Question about Jabra BT2050 Bluetooth Headset
I got jabra blue tooth ear phone. the numbers I can see are n356 and z302. I am unable to pair with my phones as it is not visible. I held it upto 5 minutes but could never get constant blue light. can you help me?
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 56 Answers
  • 2 more comments
  • isnraj Sep 05, 2010
    where is the solution?
  • anil anil
    anil anil Sep 08, 2010
    Headsets are connected to phones using a procedure called
    ‘pairing’. By following a few simple steps, a phone can be paired
    with a headset in a matter of minutes.
    1. Put the headset in pairing mode
    • When you turn on your Jabra BT2050 for the first time, the
    headset will automatically start up in pairing mode – i.e. it is
    discoverable for your phone. When the headset is in pairing
    mode the LED is constantly lit.
    2. Set your Bluetooth phone to ‘discover’ the Jabra BT2050
    • Follow your phone’s instruction guide. First make sure that
    Bluetooth is activated on your mobile phone. Then set your
    phone to discover the headset. This usually involves going
    to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and
    selecting the option to ‘discover’ or ‘add’ a Bluetooth device.*
    6
    english
    Jabra bt2050
    3. Your phone will find the Jabra BT2050
    • Your phone will find the headset under name “Jabra BT2050”.
    Your phone then asks if you want to pair with the headset.
    Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with
    the passkey or PIN = 0000 (4 zeros). Your phone will confirm
    when pairing is complete.
    JABRA BTx2050
    JABRA BTx2050 JABRA BT2050
    In case of unsuccessful pairing, put the Jabra BT 2050 into pairing
    mode manually. Make sure the headset is off. Press and hold the
    on/off button for approximately 5 seconds until the LED has a
    constant light.The LED will flash before the light is constant –
    keep holding down the button until light is constant
  • anil anil
    exelent
  • Amanda Apr 07, 2011
    thank you! I could not figure out how to put the bluetooth in discovery mode. Thanks so much!
Kulakl?k ?ifremi unuttum
Posted on Jan 23, 2011
It is a PITA but I did get mine to go pair, first it lights up and flashes fast, keep holding then it starts to flash slower, you have to let go when it is blue to get it to stay blue. But it worked mine did pair with 2nd phone after that.
Posted on Oct 03, 2011
How do you pair blue tooth to Jabra VBT185z
it auto pairs .
set mobile phone to bluetooth on
finger click on blue tooth and select discover bluetooth devices
you should see mobile phone detect jabra vbt185z
then pin is 0000 if asked
http://uswww03.gnnetcom.com/jabra/verizon/vbt185z/Datasheet_VBT185z.pdf
Oct 19, 2015 | Jabra Radio Communications
Reset N356 Z302
I NEED TO RESET THE JABRA N356 Z302 HEADSET
Jan 31, 2012 | Cell Phones
I need to pair my bt2050 up to a new phone,it was originally paired wit another phone that i do not use anymore,im using a nokia x3 now and when im trying to find and pair up it says there is no device...
Hi Barbara,
Please follow the below steps, i hope your problem is resolved :-
  1. Make sure that your phone's blue tooth is out of hidden mode and , it now shows up as shown to all, in the connectivity settings.
  2. Make sure that you delete the pairing from the other phone , via it's blue tooth settings, if you are not using the phone and it's switched off , then you don't have to worry about it.
  3. Switch off the bluetooth and restart it , so that it's ready to accept new connections.
  4. Now go in your blue tooth option and search for a new paired device , it should reflect your Jabra blue tooth.
  5. If the above method does not work , sadly your phone does not support the Jabra blue tooth.
  6. You should also try connecting this blue tooth to someone else's nokia phone to check compatibility , if it's compatible with the other models, that means X3 is an exception to this compatibility.
Hope this helps.
May 11, 2011 | Jabra BT2050 Bluetooth Headset
CANNOT GET TO PAIR says it is but is not connected
Hi, It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hope it helps.
Thanks for using fixya.....
Nov 29, 2010 | Jabra Bluetooth Headset with Adjustable...
How do you connect it to a nokia 6300
To connect a jabra 250 to the Nokia 6300: On the Nokia go to menu > settings > connectivity > bleutooth = select and the next line = visible
On the headset when it is off > push the upper button for ± 8 seconds until the lamp is burning constant and release this button.
Choose on your Nokia on the same bleutooth menu > search audio.... It will be pairing in a few seconds . It will ask if it is ok to make the connection. The password is "0000" and push on "yes"
I hope you cann understand my english, I'am dutch.
Nov 17, 2010 | Jabra BT250 Consumer Headset
Can a jabra bluetooth headset number N356 Z302 pair with an iphone
i need the pass word for this bluetooth n356
Oct 31, 2010 | Cell Phones
I need the manual that came with my jabra blue tooth
Having the model number of the Jabra would be extremely helpful.
Most Bluetooth devices have a default pairing ID of 0000.
As for turning the volume UP or down, depending on what ear it is worn on, is nothing but trial and error.
Turn on your phone, go to settings (or tools) and turn on bluetooth. Select find device:
Turn bluetooth JABRA on and HOLD the power button until the Jabra flashes. (this means it is sending a bluetooth signal) Your phone should see it and ask for a pairing code. Enter 0000
A message on your phone should indicate you are paired.
Good luck.
Oct 08, 2010 | Cell Phones
I need pass key for Jabra BT530 to pair with cell phone.
Take care.
Aug 06, 2010 | Cell Phones
Need to re-pair bluetooth to phone
Go to ur phones bluetooth settings - activate pair new device - at the same time press and hold the on button on your blue tooth head set for about 10-15 seconds - this will enter the device into pair mode - on your phone - click on pair with new device etc etc, the default access code is either 0000 or 1234
Jun 29, 2009 | Jabra Bluetooth Headset with Adjustable...
Unable to make or receive calls using Bluetooth.
try to remove the Jabra Blue tooth that you have under th list of your paired devices. try to turn off the phone and blue tooth then pair it again.
Jun 25, 2009 | Cell Phones
Jabra BT2050 Bluetooth Headset  Logo
2,015 people viewed this question
Top Jabra Radio Communications Experts
Greg Cann
Greg Cann
Michael Vincent Cruz
Jerry Greenberg
Jerry Greenberg
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
