Question about Home
How do I lift out my popo up waste. It will not stay down. I think somethig may have jamed it.
    Sergeant:
    Novelist:
  • 193 Answers
Grasp the round top part that sticks up and turn it counterclock wise. It will screw off. Inside the part that is left will be a large brass screw. Turn it counterclockwise and it will come out of the drain. Normally what has happened is soap scum and hair have built up and the pop up spring is sticking. Clean the whole assembly in hot soapy water and a sponge or brush. Put it all back together and it should work smoothly
Posted on Sep 05, 2010
94 caravan changed altnator now wont stay running
Hi James, Check the air ducts and vacuum hoses. I think maybe you pulled off something while doing the other work. If all are fine then check the up idle motor and replace it if need be. Regards John
Jun 16, 2012 | 1994 Dodge Caravan
My se27od brother sewing machine is jamed.cleaned it out.Threader bar does not work. Cleaned spool.How can I get it to sew?
since the machine jammed, it need to be serviced to see why it jamed & why the safety device turns on
Mar 10, 2012 | Brother Sewing Machines
MY PRINTER SHOWS 5010 CODE HOW DO I CORRECT THIS PROBLEM PLEASE ?
Error code 5010 indicates carriage lift mechanism error. That means that the carriage did not move up or down properly. You need to replace PR lift shaft assy, Sheet feed unit, Logic board assy, Carriage lift sensor unit. Before replacement of the logic board assy, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or more, also replace the ink absorber kit when replacing the logic board assy.
Feb 21, 2011 | Office Equipment & Supplies
Error code 5010
Error code 5010 indicates carriage lift mechanism error. That means that the carriage did not move up or down properly. You need to replace PR lift shaft ***'y (QL2-0936), Sheet feed unit (QM2-2916), Logic board ***'y (QM2-3078), Carriage lift sensor unit (QM2-3092). In brakets you have the part number for each one of them. Before replacement of the logic board ***'y, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or more, also replace the ink absorber kit (QY5-0146) when replacing the logic board ***'y.
Feb 01, 2011 | Canon Pixma MP500 All-In-One InkJet...
My hl 5150D will not print. when isend document
1/ Check waste toner may need empty. 2/ You maybe out of toner. remove toner and give it a good shake will get a few more prints usually. Need more info from you. Have you check paper paths. Have you rebooted both printer and computer. Remember you must remove power supply on both for ten seconds for true reboot.. Good luck
Oct 10, 2009 | Brother HL 5150D Laser Printer
Cherokee dogs when hot
Sounds heat related...engine temp does increase after shut-down. Leaving the hood open pretty much eliminates stuff hanging on the fenders so I'd look at the coil, cam sensor and tps as potential culprits. also manifold air temp sensor. Don't know about ice...if it leaks, could cause more problems than it's worth. Manifold gasket is possible but I don't think so.
Aug 10, 2009 | 1996 Jeep Cherokee Country
I have changed toner for copier NP-3050. Waste toner didn't remove. Is it necessary to remove the waste toner from the box ?
yes it's necessary to remove waste toner, because n long time the waste toner jamed the clining (I think in the 3050 the waster toner drop by a pipe inside the drum)
Mar 04, 2009 | Canon NP 6050 Copier
GE Profile Washer Agitator will not come off
there is a product called agitamer, a rubber bladder inserted under agitator and hooked to your cold water line, pressure popos it off quite nicely
Feb 22, 2008 | Washing Machines
Home Logo
148 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
