Question about RCA P52926 52" Rear Projection Television
Rca P52960 with the ptk chasis
Tv wont turn on. as soon as I plug the tv in a humming noise comes from the tv. I recently fixed a solder connection on the flyback because it would turn on when ever it liked but this problem is different. Do you have an ideas what is happening now.
Thanks
  • littlebong May 12, 2008
    It wont come on at all. I just went and took the back off it is more like a clicking sound then a humming sound
    does the clicking mean a shorted flyback? could my solder connection have heated up and caused a short?
  • RCA Master
  • 8,617 Answers
It sounds like the flyback is actually defective. The set wont power up at all correct?
Posted on May 12, 2008
  • Sonny Berry
    Sonny Berry May 12, 2008
    Usually in that chassis it will either exhibit a humming , clicking or a chirping sound when the flyback is defective. Just depends on what is actually wrong with the flyback.
My rca p52960 tv will not turn on at all. What can
I would disconect the front control panel you can do it by opening the back of the unit on top of the light box there is a couple plugs just unplug the one going to the front panel then try to turn it on with the remote
Jan 25, 2010 | RCA P52960 52" Rear Projection Television
Replacement STK numbers for convergence amps
This unit does not use the STK series convergence amps.The convergence power supply is what you need.I will provide that number for you after while.
Jan 19, 2009 | RCA P52960 52" Rear Projection Television
RCA P52960 Problem (bowed picture)
Normally this is either bad connections on the convergence ICs or defective ICs. If you can solder, you should be able to fix this. First locate the convergence ICs: large black ICs attached to a heat sink that shouldbe marked STKxxx. Try resoldering the pins on these ICs first. If that fails, replace the ICs.
Keep me posted.
Dan
Nov 20, 2008 | RCA P52960 52" Rear Projection Television
Tv wont turn on p52960
Still sounds like the flyback. Rca has had issues throught the years with flybacks failing especially that model.
May 12, 2008 | RCA P52926 52" Rear Projection Television
Rca p52960 wont turn on
Humming or singing can be Shorted horiz out transistor
and bad fly back transformer........need service # off back of
set for part #'s.........T.
May 12, 2008 | RCA P52960 52" Rear Projection Television
RCA P56926 Would not turn off
This tv make a lot loose connections. If you re solder and nothing change, check fly back area's is OK?... Look around convergence board for liquid coolant ( some times CTR liquid coolant projection splitter , becarfull, Liquid is danger!!) Wash yous hands and clean chassis with acetone.
Apr 19, 2008 | RCA P52926 52" Rear Projection Television
P52960
Yes your chassis is PTK195. The other site that I worl for as a support tech has the service manual for 10.99 I moved it to there front page so you can find it. they will email it right out after purchase and will assign a support tech to provide free support to help you diagnose and locate parts. Its a pretty good service we even have parts for projection units.
http://servicemanuals.vstore.ca/
Mar 16, 2008 | RCA P52960 52" Rear Projection Television
Television set wont turn on .
labor and parts are around 200.00 us dollars.
Dec 23, 2007 | RCA P52960 52" Rear Projection Television
RCA 52 inch projection Model P52960
solder connections around the flyback most likely. That is a common fault with the PTK and CTC chassis. Hope this helps.
Dec 13, 2007 | RCA P52960 52" Rear Projection Television
Rca p52927 chassis ptk 195 wont power up all of a sudden
ctc chassis with the 195 chassis were famous for flyback transformer shorting and taking out the horizontal output transistor also.
Oct 24, 2007 | RCA P52937 52" Rear Projection Television
RCA P52926 52" Rear Projection Television Logo
70 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
