Question about Dryers
Whirlpool dryer the dryer makes a loud noise when you turn it on and it wont start the dryer, but there is power to it.
  • 4 more comments
  • jizd May 12, 2008
    it is a 2003 whirlpool dryer the model number couldn't be located. the problem that I am haveing when i'm done turning the timer knob I push the start button and it makes a loud buzz almost like the drum is stuck could this be a broken dryer belt if so does the process of changeing the belt take a very long time and is it hard to do if you have never done it before.
  • jizd May 13, 2008
    the model number on the dryer is unreadable but I checked the belt and it wasnt broken what else do you think it could be?
  • kak141 Jun 02, 2008
    mine is the same way but i have the model # it is ler562okq1
  • Laura06 Apr 24, 2009
    The dryer is making a buzzing noise when you press the start button.But the dryer wont come on. we checked the belt and that wasnt the problem. the light comes on inside the dryer. can anyone guide us to what the problem might be??? it's driving me crazy!!
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    The model number should be on a nameplate located around the door opening somewhere. I need this in order to look for any wiring diagrams, so I can determine what is causing the noise you're talking about.
  • Jeff Rockwell
    If the dryer turns on, but the drum does not spin and all you hear is a loud noise, it sounds like your drum belt has broken and is wrapped around the drive motor. Could you please post back and confirm these symptoms for me? Plus, your brand and model number would also be a great help in identifying correct belt (if that's the problem) and how to troubleshoot.
Sounds like stuck brushes in the motor (bad motor)
Posted on Dec 17, 2008
  • caduck2000 Dec 17, 2008
    try manually pushing the drum slam the door quick and hit start if it takes off it indeed is a bad motor
Problem with tumble dryer that has started making loud noise.
Dryers are designed to operate in one direction. Some models turn clockwise and some turn counter-clockwise. Do not run it backwards. The direction of air flow will be impeded or reversed.
Mar 07, 2017 | Whirlpool Dryers
How do I diagnose/fix my Whirlpool Duet Electric Dryer which won't turn on.
access electric motor and disconnect from dryer, jump wire the motor with a wire with plug to see if motor is burnt out.
Jan 18, 2016 | Whirlpool Washing Machines
Whirlpool dryer was making loud squeaking noise. Now it is not turning at all. Makes a noise when you turn it on, but stops completely.
Check the drum belt. Check the drum rollers on the back & glides on the front that the drum rides on also check the idler pully. Check the felt the drum rides on in case it came loose and won't let the drum turn. Did it hum when you started it if so could be the motor. Good luck
Apr 06, 2014 | Whirlpool GGW9200L Gas Dryer
My whirlpool electric dryer makes a loud grinding noise
Is there anything caught between the dryer drum and any housing. Can you hear it when the drum is turned by hand.
Jan 26, 2014 | Whirlpool Dryers
GE dryer makes loud huming sound wont start
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 25, 2010 | Dryers
Drum will not turn and there is no heat.
This dryer has a circuit board that controls virtually everything. If it makes a buzzing noise when you press the power button to turn on the control panel, it's probably not going to be an easy fix. When you hire a professional, you avoid buying expensive parts that you might not need, such as a control board. If it makes a loud buzzing noise when you press the start button, it's possible that it could be a motor or belt problem. But again, I'd recommend a service call for this one.
May 25, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool Estate Dryer not working
Sounds like the motor has seized. Try manually turning the drum with your hands. Is it hard to turn? If it is then the motor has seized up. If not, the windings in the motor may have shorted. Hopefully this answers your questions
Apr 08, 2009 | Whirlpool Dryers
Whirlpool GEW9200 dryer makes loud whining noise...
It might be metal on metal. It is possible that something worked it's way from inside the drum it between the drum and the rest of the dryer. There's just a couple of srcews that holds the back and top on to the dryer. Take them out after un-plugging the dryer, and consider plugging it back in and running it to see if you can here where the squeek is coming from.
Feb 16, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Dryer
Today my whirlpool dryer started making a loud noise. it is drying the clothes but the noise is loud.
Jul 06, 2008 | Kenmore Dryers
Dryers Logo
273 people viewed this question
Top Dryers Experts
