Computer would not recognize the scanner
Suddenly my computer cannot recognize the scanner- i can overview the document but not go farther and scan it. I installed the driver already, and the printer (it is a combined printer-scanner) is working fine. it has been working before and stopped suddenly. strange
  • 41 Answers
Go to control panel, add hardware, search while the printer in connected, as far as im think you computer has disabled it. all you have to do it activate it.
Posted on May 13, 2008
Hp 2515 scanner - creating a multi-page scanned pdf document
How about building a PDF scanner using some manual tools to help with the PDF scanning project? I am testing about the related programmes these days. You can also google it and have a try. Good luck.
Best regrads,
Arron
Tutorial PDF Document in VB NET Overview
Feb 13, 2013 | HP PSC 2510 All-In-One InkJet Printer
How may I scan a document?
Overview: To scan a document you need a scanner and scanner software, this answer will cover
the steps necessary to scan and save a document.
  1. You must already either own or purchace a scanner (eg: this model)
  2. Connect the scanner via the provided USB cord. Consult the manual for this step as necessary.
  3. Use the provided scanner drivers (Consult your scanner manufacturer's website to obtain) and scanner utility to preview the document.
  4. Adjust the settings as necessary and preview your document, if satisfactory enter a name for your scan and save it.
Mar 07, 2011 | Computers & Internet
How do I use my x5495 to scan a resume and then to edit it with my Dell XP computer?
You'll need to scan the document with an OCR software package (Optical character recognition) that will recognize the letters themselves and transmit them to word processing application, such as Word for Windows. Most scanner packages come with some form of OCR utility, so check your installed software. You may already be set up!
Best of luck, William
Mar 03, 2011 | Lexmark Office Equipment & Supplies
Scan button suddenly appears as greyed out
Turn the printer off.Unplug the usb cable.Go to control pannel ans select add and remove.
Remove epson printer software.
restart computer.
download http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=58611&infoType=Overview
Turn computer off.
plug usb cable back to printer and turn printer on,start the computer again,should fix the problem.
Sometimes they just get a file damaged.
Nov 11, 2009 | Epson Perfection 4490 Photo Scanner...
Scanner is recognized but document scanned is a
Try and scan something again, but with the lid up just a little. I am betting that the light for the scanner is not working. Call Canon to find out if your unit is still under Warrany if that is the case. They will be help you fix it, or replace the scanner, depending on the Manufacture's warranty policy.
Aug 02, 2009 | Canon PIXMA MP180 All-In-One InkJet...
I want to scan a document to my computer
have you installed all the scanning software that came with the scanner, Install them and go through these steps to scan a document using Twain;
Overview of the Basic Procedure
This section outlines the basic scanning procedure using a TWAIN-compliant application. For detailed procedure, see the Scanning an Image.
Make sure the CX6600's power cord is plugged in.
Place your materials on the document table.
Start a TWAIN-compliant application.
In the application, open EPSON Scan.
Full Auto Mode:
EPSON Scan automatically previews the images and recognizes the document source and type. images are automatically optimized and scanned.
Home Mode or Professional Mode:
Make settings to optimize images and click Scan.
The scanned images are sent to the application.
Save the scanned images in the application.
Scanning / How to Scan
Scanning an Image
Turning on the CX6600
Placing your materials on the document table
Starting the software and scanning an image
EPSON Scan provides three modes for you to make any scanning settings; Full Auto Mode, Home Mode, and Professional Mode. This section describes how to scan an image in the Full Auto Mode. The Full Auto Mode lets you scan images using automatically-adjusted settings. For more details, see Choosing a Scanning Mode.
Note:
You cannot scan an image with a size that exceeds the available memory or disk space. If you try to scan the image, an alert appears on the screen.
Note for Macintosh users:
Most illustrations shown in this section are for Windows, so they may vary in appearance from what actually appears on your screen. The instructions are the same, except as noted.
Caution:
Before starting the following steps, make sure that all the necessary software including EPSON Scan has been installed. For details about how to install the software, see the Start Here sheet.
Before turning on the CX6600, make sure it is connected to your computer.
Press the On button to turn on the CX6600. All mode lights flash, then the mode button for the mode you used last lights, meaning it has completed its initialization.
You can scan reflective documents (like photos or paper). See Placing Photos and Documents on the Document Table.
You can start EPSON Scan in the following ways.
* Start EPSON Scan directly as a stand alone application
* Start EPSON Scan from a TWAIN-compliant application
This section provides information on how to start EPSON Scan from ArcSoft PhotoImpression. For details on starting EPSON Scan as a stand-alone application, see Starting EPSON Scan.
Note; if you are using Windows 98:
ArcSoft PhotoImpression 5 supports Windows 98 Second Edition or later. For version earlier than Windows 98 Second Edition, use EPSON Scan or other TWAIN compliant applications. See Starting EPSON Scan for details.
Start ArcSoft PhotoImpression.
For Windows users:
Click Start, point to All Programs (for Windows XP users) or Programs (for Windows 98, Me, or 2000 users), and select ArcSoft PhotoImpression 5. Click PhotoImpression 5.
For Macintosh users:
Double-click the Applications folder on your Macintosh HD, then double-click the PhotoImpression folder. Finally, double-click the PhotoImpression 5 icon.
Click the Camera/Scanner button.
Select a file format, location, and file name, then click Epson Stylus CX6600. EPSON Scan starts. See File formats for information on file formats.
Note for Windows XP users:
Do not choose WIA-Epson Stylus CX6600 from the menu to select the CX6600. If you select it, you cannot use the Epson scanner function fully.
EPSON Scan automatically previews the image, and recognizes the document source and type.
If you want to select more settings, click Pause, then click Options to open the Options dialog box. For more details on settings, click the Help button in the Option dialog box.
After EPSON Scan has previewed and recognized the document type, the following window appears. You can see the document type in the window.
EPSON Scan automatically locates the target images, modifies their skew, and starts scanning.
Caution:
Do not open the scanner unit during scanning or copying; otherwise, you may damage the CX6600.
Note:
Be aware that clicking Cancel on this screen closes EPSON Scan.
The scanned image is sent to ArcSoft PhotoImpression.
Note:
* Depending on the image you want to scan, you may not get the expected scanned image. In this case, scan the image in the Home Mode or Professional Mode.
* When you scan in the Full Auto Mode, black and white documents might be recognized as a color document. In this case, scan the image in the Home Mode or Professional Mode.
If you still experience problem scanning, un-install the entire software and re-install them all over. Install all the packages in the CD. Cheers!
May 19, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Corrupted tiff files from scanner on sharp AC-1642CS
Clean the scanner glass if no change , format the computer and install the softwares again but firs you can test with another computer.
Mar 19, 2009 | Sharp AL-1642CS Copier
Scanner will not calibrate.
Make sure your scanner is connected to your computer with a cable or over the network. Scan your calibration target and save it as an uncompressed TIFF file.
Open the Activities overview and start typing Color.
Click on the Color to open the panel and select your scanner.
Jul 01, 2017 | Umax Astra 1600U Flatbed Scanner
Scanning
you need an application software to scan a document first, install one from your manufacturer's CD and follw the direction carefully, or if your computer recognizes
go to start-program-accesories-then scanner and camera, see if your computer recognizes your scanner.
Aug 16, 2008 | HP Officejet 6310 All-In-One InkJet...
169 people viewed this question
jasbo
jasbo
