Question about Ranger RCI-6300F-150 Base Scanner
I am looking for a manual for my pro-2023 20 channel direct entery programmuable scanner modal nu; 20128l
    Genius:
  • 1,274 Answers
Hi, my name is John. You can download it here for free www.RadioShack.com .....Rate this solution on the thumbs-up...hope this was very helpful......John
Posted on Sep 05, 2010
Realistic uhf/vhf model 20-400 pro 58 ten channel. Where can I get an owner's manual?
Products associated to Radio Scanners - RadioShack.com
support.radioshack.com/productinfo/ProductResults.asp?...Scanners...
Get Acrobat Reader. Previous Page. Products associated to Radio Scanners. SKU/Catalog #, Model, Description ... 20-139 · Realistic PRO-38 10-Channel Direct Entry Programmable Scanner ... 20-313, Pro-76, Pro-76 200-Channel VHF/AIR/UHFHandheld Scanner ... 20-400 · Realistic PRO-58 Programmable Scanner.
Dec 18, 2015 | Radio Shack Radio Communications
Manual for a radio shack scanner 300 channel aao2000523
This might help.
http://support.radioshack.com/support_electronics/doc66/66173.pdf
Direct link to the .pdf file for the manual to the :
PRO-93
300 Channel Dual Track-Trunking
Handheld Scanner
Believe this is the one you are referring to. AAO2000523 at least points to this one.
Aug 21, 2010 | Televison & Video
What steps do i take too program frequences. what are the frequences for charlotte north carolina?
with the scanner on, push the "man" (manual) button. If the scanner was scanning it should stop on one channel . Push the up or down arrow key until you get to the channel you want to program. You can also use the keyboard for direct access to a particular channel i.e. push "1" "4" "9" and "man" to jump to channel 149.
Once on the channel you want to program, push "prog" (program) then the frequency you want in that channel, including the decimal point. Push "ent"(enter). Your desired frequency should be displayed. Don't forget the "." (decimal point) or the scanner will tell you "error". Move to your next hannel to be programmed and repeat. If you put in a frequency outside of the radio's capability, you wil get an error message.
To find frequencies, look on the internet. The best site I have found is
http://www.radioreference.com/ .
Oct 27, 2009 | Radio Shack Pro-2054 Base Scanner
How do I unlock channels (pro-2055)
the unlock command is done from the manual mode.
If you scanner is in the scan mode, push the "MANUAL"button to stop the scanning feature.
Next you need to go to the channel you want to unlock. If you are only a few channels away, while in the manual mode, push the up or down arrows to step (one push per channel to be stepped though) to the channel to be unlocked.
A direct method is to enter the channel number on the keypad and then push the "manual" button. The display should show the channel you desire.
If the channel lockout is on, the second line on the display will show "LO+". Push the keypad button marked "L/OUT" once. The "LO+" should change on the display from uppercase to a lowercase "lo+". The channel is now unlocked.
Oct 16, 2009 | Radio Shack Pro-2055 Base Scanner
Cant get a answer on how to program my pro-97 scanner
here is a quote from the manual; hope it helps you.
1. Press MAN, enter the bank (0-9) and channel number (00-
99) where you want to store a frequency, then press MAN
again. M and the bank and channel number appear at the
upper left corner of the display (for example: M000).
Press FUNC. Then press e or d. The bank number moves in
the direction of the arrow pressed.
Press FUNC. Then hold down e or d. The bank number
moves continuously in the assigned direction.
Press e. The channel number moves upward one by one.
Or, press d. The channel number moves downward one
by one.
2. Press PGM. M changes to P.
3. Use the number keys and ./DELAY to enter the frequency
(including the decimal point) you want to store.
If you make a mistake, press CL to delete a single digit or press
and hold CL about 2 seconds to delete all digits.
4. Press ENT to store the frequency into the channel.
If you made a mistake in Step 3, Invalid Freq. briefl y
appears and the scanner beeps when you press ENT. Start
again from Step 3.
Your scanner automatically rounds the entered frequency
to the nearest valid frequency. For example, if you enter a
frequency of 151.553, your scanner accepts it as 151.550.
May 27, 2009 | Radio Shack Pro-97 Handheld Scanner
Which is the best sanner the pro96 or the pro106
I own both of these and like the 106 more. It isn't just because it is new, but it has several options that make it more "user friendly" as well as better features. Some of the high points are:
-Easier manual channel navigation
-Larger, easier to read display
-Easier scan list understanding
-Much better user interface (text menus)
-Colored LED that you can assign to different channels..such as your priority channels. This way you can see what your receiving at a glance without having to actually look at the display,
-Remote control capability using the Win500 software.
A Pro-96 is a good scanner, but the Pro-106 blows it out of the water.
Jan 26, 2009 | Radio Shack Pro-96 Scanner
Radio Shack Pro-95 handheld scanner issues
Here is the online programming tutorial:
http://support.radioshack.com/support_tutorials/communications/200-0523/67345.htm
Here is the full manual Should include Quick guide:
http://support.radioshack.com/manuals/ome20-525.pdf
Here is FREE programming software for the PC:
Includes hardware info. You can buy programming cable at Radio Shack to connect to your PC.
http://www.starrsoft.com/freeware/win95/default.asp
Jan 02, 2008 | Radio Shack Pro-95 Handheld Scanner
Channels locked out
Mrs. Santa brought me a new PRO-97 yesterday. I'm new to this - just wanted an aircraft frequency scanner, but got the whole shameal. I had a bad AC adapter and attempted to fix the power problem as directed in the manual by re-initializing the scanner. That blew all memory away.
I received the feared All Channels Locked Out message and through a little research and fiddling, realized the scanner was pre-programmed. An Addendum came with the scanner with instructions to reload the 155 pre-programmed frequencies:
1) Turn off the scanner and then turn it on again.
2) When 'Multi-system Trunking Scanner' appears, press PGM.
3) Press 1.
This will reload the pre-programmed frequencies erased by the re-init. Press scan and it'll be as new as outta the box!
Best wishes,
Farnk
Aug 16, 2007 | Radio Shack Pro-97 Handheld Scanner
Radio Communications Logo
Top Ranger Radio Communications Experts
AnyMHz.com
AnyMHz.com
Jon Piercy
Mike Charette
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
