Question about JVC Everio GZ-MG360 HDD Camcorder
Each time you engage the recording mode it shows condensation
  • 37 Answers
That is probly from the dew sensor inside the mechanism housing you can try an air dryer at a medium heat range to not damage the plastic, and blow the hot air in the mechanism compartement until the condensation message shut dow
if not thats its the dew sensor it defective and as to be replaced
hope that will help
regards Allan
Posted on Sep 05, 2010
I can't hear myself while recording. I can only hear what I have recorded AFTER the fact. During recording I cannot hear anything at all. Is there a solution to this problem when using the Samson CO1U?
Depending on what audio production program you are using you will need to have the monitoring function engaged. Comment with what program and I can walk you through it. Good Luck, Cody J.
Dec 19, 2010 | Samson C01U - USB Studio Condenser...
On my Olympus DS-2, although I have erased all my files the recorder shows that that there is little or no room for recording. This is the first time this has happened to me.
The amount of room available on the Olympus DS2 are determined by two things:
1. Avaiable Memory
2. Recording Mode
With that said, if you have formatted (erased) the files on the recorder and there is little recording room left, you will need to change your recording mode. I would recommend changing it to SP mode.
I hope this helps.
Feb 26, 2010 | Olympus DS-2 Digital Voice Recorder
Can't plug optical cable on MDS-JE500
optical will work any way you connect................connect mini out( play mode) to cd-r rec (in) recording or cd player (out) to mini (swithch to record, optical/line in/mic) the optical cable you have should work if all connection are fitted well. i record cd to mini using optical and vice versa all the time. just make sure you are connected correctly to what you wanna do
Mar 01, 2009 | Sony MDS-JE520 Mini Disc Player
Panasonic DVD player shows EXT-L in its display.
You have switched machine onto external link mode
Either press external link on remote or find it under the flap.
Has a small child been playing with the remote?
Jan 30, 2009 | Panasonic DMR-EH57 HDD Recorder Player
Intermintant in recording
Hi,not shure if this is your problem but if you are recording shows from tv & you are in av2 of output you will have no recording even though it shows that the recording has begun,all tv recordings must be in the av1 output mode to record from tv I have learned that few times thinking that all is working but to find out that I was in the av2 output mode which was really not recording the whole time,before I begin any recordings I from now on check that I am in the av1 mode then I know the recording will be working,take care ECK
Nov 11, 2008 | Panasonic DMREZ27 DVD Recorder
Magnovox MWR20V6 will not begin recording when it should.
This is more a work-around than a solution, as the unit is failing to function normally; however, having the identical problem I observed that the unit is failing to power on at 2:00 minutes before beginning recording, a necessary step to record to DVD.
My work-around is the following:
1) Set up the timer, inputting necessary date, time, etc. as normal. With the unit still powered on, start the timed recording mode by pressing timer set, as normal. You will see the red clock icon and the DVD logo iluminate on the VFD.
2) Press the Standby-On power button. This will power the unit on in VCR mode. You should at this time be unable to switch from VCR to DVD mode since the DVD is still in timer mode. LEAVE THE UNIT POWERED ON in this manner. The timer will function and the DVD will record normally.
I have no clue why my unit suddenly forgot how to power up on its own in order to record to DVD. If anyone has an answer for that one please post!
Tom Gee
May 03, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
LG RH177 Recording
once you have set timer record, you must then put machine in standby mode,once in standby mode you will have a little timer display in panel,should then come on when time to record
Aug 13, 2007 | LG RH177 DVD Recorder/HDD Recorder
JVC Everio GZ-MG360 HDD Camcorder Logo
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
