Question about Samsung HLN437W 43" Rear Projection HDTV
WIll not turn on. Keeps blowing fuse. - Samsung HLN437W 43" Rear Projection HDTV
  • Samsung Master
  • 19,396 Answers
Hi Tanya.
If the TV keeps blowing the fuse, then problem is either power cord or PSU board. The power cord can be tested reading Ohms on the two opposite prongs of the AC connector. If there is continuity between the two prongs, then the cord is shorted.
The power board is more difficult to test, but often, after a short has ocurred you can visually spot a blown components or traces and smell of burnt plastic.
To get a quote on repair call Samsung at the number listed on the owners manual.
Here all parts for this model.
See also :
Support SAMSUNG
Service Request
Service Locations
Search for service policy or warranty
Troubleshooting
Posted on Sep 05, 2010
Signal fuse keeps blowing
Does the fuse blow on both left and right sides,or just blows randomly or as soon as you put the new fuse in?
Does it have tilt steering?I would check the wiring in the steering column to start.
May 18, 2017 | Cars & Trucks
30 amp starter fuse keeps blowing on 98 cherokee
you may have a short (verify the integrity of the insulation of the positive wire from that fuse going to the rear window defroster, check the relay & switch.) try to replace the relay.
Oct 03, 2015 | Cars & Trucks
Fuse keeps blowing
Once a fuse blows & you replace it-- ONE Time--
then you stop
You go to wiring diagrams of the circuit with the
blown fuse & start your testing
Aug 11, 2014 | 1994 GMC Sonoma
Why does my efi fuse keeps popping 1999 chevy prizm
Pull the EFI relay, replace the fuse, and see if it blows when you turn the key on. If it does not turn the key off, reinstall the EFI relay and remove the circuit opening relay/fuel pump relay. Turn the key on. If the fuse blows than we know the problem is One of the O2 sensors, the IAC, the purge solenoid, or the ECM You can unplug the O2 sensors, iac, and purge solenoid. Replace the fuse, turn the key on, and plug them in one at a time until the fuse blows. Replace that component. If the fuse blows with those unplugged than its probaly the wiring and possibly the ECM. let me know what you find and I'll help you more if needed.
Aug 05, 2012 | 1999 Chevrolet Prizm
Mazda 626 ac fuse keeps blowing
Try unplugging the compressor then put in a new fuse. If the fuse does not blow, the problem may be the clutch on the compressor.
Jul 29, 2012 | 1997 Mazda 626
My 2002 Sebring keeps blowing the starter fuse?
Mine is doing the same thing. We are getting ready to replace the starter. Hopefully that is the problem. I'll let you know how it turns out.
Feb 28, 2010 | 2002 Chrysler Sebring
2006 f150 keeps blowing turn signal fuse
It sounds like the fuse is doing what it is supposed to do, and burning out when there is a short circuit. Check the wiring from the fuse block back to the lights and pay special attention to the trailer connection.
Oct 09, 2009 | 2006 Ford F-150
Fuse keeps blowing
In my experience...if it blows the fuse as soon as you turn the key, under the flywheel, there is a stator that recharges the battery when the engine is running, remove the flywheel, in most cases the magnets under it are broken and are in direct contact with the stator. If that is the case, both must be replaced
Jun 17, 2009 | Garden
Chevy silverado keeps blowing fuses
Your 20 amp fuse will not blow if glowplug wire shorts. each plug draws 15 amps which is 120 amps total.I think there are in line fuses for them. Try to wring out where each output from the fuse goes, disconnect all and reconnect one at a time till it blows.That should point to your problem process of illumination! Good Luck!!
Aug 25, 2017 | 1994 Chevrolet K1500
No parking lights, fuse keeps blowing.
There is a ground not connected or a wire open that is causing it to blow
Mar 08, 2009 | 1999 Pontiac Montana
Open Questions:
Samsung HLN437W 43" Rear Projection HDTV Logo
106 people viewed this question
Henry  Thomas
Henry Thomas
