Question about Toshiba Satellite M55-S135 Notebook
Trying to hook up my toshiba satellite m55 thru my vga cable to my lcd tv. when the computer turns on it starts to work and you can see it on the tv, but then it says there is no signal. the backlight on my computer stopped working i believe bc i can still see the icons, so try to use it thru my tv. on the the vga cable package it told me the i have to change video resolution to 800x600. where would i go to make change that? or is there something else i need to be doing altogether?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 100 Answers
On the blank area of the desktop, right click and select properties, In the display properties, select Settings tab, move the screen resolution pointer to the left end till you get the 800 X 600 resolution, Press Apply and then OK button.
Posted on Sep 05, 2010
Cable
I tried to connect my PC with LCD TV using an HDMI cable.
PC did not detect my TV; however everything works fine with VGA cable. VGA cable is the perfect choice.
Jul 08, 2013 | Toshiba Satellite L305D-S5974 Laptop
Will my sanyo hdtv hook up to my toshiba satellite c655
If your TV has a VGA computer input connector, the you can connect a VGA cable from the TV to the video port on the Toshiba laptop.
Jan 27, 2013 | Toshiba Satellite C655-S5068 Notebook
Connect pc to tv
You will need a cable that connects the tv to the pc. If you pc has a vga connection and your tv has a vga connection, then you would purchase a vga cable and connect it. If the computer and the tv have 2 different types of connections you will need some type of adapter between the two of them.
Once you get them connected with a cable you just turn the tv on and Select Input (Select either PC, Computer, HDMI) of where the tv should receive the signal.
On the pc if you just reboot it most times the image will appear on the tv. if not you can Press and Hold your FN function key at the lower left portion of the keyboard then hit the correct F1 thru F12 key that toggles the display. The correct F1 thru F12 key will have LCD/CRT on it or it will have the icon of a display.
Apr 28, 2012 | Computers & Internet
How can i hook my toshiba satellite pro to my tv
there are some options here.. however they are limited to what ports are available on your computer AND on your tv.. for instance..
1 s-video, this is a round like ps/2 port thatt he computer and your tv have to have for video.
2 you can use a vga port from the laptop onto the tv for video
3 you can get a switch box that will be VGA from the laptop to VGA on the switch box that will use AV cables to the tv like a dvd player, and you'll just hook your computers headphone jack intot he jack on the converter box for sound through the tv.
4 buy a brand new smart tv.
Aug 05, 2011 | Toshiba Satellite Pro L300 Notebook
I can`t use an external monitor connected by VGA port for my Toshiba Satellite M55 S331. I need to know if the port is damaged?
The M55 series does not output to external VGA automatically. You can either go into Setup (press F2 when computer is starting) or use FN F5 in Windows to toggle between LCD, monitor, or simultaneous output.
The monitor port should be standard, so as long as the plug on your monitor doesn't have any bent pins, it should work.
Jul 26, 2011 | Toshiba Satellite M55-S331 Notebook
My toshiba M55 Satellite will not boot up. My
Take the hard drive out and see if anything comes up on the screen. If so, replace the hard drive.
Does the screen get any brighter when you turn on the laptop? If not, the lcd cable, or power inverter may have gone bad.
Did you have any blue screen of death errors, or any other kind of errors before the screen problem? If so, you may have bad memory. Do you hear any beeps?
Jan 14, 2010 | Toshiba Satellite M55-S3314 Laptop
What cables do I need to connect my toshiba satellite m55 laptop to my hi def tv?
This really depends on the connectsionon your hi def TV. The laptop doesn't have an HDMI port (these ports carry sound and video in one cable), but it does have a VGA out port as well as a s-video out.
You can connect an s-video cable from your laptop to your hi-def TV, if the TV has an s-video input port.
You can also purchase a VGA to Component converter if your hi-def TV has component inputs, these are the Red, Green, Blue inputs. Amazon sells these, here is a link: http://www.amazon.com/Premium-VGA-Component-Cable-Black/dp/B000RJLSZU
If you have a DVI input you can purchase a VGA to DVI converter as well. These are very inexpensive and you can find a wide selection on Amazon, here: http://www.amazon.com/s/ref=nb_ss?url=search-alias%3Delectronics&field-keywords=vga+to+dvi
Finally, you can also purchase a VGA to HDMI converter. This would be the most expensive option, but you can use this box to put both sound and video from the laptop onto the HDMI cable. YOu would need both the converter and cable for this to work. Converter is here: http://www.amazon.com/VGA-Audio-HDMI-Converter-Adapter/dp/B0015YWV1G/ref=sr_1_3?ie=UTF8&s=electronics&qid=1263068538&sr=1-3
Cable is here: http://www.amazon.com/HDMI-meter-foot-cable-1080P/dp/B0002L5R78/ref=pd_bxgy_e_img_b
Jan 09, 2010 | Toshiba Satellite M55-S325 Notebook
VGA connection from PC to TV --TV says "no signal"
On the remote control for your television, there should be a source or input button. Pressing the key repeatedly will switch from cable input to standard tv input, to s-video, or ypbr, or game, or various others. Try doing this and see if the image appears, this awlays works for me. If I am telling you something you have already tried, i am sorry!
Jun 01, 2009 | Toshiba Satellite M55-S331 Notebook
Connectiing toshiba satellite 2210 to a tv set
The cord you need will either be VGA to S-Video or VGA to RCA depending on which port is on the tv.Once you have the cord hooked up to both,You will need to switch into presentation mode on the laptop using the FN + F7 keys.
Please take time to rate this fixya
May 14, 2009 | Toshiba Satellite A205-S4617 Notebook
Toshiba laptop won't work with new optoma projector
-toggle the laptop display using the FN keys and F5 I believe. -lower laptop resolution to 800 x 600 -look in laptop display properties for lcd or external display settings, see if it (external crt) has to be enabled on the laptop first.
Aug 26, 2007 | Optoma Projector Multimedia Projector
Toshiba Satellite M55-S135 Notebook Logo
57 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
