Question about Sewing Machines
Sewing Machine Froze Up
I was threading the bobbin and suddenly my machine just slowed and froze up and I can't get it to move. I took it apart to see if I could see anything and tryed to take the bobbin gear out to see if there was thread jammed in the teeth but I couldn't figure out how to access the bottom screw. Please Help!
Any suggestions as to how I might fix this at home instead of taking it somewhere?
  • 3 more comments
  • Joygirl1111 May 12, 2008
    It's a old Brother Pacesetter XL-3001, the motor seems fine it's just the gears won't move, like it's jammed somewhere.
  • Joygirl1111 May 13, 2008
    Do you have any photos or more details about where I need to look closely? And if the camstack is split, is that something I can fix?
  • Anonymous Jun 15, 2008
    I rethread my overlock serge machine and it froze up what to do to get it working again
  • mirow3 Jul 08, 2008
    I have a Pro Line sewing machine and it just froze up on me. I cannot turn the wheel forward or back so the needle of course won't move. It makes a buzzing sound when I put my foot on the pedal. I don't see where to oil it, except under the bobbin and I took the side cover on the left side off and put a little oil on the needle shaft.
  • Anonymous Apr 27, 2009
    the xl3001 brother sewing machine has jammed. The machine can just about be turned by hand and the motor works fine. I think it is the clutch mechanism but I am not sure how thay work or indeed how to get at the clutch.
    Ideas please?
SOURCE: Brother XL-5130 Sewing Machine
Put the thread through one of the holes. Then put the bobbin on the spindle. Pull about 3 or 4 inches out of the hole and hold on to it. Start winding the bobbin. After about ten turns, or when the winding thread is secure, you can stop the machine and cut off this 3 or 4 inch tail. To insure that the thread winds up and down the bobbin and not off the top or bottom, there is probably a metal bobbin tension disk that the thread must pass around before it goes to the bobbin. It is probably on the left of the machine and may or may not be part of a thread guide. The thread must pass around this disk on its way to the bobbin in order to put tension on the thread so it will wind properly. If you can't find the disk, which is a small metal button or screw with some type of somewhat moveable spring cap, you can just get the thread to pass through your thumb and forefinger. Hold your hand 6 or 8 inches to the left of the bobbin and pass the thread between your thumb and forefinger so that it makes the thread go in a direct straight line to the bobbin. Pinch the thread only enough to keep it taught but not tight and let it flow through your finger to the bobbin. The thread should go up and down evenly on the bobbin. If not, move your hand up or down to position it so the thread will wind up and down smoothly. It will not be necessary to move your hand once you find the correct position needed for winding.
Posted on Jul 20, 2007
SOURCE: Kenmore Sewing Machine model # c877.15
I have an old Kenmore and here are the directions from my manual: 1. Draw thread from spool through bobbin winder tension discs. 2. Wind thread around an empty bobbin several times. 3. Place bobbin onto bobbin winder shaft with thread coming from rear of bobbin. Push bobbin winder latch against bobbin until it clicks. 4. Release clutch by turning clutch knob toward you. Start machine.
Posted on Aug 09, 2007
  • 192 Answers
SOURCE: Bottom thread will not catch
Unplug the machine and remove the needle plate so that the bobbin case if fully exposed. Lift out the bobbin case and the cup that it sets in will be visible. Locate the "hook" on this cup. It is a finger with a sharp point at the upper edge of the cup. The hook is what grabs the thread from the needle while sewing.
  • Thread the needle.
  • Turn the handwheel by hand.
  • Watch the hook as it approaches the needle from right to left.
If the hook passes by the needle AFTER the eye of the needle is above it, you timing has slipped and the machine must be taken in for repair.
If the hook catches the thread from the needle, put everything back together and try threading again.
Posted on Nov 14, 2007
  • 12 Answers
SOURCE: Bobbin thread breaks
Things to check for thread breakage (top or bottom)
1. Good thread in the machine - not hand thread, cheap thread, quilting thread.
2. A burr on the hook - a small nick on the hook can grab and tear threads, however this usually causes the top thread to tear, not the bottom
3. Make sure a new needle is in the machine - one made for the material you are sewing
4. The bobbin must be installed to rotate in the correct direction in your bobbin case
5. And I'll say it anyway - tensions - the primary cause of thread breaking - Remember, there are TWO tensions in a sewing machine, top and bottom. Also, the thread you see on the bottom of the stitch is the top thread, and vice-versa.
Posted on Dec 04, 2007
SOURCE: Upper thread wraps around bobbin mechanism, while sewing
Posted on Sep 22, 2008
Brother 1100, was sewing , now it is froze, cant turn the wheel far either way, cleaned, wants to go but is stuck, I cant see any thread in bobbin plate but I think that is where issue is advise
You could check the bobbin winder shaft. If this is engaged the machine appears to have frozen while turned on. Move the bobbin winder shaft left, then right while checking the foot controller and you will soon know if this is the problem.
Nov 08, 2016 | Brother Sewing Machines
Machine eats bobbin thread
computerized so could be anything
tension or sewing action parts needs a service
Apr 28, 2017 | Janome Magnolia 7330 Sewing Machine
White sewing machine froze up
When was the last time you cleaned and oiled? There could be a thread caught in the bobbin area.
Jan 29, 2014 | Sewing Machines
Singer sewing machine will not catch bobbin thread to sew
Check the bobbin tension and timing. Please top and bobbin using to new quality threads.
Dec 29, 2013 | Singer Sewing Machines
Blind hemmer is "frozen" won't move at all. What can I do?
on a normal sewing machine this usually means the threads are all snagged up in a knot in the bobbin case. Snip your threads, wriggle the fabric out, remove all snagged threads and rethread the machine. I don't know if this will work with your blind hemmer.
Apr 25, 2013 | Sewing Machines
My machine was working.fine when during a seam it froze. I took off the the bobbing cover and saw the bobbin case had shifted out of place. I replaced it and got the needle moving freely again and now my...
clean under the needle plate where the feed dogs are for lint
also get a can of air & use it on the bobbin area
change the needle
rethread the machine top thread & bobbin
make sure the bobbin is not warped or damaged
check the top thread tension
Nov 17, 2010 | Brother CS6000i Computerized Sewing...
My crankshaft has froze up
Hi, If you can get the top cover off, spray the whole shaft and moving parts with wd-40, let it sit for a few hours and then try it again. If it still does not move, spray it again and let it sit over night.
It should work. If not, you'll have to take to your local repair shop. But try the WD-40 first.
Apr 21, 2009 | Janome D'cor Excel Pro 5124 Mechanical...
Bernina 740 favorit timing
boscados 740 840 940 742
Jan 12, 2009 | Bernina Activa 130
Sewing Machines Logo
256 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
