Question about Mackie 1604 Vlz3 16 Channel Mixer
How can I hook up my ipod to the Mackie 1604-VLZ PRO? I'm not sure which control buttons, knobs or slides to use to to make it play. I plugged it into the "tape in (RCA)" jacks. I need help with the control settings. Thank you
  • Mackie Master
  • 5,603 Answers
Easiest is to use a 1/8 inch stereo to 1/4 inch splitter cable (1/4 mono's) and plug into the tape input. Then use the tape level knob.
IF you want to use sliders, then plug the spliter 1/4 inch plugs into two channels and set the PAN controls for these to opposite ends and then you have to adjust two sliders to control the gain.
Posted on Sep 05, 2010
How do i hook up monitors to mackie1604 vlz pro to where you can hear music and mike.
Plug either a powered monitor or amp and then speaker into one of the aux sends. Now adjust the monitor mix using the appropriate aux send pot on each of the channel strips you want to send to the monitor. Think of the aux send pots as faders for the monitor mix the same as the main fader for the ain mix.
Aug 15, 2014 | Mackie 1604 Vlz3 16 Channel Mixer
Where I find power transformer of mackie 1604
You should be able to get this directly from Mackie service. Please see the link below for the contact information. Please note that the exact model number adn serial number will be required to insure that the correct transformer is obtained. There are a few variants of the 1604,
Dan
Link: http://www.mackie.com/support/service/index.html
Jul 19, 2011 | Mackie 1604 VLZ 3 16 channel Analog Mixer
MAckie 1604 VLZ Pro Mixer, running QSC 1850 with jbl's from main outs. I would like to hook up powered subwoofers. What is the correct pathway? kenshireman@msn.com
The best way is to use a two-way crossover between the mixer and the amplifiers. In your case, the low output from teh crossover would go to the powered subs, the highs to the QSC. Use the crossover adjustment to set the frequency crossover point to get the sound quality you require.
Dan
Mackie 1604 ---> Crossover --- Highs ---> QSC --->Speakers
-----> Crossover --- Lows ---> Powered Subs.
Jan 27, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
My mackie 1604 vlz 16channel has a problem, it changes sounds during the use and faders need to be cleaned. why is it changing sounds on me...?
If the faders have become noisy, they may be changing due to poor contact. Try putting a small amount of CRC226 in the center of the slot of each fader and then move fader knob to top and bottom. CRC226 is available in the electrical department of Home Depot in a small can with spout... about $2.70
Jan 16, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
Some of my channels have stopped working 4-5-6-13-14-15-16 mackie 1604 vlz pro
If you havent ground looped the chanels. Most of the time the chanels need to be cleaned.
Dec 01, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Hello. I'm missing the bottm plate of the mackie 1604 vlz pro. I bought it on ebay and the bottom plate that covers the internal parts did not come with it. Is there anything I can do about this? Do they...
Mackie does sell parts. If you cannot afford or get the part, procure some metal and make your own. Mackie is headquartered in Woodinville WA I believe.
(800) 898-3211 Monday-Friday, 8am-4pm Pacific Standard Time
Aug 06, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Hello, Effects and EQ hook up problem
Many of those connections REQUIRE using TRS cables (stereo style) rather than TS cables (mono style). It is possible you have mixed the cables if it worked before.
Any cable plugged into an "insert" should be a TRS (tip-ring-sleeve) cable.
Look up these connections in your 1604 manual.
Feb 18, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Hi, Model: Mackie 1604 VLZ PRO When using the control room monitoring, even if the corresponding "SOURCE" switch of the subgroup/main mix is disengaged, there is still small volume of sound. This is...
You may be getting a small amount of cross-talk. How high are the gain settings and sliders when this occurs? Also, can you describe the overall setup that you are using? I'll check the prints, but you should not be getting any volume unless the gains are maxed.
Dan
Oct 15, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
Mackie 1604 Vlz3 16 Channel Mixer Logo
637 people viewed this question
Top Mackie Music Experts
Michial Gueffroy
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
 Grubhead
Grubhead
Are you a Mackie Music Expert? Answer questions, earn points and help others
