Question about Cisco 7941G-GE IP Phone
7941G-GE Locking Up
I have a 7941G-GE phone that freezes/locks up. I have to manually unplug the ethernet cable from the back of the phone to reset the phone. Sending a reset from Call Manager does not work.
Thanks!
  • 48 Answers
This can be caused by corrupted firmware, or possibly damaged circuitry. IdacomUSA is your best bet. Your phone will be completely refurbished, and sent back to you within two weeks and comes with a 2 Year Warranty on the phone.
Posted on May 13, 2009
I need to modify the settings of my cisco ip phone 7941
Complete these steps:
  1. Unplug the power cable from the phone, and then plug in the cable again.
  2. Immediately press and hold # and while the Headset, Mute, and Speaker buttons begin to flash in sequence, release #. ...
  3. Press 123456789*0# within 60 seconds after the Headset, Mute, and Speaker buttons begin to flash.
Aug 04, 2015 | Cisco 7941G-GE IP Phone
How power need Cisco 7941G-GE IP Phone
These phones can take their power from a Power over Ethernet switch, where all you need to do is plug the phone in to the switch and it gets its power from there.
You can also get power cubes for these phones, but they do not come with the phone as standard, as most people like the convenience of having the power coming from the switch, and not needing to use up a further power socket in the floor/wall.
Hope that this helps!
Nov 06, 2010 | Cisco 7941G-GE IP Phone
Phone does not boot , what can be the cause of this ?? I have tried to use different cables on the phones but none seem to work, I have also tried to reset the phone back to its factory state but nothing...
If you are sure your network is setup properly; and the voice vlan is properly setup; it's probably a bad phone. You could try cisco TAC for support. I would double check that the MAC address of this particular phone is correct with the bootup provider.
Jul 07, 2010 | Cisco 7941G-GE IP Phone
When I plug the 7941 cisco phone up to our network on a POE switch, it responds with the message "Ethernet Disconnected", but when we plug another Cisco 7941 phone to the same line it works perfectly... We...
I would check your duplex settings. Often, if you hard code the duplex settings or have a mis-match; one end may not talk properly. Also, have you tested the wiring? Do you know the ethernet is okay for sure? TechRx, Inc. - techrxgb.com
May 12, 2010 | Cisco 7941G-GE IP Phone
Dell latitude e6500 disconnects ethernet after 20-25 minutes. tried changing power save settings, sleep, and hibernate settings. nothing works
Control Panel>Add/Remove Programs>Dell Control Point System Manager
select change> next> click modify> Internal Network Card Power under Power Manager> “This feature will not be available”
Nov 28, 2009 | Cisco 7941G-GE IP Phone
Can I hook a 1131ag LWAP directly to a 7941g?
If the 7941g is the cisco cp-7941g ip phone then no you can not since the ip phone only has ethernet connections and the airap1131agak has only wireless connections on it as it is a wireless access point, so you will need a wireless router or something similar to get the wireless to ethernet cable.
Oct 29, 2009 | Cisco Aironet 1131AG (AIRAP1131AGAK)...
CP 7941G issue
Try configuring CCM IP address either trough DHCP parameter, or Network configuration on the phone.
Oct 08, 2008 | Cisco 7941G-GE IP Phone
Inline power problem: cisco ip phone 7941G
You need to ensure that each port that has a phone plugged into it is configured with power over ethernet configured switched on.
Mar 20, 2008 | Cisco 7940 IP Phone
Ethernet Disconnected message in POE 7941G IP Phones
the first problem will be to check or replace the cable that you use to connect the phone or check the jack that you use
Jul 12, 2007 | Cisco 7941G-GE IP Phone
Cisco 7941G-GE IP Phone Logo
299 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
