Question about HP Compaq Presario SR1300NX (PP195AA) PC Desktop
Compaq presario dvd writer light blinking, dvd not working
Ever since I did some clean-up inside of my computer my dvd writer has not worked. I assume that I hooked up the drive incorrectly. The light on the writer constantly blinks and while the writer drive opens up, it won't shut and won't read. Any ideas
  • i lovesheree Jul 06, 2008
    I cleaned up my computer a deleted different programs that I don't normally use. But when I try to burn cd's or watch movies my cd,dvd rewrite will not read the cd. It does open and close fine, But does not read the cd when the cd is inserted.
  • 4 Answers
There could b possibly 2 reasons for this 1. you must have not connected the power cable to the writer properly 2. the writer must have received a mild shock due to improper connection of the power cable[ul have to get this repaired]
this is the only reason that explains y ur led light on the rom was constantly blinking.. but i need to know more.. Was ur dvd writer drive present on my computers??
even check the Sata cable or ide cable
but im sure its the connection problem mainly it could b from the Rom itself ur Rom must have lost its voltage resistance
Posted on Sep 25, 2008
  • 48 Answers
Check if power jack working right. Try to change it with other jack. Sometimes the pins inside jack are loose. try to tight them.
Posted on May 12, 2008
The DVD writer does not read any disc. the system complained of drivers?
clean your DVD drive with any dvd cleaner. unistall & install your dvd driver. download the dvd write application/software from the HP website. hope it will work.
Jul 06, 2011 | HP Compaq Presario CQ50-130US Notebook
Compaq presario c700
If there is a little pin hole on the front use an unwound paper-clip. push it into the hole and the mechanism should release? Realy need more detail though.
Apr 01, 2010 | Compaq Presario 700 Series DVD-Rom Drive...
Dvd writer/cd writer combo on a compaq presario has jst stopped working. when i put a dvd or cd into the drive nothing at all happens other than the green light appears on the front of the cd driver. no on...
1st of all insert the correct cd or dvd without scratch and then check it otherwise open you pc case and check your id or sata cable correctly connected or change your id or sata cable
Nov 18, 2009 | Video Game Consoles & Games
No Sound when I play a DVD, but I do have sound when I play a Music CD
Open your sound controls to make sure nothing is muted or set on low volume.
If that's not the case, open your audio drivers program and check to see if nothing is muted.
Oct 22, 2008 | Computers & Internet
Cd/dvdrom light is blinking all the time
Check first under my computer/computer if you can see the DVD/CD Rom drive.  If not detected, follow the steps on this link...
http://support.microsoft.com/kb/929461/en-us
It should work fine after reboot.
Hope this helps
Sep 12, 2008 | Compaq Presario X1000 Notebook
Dvd-rw not working after few seconds
Check for both the xp cd and the dvd writer.It may happen that your dvd writer is not functioning or it may happen that your xp cd has got the scratches. Replace the cd and see whether it is working or not. In the earliest case u have to clean the lense with a soft cloth. Still if u are getting the same problem the it may be required to replace the writer.
Regards.
ucp_pru
Jul 28, 2008 | Computers & Internet
Presario 3700 dvd writer no longer recognizes bland dvd disc
the lazer lens of your DVD rom was not able to read the disc. Clean the optical lens with soft materials. if same errors after cleaning, Be sure that your system is stable can can cause error on DVD rom if either that is not the case. maybe its time replace your DVD rom.
Jan 10, 2008 | Compaq Presario 5000 PC Desktop
USB DVD ROM no detected
You need XP service pack 2 or later installed on your notebook. Does your notebook detect other USB drvices, if not your USB port on the PC is gone. If the USB prt is working and you have XP service pack 2 installed then you probably got a bum DVD drive so return it and get another.
Jul 14, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario SR1300NX (PP195AA) PC Desktop Logo
255 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
