped. The unit may need servicing already. And it is advised that if you are not sure with what you are doing, it is best to let a technician personally check on the unit to avoid further damage.
My monitor dont work anymore but when i charge it ..the charge light light up...and when it fully charge it turn green but still dont come on.. no water in or i didnt drop it help me
probably back light is out. Look closely at screen and see if you can see a faint image on screen (hard to see if no light behind to shine though, so look close).
May 21, 2014 | Uniden UDR444 - Monitor Lcd 4.3 Tchsc Bk
Toshiba satellite A505D-S6968 I turn it on and everything lights up but I get a blank screen. Nothing at all the keyboard is lit up and so are the power buttons
Can you see anything on the screen in a bright light? A ghost image? Fan spins? Sounds? Only a black screen? Has there been ANY damage? Drop? Bump? Jar? It could be the Monitor, Inverter, backlighting, lose connection in the rear of the monitor, the switch the controls the lighting of the monitor when you open and close the lid? Hard to be sure without troubleshooting. Here's a video to give you some tips: http://www.youtube.com/watch?v=2Yi6GNFcP3w
May 12, 2013 | Computers & Internet
Black screen
Not much info to work with? Does it boot? fan spin? Can you see a "ghost image" on the monitor in a bright light? Does it show in a External monitor? Any damage? Drop? A few things to check, Backlighting, inverter, on/off switch that controls the monitor when the lid is opened or closed, and the ribbon cable that runs up the back of the monitor. OR the monitor/Graphics is gone. If you boot to Safe Mode any change? Take a look at this video for troubleshooting tips: http://www.youtube.com/watch?v=2Yi6GNFcP3w
Mar 05, 2013 | Acer Aspire Laptop 5740-5780 5740 - Intel...
Screen image works but wont light up
You didn't supply Make, Model of machine or OS, But ,If your machine is booting up and you can see a "ghost Image" on the monitor in a bright light the backlighting is not on. On a laptop there is a tiny switch that controls the light, a on/off switch when you open/close the lid. Sometimes the tiny switch will get stuck, a drop, jar, damage, dust, loose monitor hinge, etc. Or the CCFL/LED is out due to a loose wire or ribbon cable. Without your machine info that's the best I can do.
Nov 21, 2012 | Computers & Internet
Compaq Presario CQ50-110US 15-inch Laptop dropped will boot but no video
Your laptop may have a combination of problems. Since the laptop was dropped, it is possible that your may a motherboard that no longer outputs video through the video controller, or the screen may have been damaged internally. Try hooking up an external monitor through the vga output of your laptop, usually located on the side or back of the laptop. If the external monitor works, then most likely it is your screen that's bad, if the external monitor doesn't works, then most likely it is your motherboard that's bad.
Let me know if this helps.
Feb 12, 2012 | HP Compaq Presario CQ50-110US Laptop
Envision g2219w1 powers up but display is light Grey you can adjust contrast and brightness
click start control panel,display,desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
Sep 15, 2011 | Envision Monitors G2219W1
If I turn on my computer the monitor works well but after a few minutes it turns off itself (it goes to the standby mode orange led lights). Then if I turn on the monitor again it works only a few seconds....
Just in case the monitor is not te problem, why don't you try this.
For (xp)
-Go to desktop
-right click and click properties.
-screen saver
-power
-then set all the drop down list box to never
-click apply.
You can try it on other operating system.
-go to controls
-look for display and follow 2nd step on xp.
Hope this help. Thank you for using Fixya!
Apr 19, 2011 | AOC LM729 17" LCD Monitor
My menu monitor setting is not in English, how do I change the setting back to English? Also the picture on the monitor has shrunk, how do I get it back to full screen?
click start control panel,regional and language options select regional language options from the drop down list select the language you want also from the bottom drop up list you can select your present location location or another language
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
hope this helps
don
Feb 23, 2011 | Emprex LM1704 17" Monitor
Sir, Actually monitor is not working perfectly it showing some lines on the monitor please suggest some trouble shoot steps fort this... Regards Udit
click start control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor
also
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can make settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general
hope this helps
Jan 28, 2011 | Computers & Internet
Computers & Internet Logo
48 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
