Question about Nokia BH-214 Bluetooth Stereo Headset
I received new one , when I connect the Charger , charger indicator not lit but when turning on the it blinks in blue and not detected in any mobile NOKIA, BalckBerry , Am i missing something in getting connected
The blue means the blue tooth is on try to pair it with your phone make sure your blue tooth is on on your phone try code 0000
Posted on Sep 16, 2010
When I put the battery on the charger the light on the charger stays on for little awhile the it starts to blink, but when I try to use the battery it is not charged. So I am not sure if I need a new
Hi there! It sounds like you have our Linx stick vacuum or hand vacuum model. Plug only the charger into an outlet, the blue light on the charger should flash once. If the light on the charger flashes once then the charger is fine. Try resetting the battery by following these quick steps below.
1. Remove the battery from charger or cleaner
2. Unplug the charger
3. Insert the battery into the vacuum and turn the unit on for 30 seconds (even if it has no power)
4. Remove the battery
5. Plug the charger into an outlet, make sure the light on charger blinks blue once.
6. Insert battery into charger
The light should be a solid blue, indicating the battery reset worked. If so, allow the battery to charge for 3-4 hours, completely deplete battery on your next use and re-charge. If the light on the charger is still blinking, your battery will need to be replaced. I have included a link where you may go to purchase a replacement battery if needed. Hope this helps!
Search Results
Sep 21, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Why doesn't my battery charge? Why doesn't the charger's light come on?
Hi Suzanne! Follow these steps to check that your charger and battery are working properly.
1. Unplug the charger for at least 30 seconds.
2. Plug the charger back in. The blue light on the charger should flash once.
If the blue light flashes once this is an indication that the charger is still functioning properly. If the blue light does not flash, the charger will need to be replaced. Follow this link to order a replacement charger. LiNX Battery Charger
3. Place the battery in the vacuum and turn it on for 30 seconds. (even if it does not turn on or powers off)
4. Turn the vacuum off.
5. Remove the battery and place it in the charger.
If the light on the charger is solid blue this is an indication that the battery has been reset. Allow 3-4 hours for the battery to fully charge. The blue light will start to blink slowly to indicate the battery is fully charged.
If the light on the charger is flashing blue or there is no light at all this can mean that your battery needs to be replaced. Follow the link to order a replacement battery. LiNX Lithium Ion Battery
Hope this helps!
Jul 28, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
Jazzy 1133 has new batteries. All lights are lit on the battery condition meter. Maximum speed/profile indicator constantly blinks no matter how many sements are lit. After I turn it off and waiting a...
If all lights are flashing excessive voltage has been applied to the controller system. 6 flashing lights on the 1133 indicates that the chair is being inhibited by the battery charger. Try unplugging the battery charger. Check you battery connections.
Mar 30, 2013 | Pride Jazzy 1113 Power Chair
I have an amigo RT, bought is second hand. I bought new batteries but the indicator light on the front control panel drops down rapidly. any suggestions
check the charger, if you plug it in the indicator should blink for aprox. 30 sec. then go solid and when charge is complete the indicator will start to blink again, also if the charger is working the scooter should not move when plugged in, if charger not working check power cord before replacing charger
Sep 17, 2011 | Amigo Health & Beauty
Iam using Energizer 15min charger. I have used for a longer time. Now the charger red light blinks while trying to re-charge batteries. I have tried various batteries but red light blinks. Failed to charge...
A flashing light indicates that the charger seems to detect a problem with the cells. (two or more cells form a battery). Since you've tried other cells, it can be reasonably assumed that the charger is faulty and should be replaced.
Feb 14, 2011 | Energizer 15 Minute Battery Charger Combo...
On the Jazzy select what color for charging indicates fully charged, red, green?
scraig Lights on the joystick all lit up to the far right and the green light lit on the charger. Red indicates charging or blinking red indicates error in charger. Hope this helps
Nov 20, 2010 | Pride Mobility Products Jazzy Select
When I plug it in to charge the red and amber lights stay lit and the green flashes and if i move the joystick everything is backwards push forward goes backwards left is right. b4 when it was plugged in...
sounds like a charger inhibit problem. Whenever you charge your chair the charger inhibit shuts down the chair so it can't be moved while charging. If you are getting this then that function is not working. Lets try this if you know of someone who has a chair or scooter with an off-board charger see if you can borrow it. Plug the off-board charger into the charger port located under the front of the joystick (don't have the on-board charger plugged in) and then turn the charger on. turn the chair's power on and you hopefully will see the lights blinking again indicating a charger plugged in (charger inhibit) the lights on the charger should be red and yellow (yellow turning green when fully charged) If you still get the problem with the off-board charger then your problem is in the controller or power module and this requires a new one. If Medicare paid for your chair you can call Repair Xpress @ 1-877-81-3733 or Roadrunner Mobility @ 1-800-467-2668 to have them fix it for you and bill Medicare for most of the repair costs. Hope this helps you
Oct 31, 2010 | Invacare Pronto M51 Power Wheelchair
How do I turn it on
Hello.
To power on the Gateway VX750, press the power button on the front. The power button has 3 sides with a "G" in the middle.
The LED indicates the power status of the monitor.
  • Not lit - The monitor is turned off or does not have power connected.
  • Blinks one time and then goes off - The LED blinks one time when the monitor's power cord is plugged into an AC outlet to indicate that power is detected.
  • Lit solid blue - The monitor is turned on and active.
  • Blinking blue - The monitor is in power saving mode. Before entering power saving mode, a message briefly appears.
Hope this helps.
Aug 12, 2010 | Gateway VX750 (Black, Platinum) 17" CRT...
Tom tom will not charge using 12 volt charger
I have the same tomtom and it has the same problem. Sorry to say it is the battery. You cant change it it has to go to Tom Tom. I just bought a new one. Hope this helps.
Nov 17, 2008 | Tomtom ONE GPS Receiver
Nokia BH-214 Bluetooth Stereo Headset Logo
124 people viewed this question
Top Nokia Radio Communications Experts
shaun taylor
woodzowl307
Are you a Nokia Radio Communication Expert? Answer questions, earn points and help others
