Question about Garden
Hello.I have an e65dre diesel generator which is about 5yrs old,no more than about 50 hrs running time.Other reviews suggest unit should be started at least once a month which I haven't done.This unit would have to be jumped as battery would not stayed charged even after running.Bought a new battery and still same situation.Yesterday after hurricane was over and power was out I jumped the unit,started right away and after about seven hours the areas that had power to the suddenly shut down however unit continued to run smoothly.I had two neighbours that are both electricians look at it and the unit is longer providing voltage ,also mentioned this is probably the same for the battery no voltage going to it to keep it charged if that sounds right.I to misplace the book for the control panel.Need a little advice please.I did read another review that stated if something is not tickled once a month it looses its charge,however yesterday it started beautifully and ran for 7 hrs no problem.Thanks in advance for any help.correction to my last e-mail.That should have read 7 hrs not 7 yrs.
  • 905 Answers
Eagle is not very forthcoming with publishing documentation on the net, so I am shooting from the hip here from past experience.
Your generator does not need to be "flashed" as it should be a self-exciting unit. If there was power coming out, and it died all of a sudden (was there a sudden surge just before this happened?), one or more of the field diodes may be toasted.
Popoff the end cover of the alternator / generator head itself to get access. Write down part numbers that you find of both the diodes as well as the capacitor. Also make note of wiring.
You will need to identify the field winding. This winding will have the diodes going to it. At the connection to the diodes, disconnect and measure for continuity of the field using a multimeter. You should have some resistance. Then check each end of the field winding in relation to the rotor core. There should be no resistance at all. To have continuity here means that your rotor is grounded, and you have found the problem (have rotor rewound to repair). Find your stator connections, these will be the output of the alternator, and will be connected to circuit breakers and such. Here, there will be 2 connections (for 240vac generator). Measure the 2 connections for continuity, there should be some resistance. Then measure each end to the frame of the alternator. There should be no resistance at all, or it would indicate that the stator is grounded, and is another problem.
As far as immediate problem, I suspect that your rotor and stator windings are fine, but your capacitor voltage regulator has faulted on you. Since these items are already on the edge as far as being appropriate for the application, find diodes / diode block with a higher current rating and working voltage. Regarding the capacitor, keep the same capacitance rating (likely 10-12uF), but increase the working voltage.
Given that the capacitor and diodes spin with the rotor, look for mechanical stress on the connections as well. Repair as necessary, you want the wiring to be as close to the center of the rotor as possible to minimize G-Forces when it is rotated. Secure everything that you can, keeping in mind elevated temperatures.
Posted on Sep 05, 2010
Where. Can I find info on starters and solinoid parts for a E65DRE EAGLE POWER TOOLS GENERATOR can anyone help me
Contact the manufacturer is the only suggestion I can make, we have no parts connections here.
Sep 28, 2016 | Electrical Supplies
WHERE CAN I GET A MANUAL FOR A 1966 30KW WESTINGHOUSE GENERATOR? MODEL #: 653JO54G01
Finding a manual for a 50-year old diesel generator will be difficult. However, if it needs service I would look online for a commercial service provider who has been in business for many years and is experienced in diesel generators. Look online for generator repair companies. While it's still unlikely they'll have a manual for it, most likely they will still be able to provide service for it. A Google search came up with this site: http://www.dieselenginemotor.com/diesel/engine/Detroit%203-53n%20Diesel%20Engine/3008. Good luck
Mar 13, 2016 | Electrical Supplies
Generator is two yrs old only had a couple of outages maybe totaling thirty hrs Generator ran great and also ran every wk for its exerciser cycle. The generator didn't start on this cycle and the system...
Is this a natural gas fueled generator? Sounds like a fuel problem, i would go through the fuel system and find out whats wrong. If its a natural gas/propane unit its most likely a bad regulator or low pressure.
May 04, 2017 | Eaton Electrical Supplies
Generator wont start up unless i spray starter fluid into it
This sounds like a dirty carbureator. Just bad enough that it won't start cold.
Mar 29, 2014 | Electrical Supplies
I have an ETQ TG60H12 6000 wt generator. It has .9 hrs because I only fire it about once a month. I've noticed a wet spot on my shed floor but was never able to determine the origin until I noticed a leak...
remove and let the tank dry out you can then get a product that you pour inside to cure the leak, cant remember the name of the product most bike shops would be able to get hold of it
Oct 23, 2013 | Northstar ETQ DG6LE Portable Generator...
Hello, My tv is about 5yrs old.We heard a loud
You need to replace Y main board & buffer, which will cost you around $600-700. Since the TV is five years it will be better to go with new, and it won't be worth enough to spend $700 for old TV.
Hope this helps.
Shane
Feb 13, 2011 | LG 42PX5D 42 in. Plasma HDTV
I have an 18kw kohler generator. the unit is aprox 10 years old...has about 150 hrs on it. over the weekend, when the power was out, it was running just fine when all of a sudden the ford engine...
change the temp sensor and re test the gen set these have a bord that senses if theirs a issue with the engine and will cut the bower to the get head so theirs no load on some mod's then when the temp reaches a higher point they shut down. re-post is this does not fix the issue i will review the books on the unit.
hope this helps
Aug 09, 2010 | Kohler 18RESL 18 kW Emergency Power...
Hi I have an eagle power generator (E65DRE) and it will not generate power. All the coils and components are alright. Do I have to (excite) the generator after it has been sitting for a while? Has any one...
Yes, that's exactly the issue. You should run it once a month to avoid this. Generators can't sit for a while or they will loose the charge that excites the coils for producing power
Sep 07, 2009 | Eagle 10000 W Portable Generator
Question about Portable Generator
It will not even know it is working! Honestly, it will be a breeze for it!
Dec 22, 2008 | Electrical Supplies
Garden Logo
577 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
