Question about Kenmore Dishwashers
All the glasses come out cloudy and the stainless steel knives have rust marks. I don't overload, use proper soap What 's going on?
  • Kenmore Master
  • 43,501 Answers
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Sep 07, 2010
I have faberware stainless steel knife set knives have rust spots. What & why??
How do remove rust spots from stainless steel Yahoo Answers
Yes, stainless will rust. The above link has helpful information on how to treat rust spots on stainless. The web site suggests using a mild acid, such as oxalic acid, which can be purchased at Home Depot or Lowes. Use a green scrub pad, as recommended. Hope this helps....
Apr 28, 2014 | Refrigerators
What are the advantages to buying a titanium diving knife?
Titanium contains no carbon therefore it will not rust as near as quickly as stainless steel and they almost certainly are corrosion resistant, titanium is also a lot stronger than stainless steel knives and they require almost zero maintenance.
Jan 17, 2013 | Scuba Diving & Snorkeling
What's the best way to remove rust or corrosion from your knife?
Rust can be removed by using a good stainless steel rust remover that is organic and dos not harm the metal. Rust on stainless steel should never be scrapped off. This may cause scratches on the surface and thus spoil the look of the metal.
Jul 25, 2012 | Camping, Backpacking & Hiking
Can stainless steel rust?
Unfortunately yes, any stainless steel product can get rusty under some circumstances although a stainless steel is much more resistant to corrosion and rust. I suggest you to get stainless steel if you don't want to replace your silverware and kitchen product every couple of months.
I amgetting rust marks on my cutlery and my glasses are cloudy
It could be low water fill but more than likely a failing watersoftner try some Lemmeshine at walmart. to remove cloudy issues and don't add more soap trying to make up for the cloudiness on glassware it will only make things worse.
Apr 01, 2011 | Hotpoint Dishwashers
White coating on glasses, silverware and door of dishwasher that is very difficult to remove (even with a stainless steel scrubber) Is there a product I should be running through the cycle (without...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1/4 of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Jan 22, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
New soap and rinse dispenser was replaced on August 12,2010,now glasses are coming out with hazy film on them. Rinsing agent does not seem to be coming out of dispenser
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is toadd some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
Dec 12, 2010 | KitchenAid 24 in. KUDP02CRBS Stainless...
Our glasses are coming out with a cloudy film all over. How do we remove and prevent? Dishwasher has plenty of rinse aid.
remember all the dishwasher needs is 1. dishwashing soap. 2.the hottest water going to the machine. 3.the jet dry must be filled completely,some model you can turn up the jet dry is needed. hope this helps.
Mar 12, 2010 | Bosch Evolution 800 SHE58C05UC Stainless...
Cutlery is cloudy and dirty, some food is dried onto knives and forks. Cups and glasses are cloudy and not clean on inside. Coffee or tea stains are not removed. Plates and soup bowls seem OK , and water...
they must have changed the way they treat the water in your area. those spots are caused by hard water. www.dishwasherfilter.com has a product out for this problem. it filters the water going into your dishwasher leaving them spot free and crystal clear with every load. you will love the way your dishes look.
Mar 21, 2009 | Bosch Evolution 300 SHE43M05UC Stainless...
Cloudy glassware, stained flatware
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Jan 19, 2009 | Maytag 24 in. DWB1000 Built-in Dishwasher
Dishwashers Logo
43 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
