Product mfc 420cn Problem cannot fax documents phone line ok but get error message poor line condition/ out of memory
  • skchezy May 13, 2008
    I really like the way that you like to profit from other people's problems by posting adds on how they should spend their money for your products.-------------------NOT
    In closing I would like to say thank you for the help that I did not receive,
  • 832 Answers
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_list.html?reg=us&c=us&lang=en&prod=mfc420cn_us&Cat=12
Posted on May 13, 2008
Im trying to send a fax but it saids out of memory and poor line condition
This message show when temporary memory full fill because of too much pending command or execute command which hold printer temporary memory. So you need to clear or delete pending command from its memory then restart your computer. Thanks a lot
Nov 10, 2012 | Brother MFC 420CN All-In-One InkJet...
OUT OF MEMORY
Hello laray7813,
Please visit this link to know exactky what NG means and how to solve it.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000009/faq000209_000.html?reg=us&c=us&lang=en&prod=mfc420cn_us&Cat=12
If this dosent work, let us know and we will find other solutions,
Dahaka
Jul 22, 2008 | Brother MultiFunction Center MFC-440CN...
Can't send fax. Getting transmission verification report stating NG: poor line condition/ out of memory. HELP!!
There are two possible reasons why your printer display the error message.
1. Poor Line Condition
- electrical interference on the line -Make sure electrical or electronic appliances do not interfere with the printer's phone line
- poor line connection - If you have a phone try connecting it directly to line outlet. Listen to the dial tone, if you hear noisy and static, then you will need to call your local telephone company cause there is a problem in your phone line. If dial tone is clear and stable then try checking the telephone line cord that you use to connect your printer from the line outlet, replace if broken.
- alarm system or another device on same line, these interferes with transmission / reception of the fax machine. Try connecting the printer all alone and then try sending a fax.
2. Memory Full
- There is no space to store incoming fax messages. Delete all stored fax messages.
Apr 09, 2011 | Brother MFC 6490CW InkJet Printer
Poor line condition / out of memory when attempting to send fax
That is a problem with your phone line. Get a line filter from Radio shack and install it between your wall socket and the fax. This should solve teh issue.
Jul 08, 2010 | Brother MFC 420CN All-In-One InkJet...
When faxing it states NG: poor line condition/ out of memory
to solve this ... you need to have your phone company "condition" the line. Somewhere between you ant the CO (Central Office) there is/are come crummy (read Corroded) connections.
This may cost you ... inquire before you order the conditioning.
E-mail is more convenient ... consider instead of FAX
Oct 13, 2009 | Brother MFC 420CN All-In-One InkJet...
Using MagicJack for faxing; however, Brother MFC 290C is stating poor line condition - why? Also say's low ink Magenta - would that create this problem?
I had the same problem trying to send out faxes out using my Brother MFC 7340. I use a magic jack phone line. Page 106 of the user manual says if sending via VOIP phone line, you should press menu, then 2, 0, 1 to select "Basic (for VOIP) mode. Then press ok. Then press stop/exit. This cuts the modem speed down to 9600 bps and turns ECM off. Then retry to send the fax. I did that and can now send and receive faxes.
Jun 06, 2009 | Brother MFC 420CN All-In-One InkJet...
MFC-440CN PRINTER fax error
Plug a phone into the line and listen for static. Too many phones on the line, bad lines,etc, can cause a poor line condition. Try the unit directly into the phone line, no answer machine or anything else on the line. Maybe the memory thing is it has a lot of faxes that it hasn't been able to send.
Apr 29, 2009 | Brother MultiFunction Center MFC-440CN...
Error message for fax
not thing to do with your machine call your local phone comp they will take care of you!
Dec 11, 2008 | Brother MFC 420CN All-In-One InkJet...
Printer MFC 420CN
Click HERE to read previous suggestions to this problem.
Jun 01, 2008 | Brother MFC 420CN All-In-One InkJet...
OUT OF MEMORY
Just because you can hear fine when you call the same number and talk to the person there, does not mean a fax machine won't sense noise on the line. A fax machine is much more sensitive, and cannot have a lot of noise or it will not be able to render the image at the other end correctly. So have your phone company and the recipient's phone company check the lines for problems.
There is also the chance that the two fax machines cannot get along. We have clients that we cannot use our fax machine for, because it always generates a similar error to yours. If we go to the other side of our building and use a separate fax machine on a different line, it goes through just fine.
The other half of the error is out of memory. If you have not tried these ideas, try them also: To gain extra memory, you can turn off Fax Storage, print fax messages in memory or cancel a Delayed Fax or Polling Job. In general, shutting the unit off will purge most everything out of memory.
Nov 05, 2007 | Brother MFC 420CN All-In-One InkJet...
450 people viewed this question
jasbo
jasbo
