Question about Dualit Espresso 889 Espresso & Coffee Maker
No water/coffee comes through? the temprature indicators doesnt light up?
    Problem Solver:
  • 15 Answers
The POWER LIGHT for the 889 is RED and located on the LEFT of the center cowling
The BOILER LIGHT for the 889 is YELLOW and located on the RIGHT of the center cowling
If you turn on the power to the unit (the INNER SWITCH on the RIGHT SIDE) the RED light should turn on, showing that the machine is powered. At that point the YELLOW light should also turn on for about 10 seconds, at which point it will turn OFF with an audible CLICK.
If the RED light does not turn on then you have a very dead machine.
If the RED light does turn on but the YELLOW light does not then you have a half dead machine.
Opening up and repairing the 889 is not for amateurs. High voltage, heat and pressure inside.
If you decide to bin the machine I would appreciate getting the drip tray from you as I have lost mine.
Graham Leach
Posted on Nov 08, 2010
Barista supremo thinks it doesn't have coffee beans
http://www.espressotec.com/media/downloads/57/SA1260_Odea_Giro_plus_manual.pdf The red light comes on, doesn't it? The light indicates that the water tank could be empty or the drip tray is full. Tell the coffee machine that it has enough beans, but to please the machine you will fill the water tank and empty the drip tray. Good luck, kolbrun
Sep 10, 2013 | Saeco Odea Giro Plus Coffee Maker
What is freeze dried coffee?
Freeze dried coffee is liquid coffee that's been dehydrated. Once put in hot water, it can be drank again.
Aug 12, 2012 | Camping, Backpacking & Hiking
Fracino little gem coffe machine manual
visacrem intternational limited
FRACINO COFFEE MACHINES
THE LITTLE GEM
INSTALLATION INSTRUCTIONS
.REMOVE PLASTIC BUNG & FILL TOP TANK WITH COLD WATER TO TOP (N.B WATER SHOULD BE SOFTENED)
.PLUG MACHINE IN & SWITCH ON AT MAINS
.TURN MACHINE ON (ON/OFF SWITCH ON SILER PANEL JUST UNDER FRONT RED PANEL- NEXT TO GROUP)
.RED NEON AND AMBER NEON LIGHTS WILL ILLUMINATE AND THE MACHINE WILL START TO FILL
.OPEN STEAM VALVE (TURN RIGHT HAND BLACK HANDLE ANTI CLOCKWISE)
.WHEN WATER LEVEL REACHES THE YELLOW LINE ON THE SIGHT GLASS THE LIGHT WILL GO OFF AND
THE MACHINE WILL CUT OUT
REFIL THE TANK AND THEN TURN THE ON/OFF SWITCH OFF AND WAIT 5 SECONDS TURN THE ON/OFF
SWITCH BACK ON THE MACHINE WILL CONTINUE TO FILL
.WHEN THE WATER LEVEL REACHES THE TOP RED LINE ON THE SIGHT GLASS THE RED LIGHT WILL
GO OUT THE AMBER LIGHT WILL REMAIN ON UNTIL THE WATER REACHES THE CORRECT LEVEL AND THEN
GO OUT
.THE MACHINE WILL NOW START TO HEAT THE WATER WAIT FOR STEAM TO COME OUT OF THE STEAM TUBE
(BETWEEN 5-10 MINS APPROX) AND CLOSE THE STEAM VALVE (TURN RIGHT HAND BLACK HANDLE CLOKWISE)
.WAIT FOR THE PRESSURE TO COME UP TO 1-2KG/CM3 (PRESSURE GAUGE ON FRONT OF MACHINE BETWEEN
THE TWO BLACK HANDLES)
.THE MACHINE IS NOE READY TO USE
.PUT EMPTY FILTER HOLDER INTO THE GROUP AND FLUSH WITH WATER BY TURNING ON RED SWITCH NEXT
TO PRESSURE GAUGE AND LETTING WATER RUN THROUGH THIS PROCESS WILL TAKE SOME TIME AND USE
APPROXIMATELY HALF PINT OF WATER THE GROUP AND FILTER HOLDER SHOULD BE HOT - CHECK BY
TOUCH IF THEY ARE NOT HOT LET WATER CONTINUE TO FLUSH THROUGH UNTIL THEY ARE AND THEN
TURN RED SWITCH OFF
.MAKE A TEST CUP OF COFFEE THIS FIRST CUP WILL PROBABLY BE COLD BUT AS YOU MAKE MORE CUPS
OF COFFEE THEY WILL GET HOTTER IF POSSIBLE LEAVE THE MACHINE TO STAND FOR APPROX 30 MINS
BEFORE MAKING COFFEE THIS WILL ENABLE IT TO WARM UP AND PRODUCE COFFEE AT THE CORRECT
TEMPRATURE.
HOPE THIS IS WHAT YOU WERE LOOKING FOR ITS WHAT THEY GAVE ME WHEN I GO MINE FROM THEM.
IF NOT HERES A LINK TO THE PARTS MANUAL AND CATALOG
http://www.fracino.com/technical/parts.html
http://www.fracino.com/machines/hand-fill-coffee-machines/little-gem.html
http://www.vendingexpress.co.uk/uploads/pdf/product-fracino-little-gem-automatic_4e7a1df44be5d.pdf
Jan 20, 2012 | Coffee Makers & Espresso Machines
There is no water coming out of the machine at all. No error light come on but when you go to make a coffee with beans or pre ground it goes through the process but just dry coffee comes out. Also no water...
For the steam check the end of the nozzle to make sure it is not blocked.
For the coffee run a coffee using the pre ground method but without coffee grounds, if water comes out then grinder is too fine, if no water remove brew unit and clean top shower screen, you might have to clean tube leaving from shower to discharge.
Aug 29, 2010 | Gaggia Syncrony Compact Coffee...
Temprature control
I suggest turn it to lower temperature, so that water won't drip down. You can get rid of the hardness by keeping those things out of the unit for about half an hour before using, so that it may lose some coldness and become soft.
Jul 05, 2010 | Fisher and Paykel Active Smart® E522BR...
We are having a problem with our bun coffee maker. we have used several different coffee's to rule out that the problem is not the coffee. However it doesnt seem like the problem could be the coffee maker...
What brand of filter ae you using?
Some filters will filter too much and others not enough.
with 1.5 to 2 Oz of coffee in the filter, it should take 4 to 5 minutes to complete a brew of one 64Oz decanter.
Jan 06, 2010 | Bunn VPS Coffee Maker
I have a schaerer opal coffee machine, when I switch the machine on, the water light flashes, and a pump runs continuosly as if it is trying to purge the machine. but nothing comes through. does anyone...
I have a schaerer opal coffee machine, when I switch main power machine on, the descaling indicator, cleaning/rinse indicator and stand-by mode indicator lamp remains lit, and a pump runs continuosly. the machine do not ready mode indicator. Yudi INDONESIA
Apr 05, 2009 | Schaerer Opal Espresso Machine
Cleaning light came on and now, coffee pot will not work
Automatic clean function
The coffee maker is equipped with an automatic clean function. After 60 brewing cycles, the clean indicator/button (22) lights up. This indicates coffee maker should be cleaned by using the automatic clean function and the charcoal filter (17) should be replaced.
NOTE: The coffee maker can continue to be used, when clean indicator/button (22) is on.
• To begin the cleaning cycle, remove the charcoal filter (17) from the water tank (10). Fill the tank with a vinegar and water mixture (1/2 vinegar and 1/2 water) or a descaling product. Press clean (22) button for three seconds. The clean indicator/button (22) flashes and the cleaning process begins.
Cleaning process:
• 24 cycles of 7 seconds brewing and 21 seconds off
• 30 minutes rest
• Brewing the remaining descaling solution
• After cleaning process is complete the clean indicator/button (22) goes off. Fill water tank (10) with clean water and run one brewing cycle to rinse the coffee maker.
• Change the charcoal filter (17) (ill. k). Reinsert the charcoal filter to the coffee maker (ill. l).
NOTE: You can use the cleaning function before reaching 60 cycles (especially if the water hardness is above normal). Press and hold clean indicator/button (22) for 3 seconds.
NOTE: The Cleaning Process takes 60 minutes to complete. You cannot cancel the cleaning process before it is complete. Unplugging the machine only delays the cleaning process.
Jan 26, 2009 | GE 106591 Coffee Maker
Water pump not working
Can you please try firstly making a "Pre ground Coffee" on your coffee machine by selecting the pre ground button and making a coffee without coffee in the bypass.
If that doesnt work, let me know.
If it does, open slide the grinder right up to the coursest setting and see if water comes through.
Once again if that doesnt work let me know.
Oct 31, 2008 | Saeco Magic De Luxe Espresso Machine
Bunn coffee maker not working
My warm indicator light is not working. Only used less than a month.
Nov 15, 2007 | Bunn NHB Coffee Maker
Dualit Espresso 889 Espresso & Coffee Maker Logo
317 people viewed this question
Top Dualit Coffee Makers & Espresso Machines Experts
ray gallant
L Pfaff
L Pfaff
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a Dualit Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
