Question about RCA P56830BL 56" Rear Projection Television
Tv wont power up t.v. will not turn on. I have checked the wall recepticle circuit and it is fine. the t.v. was working fine, I left it for a 1/2 hour and returned to find it off. Do I take a chainsaw to it or is it fixable. I shure do like having it around. thanks.
I now have the exact same problem, but occered after a power electrical storm. I took the back panel off and found the Main Chassis Board to be a little crispy and smells like the majic smoke was let out. Does anyone know where I can buy a new board?
Posted on Aug 06, 2008
Wont turn on at all
If there is no power at all to the machine check the plug-in recepticle. Plug a lamp in it's place to verify it's working. If not check the house circuit breaker. If it's tripped reset it.
Unfortunately i'll have to know more about the machine to tell you more than that.
Jan 26, 2013 | Kenmore Washing Machines
Wall thermostat shows NO POWER, But there is power at recepticle
Try powering the whole system down for 20mins to allow for a reset of the computerised sections to occur
Mar 22, 2008 | GE AZ38H12DAB Thru-Wall/Window Air...
My Cuisinart CCM-16PC suddenly decided not to burr/grind coffee. It doesn't turn on. Electrical recepticle is hot and the device is plugged in. I've cleaned all of the connections/buttons/grooves so...
Same thing happened to me about 1 year ago. I took the machine apart and determined the issue to be in the circuit board. I bypassed the board and wired the power cord directly to the motor. The machine began to work and is still operating fine. The only drawback, of course - having bypassed the circuit board and switch, you now are on full manual operation. Plug the power cord into the wall outlet and the motor spins; when you are finished grinding you have to remove the cord from the power source to stop the motor. I am OK with this - beats 35 - 50 dollars for a new grinder. Dave
Feb 28, 2011 | Cuisinart CCM-16PC Supreme Grind Automatic...
No power to wii
Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on the verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
Apr 11, 2009 | Nintendo Wii Console
Sony Wega 40" TV will not turn on, standby light blinks 6 times repeatedly
Hello,For model KV-40XBR800,
Pls check following area.
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high
turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
And NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks.
Good Luck
Dals123
Oct 05, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Television wont turn on.
try to check first if theres an output voltage in the wall outlet. if there is, you have a completely inoperative (dead) set. this symptom is usually caused by a breakdown in the power supply circuit. in most modern receivers (transistorized and/or IC), it may also be caused by a breakdown in the horizontal deflection circuits (horizontal oscillator, pre-drive or drive circuits). this is because the supply voltages for the tuner, video intermidiate frequency (VIF), video amplifier, sound intermidiate frequency (SIF) and vertical output circuit are usually supplied by the horizontal output circuit. but again, if you are not inclined in this kind of job, better bring it to a qualified tv technician. good luck!
Feb 04, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
TV won't turn on
If the TV wont go on with the manual button on the front panel, then you have an issue with the tv set. Try a differant wall recepticle. Or unplugging it overnight. If it wont go on with the button on the front of the set after this is tryed, then its time to go to the repair shop, as the set has a power supply problem or a problem in the HI voltage/sweep circuit. Good Luck
Jun 17, 2006 | Sony FD Trinitron WEGA KV-27FS320 27" TV
TV auto shut off-power indicator light blinking-won't turn back on
You could have gotten an electrical surge that put your set into a shutdown condition and unplugging the set and letting the Microprocessor reset will fix this problem if it dosent blow out the main power regulator as you still or might I say have a regulator IC problem. IF THIS PROBLEM HAPPENS AGAIN MORE THEN A FEW TIMES WITHIN A SMALL TIME FRAME I WOULD HAVE THE SET LOOKED AT BEFORE THE REGULAOR BLOWS SOMETHING OUT!!!!
Jan 11, 2006 | Toshiba 43H70 43" Rear Projection...
Televison & Video Logo
76 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
