Question about Philips FaxJet 375 Plain Paper Inkjet
How do I get a fax number?
Just had bt in who put in phone line, how do i get m fax number or is it a case of plugging the phone and fax into the double phone socket and it will work? (i was out of the office when they called so couldnt ask them) I have a new phone number but i know fax numbers are usually different
    Genius:
  • 1,554 Answers
You are correct just use a splitter and if you hear a fax . beep beep then hit answer
or just set your fax to answer on the 6th ring.
or purchase a dedicated phone line for faxes.
who uses faxes any more.
Posted on Jun 04, 2008
Hi ive got this bt phone and have it pluged in to a fax phone machine for the answering machine but I cant get it set up as I record the message but when u ring u cant here it
A fax phone answering machine would usually be supplied either with a standard handset or with a modified one-piece phone.
I have owned a number of fax machines and have yet to find one where there is a facility to plug in another standard phone except at the line plug itself.
The fax line plug usually serves as an adapter which provides a standard telephone socket into which a standard phone can be plugged in. It is wired so when making or answering a call, the phone used takes priority over the other and effectively disables it.
I have found the socket adapter provided by the fax line plug isn't suitable for an answering machine and a separate standard socket must be used.
Mar 03, 2015 | Office Equipment & Supplies
When I try to send a fax on my lexmark x4650 it has error no dial tone?
If you are getting "no dial tone" as an error on your fax machine, it means that you have the telephone cord plugged into the wrong port on it.
Turn the printer around so that you can see the back of it. If you look closely, there should be three ports to choose from in which you connect a telephone cord. Sometimes they put a little white plastic piece in the ports to keep them clean during shipping ect. If this is the case, go ahead and remove them now.
If you look closely at each port , you might notice that they have text or pictures right above or below them to tell you which one to use. let me explain; if you have one telephone line and wish to use it for both fax and voice calls - you will need more than one port. That's why they mark them.
One of the ports should say "line" or have a picture with a funny little symbol on it. This is the port that you would use if you want to fax someone using your printer. You plug your phone cord into this port on your printer.
One of the ports should say "phone" or have a picture of a telephone by it. This port is used when you want to share a single phone line with both your fax machine and telephone used for making voice calls. To split your line between both fax and phone, you plug your phone cord from the wall into the port marked "line" and take a second phone cord and plug it into the port on your printer marked "phone" and the other end of that line goes into your telephone (voice line).
The last port should say "line 2" or similar and usually has no picture next to it. This is an additonal port to share with a second phone line.
To correct your problem of "no dial tone", plug your phone cord into the socket on the wall and put the other end into the port on the printer that says "line". Now lets test the connection.
Put a piece of paper into your printer, press the fax button and dial any phone number using 1 and then the area code followed by the phone number and press 'start" or "ok" to begin the fax. If you have chosen the right port to connect your telephone cord, you will hear a dial tone first, and then dialing of the numbers you chose. If you cannot hear a dial tone before your numbers begin, then you have not chosen the right port. If this is the case, remove the phone cord from the port you have chosen and try another until you do hear the dial tone.
NOTE:
Do not try to go from your phone jack into your telephone and then use a second port on your telephone to connect a second phone cord that is plugged into your printer/fax. A second phone port on your telephone is most likely for a second phone line to use for voice calls. The majority of phones for residential use do not have a built in splitter that works like a fax/printer does. If you try to use a second port on your phone to split to your fax machine, it usually will not work. Follow the instructions as listed above to re-route your line and correct the problem.
MAGIC JACK USERS:
While magic jack is great for making free long distance calls, it is not suggested for use with a fax machine. if your trying to use your magic jack phone line to fax it usually does not work.
Jul 16, 2011 | Lexmark X4270 All-In-One InkJet Printer
Can not receive or send fax. There is the phone tone on the BT line.
When we are speaking about faxes you have to try at least a few numbers, because there is sometimes a temporary problems with tel line speed. To send or receive the fax the tel line should be stable. Fax machine try to connect to highest speed (33,6 by default) and if the line is not stable you will receive connection error.
Try again but tomorrow or ask yout telephone company if there is a problem with line
pifonski
Feb 20, 2011 | Samsung SF-5100 Plain Paper Laser Fax
Fax issues - Brother 1020e
Sounds like your phone cord is plugged into the "tel" or "phone" port on the back of the fax. It should be plugged into the "line" port.
Oct 25, 2009 | Brother FAX-1020e Plain Paper Thermal...
How do i send a fax with my cannon MX310 what are the steps?
Plug a phone line into the LINE port place original face up on the feeder dial the fax number press START (fax)
Jun 16, 2009 | Canon PIXMA MX310 All-In-One Printer
Fax nightmare!!!
If you have a BT line and use the 1571 answering facility , when you have a message waiting the dialling tone changes from a constant tone to a split tone. This is to let you know that you have one or more messages waiting.
In order to get the dialling tone to revert to the constant tone you have to deal with the waiting messages in accordance with the options provided i.e Save, Listen Again or Delete. BT say the Split Tone is to let subscribers know when they have a message waiting. This should resolve the Fax problem.
It certainly worked for my phone/fax system.
Good Luck
Geowilmil
Nov 28, 2007 | Pitney Bowes 9920 Plain Paper Fax
Philips FaxJet 375 Plain Paper Inkjet Logo
35 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
