Question about GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker is not getting any water - GE (PSS26MSRSS) Side by Side Refrigerator
  • GE Master
  • 8,220 Answers
It is either going to be the ice maker or the water valve. First make sure you ain't got an ice cube jammed in the ice mold. If you do then use a hair dryer to melt that fouled ice cube. The ice maker uses a logarithmic program which constantly measure resistance to the mold. It adds the water add needed. When the resistance in the ice mold changes to the point ice has been determined in the mold the program will initiate a harvest cycle. The heater will come on and the motor will push the ice out. With the mold empty the resistance changes. Water is introduced till the resistance for fill is met. This means it will continue to try till it gets enough water to satisfy the program. If it was me I would replace the valve first. That might fix it. If it does not fix it then when you replace the IM you will have a complete new ice making capability.
Here is a PSS service manual
Electronic Ice maker manual
Posted on Sep 05, 2010
My lg refrigerator lsxs26326 is dispensing water but not filling ice tray up. What could be wrong?
the water solenoid valve for the water dispenser is separate from the icemaker water supply solenoid valve . get to the icemaker water supply solenoid and test it if it works alright . unplug the fridge from wall outlet do not close water supply valve. disconnect water tube connection on the water discharge side of the icemaker water supply solenoid valve . pull - out power supply connection of the solenoid coil . connect solenoid valve directly to wall outlet. a faint click should be audible and water should come out from where the tube was removed -- from the water supply discharge side. if no water is coming out with the solenoid plug in , then the solenoid is faulty. but if water comes while solenoid is powered -on , check the position of the icemaker lever. if it is on off position icemaker timer won't activate icemaker water supply valve..move icemaker lever to on and check for water pouring into the icemaker tray' if no water comes out . change the icemaker timer. thanks.
Mar 04, 2016 | LG Refrigerators
I moved my GE TFX277PFSB (new in 1994) side by side to my enclosed sun porch 2 years ago when i got a new fridge for the kitchen. Today, I decided to run a water line to it to allow it to make ice again. ...
Make sure the arm on the icemaker is in the down position,if it is up and locked in place the icemaker is off. If it is down and the icemaker is turned on,each time it got cold enough the to cycle the icemaker(usually about a hour) the icemaker started and for 7 years power was sent to the water inlet valve to fill the icemaker and the icemaker side of the water valve is burnt up. The water valve has 1 inlet teh house water supply attaches to and 2 outlets 1 for icemaker and 1 for door dispenser
Gene
Aug 07, 2011 | Kitchen Ranges
Ice maker leaks or runs over Causing big chunks of ice in the drawer
It's very possible that the water inlet valve isn't cutting off completely. I had that to happen on mine.
Mar 17, 2010 | Amana ATB1832AR Top Freezer Refrigerator
GE side by side refrig/freezer Mod. TFH24JWTA WH. Ice maker stopped working, stop/start wire is down (on). Get water through the door, but not sure if it goes to the ice maker. Ice maker is empty of water....
usually yes if no water to icemaker could be water valve solenoid. . first you can remove cover on icemaker and put the unit thru a test mode. find the plastic or medal cam in center of icemaker head when cover is removed., theis is a flateblade screw center get a small screwdriver and turn screw counterclockwise for about a 1/4 of a turn , icemaker will start cycling if icemaker ok then it will go througha cycle let it do its thing usually a few minutes for it to cycle, if fills you may have a bad icemaker, if no fill then valve may be bad. make sure you have good water pressure from your water supply that can cause icemaker problems.
Sep 17, 2009 | Freezers
The icemaker will not work
you might need to replace the icemaker or the freezer isnt getting cold enough for the icemaker to operate correctly. if freezer isnt getting cold enought for icemaker to operate correctly you should probably have it checked by a tech. if the icemaker isnt taking water you also could have a bad water valve
Sep 17, 2009 | Refrigerators
Not makeing ice , defrosted frezzer, got drinking water, took back off by water lines, brown sylonied not getting power too send water up. what is wrong or were to from here
That is a water valve that supplies water to the icemaker and water dispenser. The icemaker is what energizes the valve and sends water to the icemaker. Change out your icemaker or you can just replace the module on the icemaker.
Sep 13, 2009 | Refrigerators
Amana side by side icemaker stopped working
The icemaker is not working because the water pressure is too low. An icemaker is controlled by a timer so it has no idea how much water is in it. The water valve gets energized for about 7 seconds letting water in the icemaker, but if there is no water pressure then the icemaker will not fill.
Sep 12, 2009 | Refrigerators
Kenmore side by side Mod#10657567790. No water to Icemaker. I am getting water to water disp. but none to icemaker. Changed out solenoid still no water to ice.
Hello. It sounds like the icemaker is bad. It is not the solenoid but the fact that the icemaker head is not requesting the water.
Jul 15, 2009 | Refrigerators
Icemaker not signalling for water.
cheek the condenser fan.if its opration is not correct.
May 23, 2009 | Whirlpool GD2SHGX Refrigerator
Ice machine not making ice
Hi, everak11,
Three possible solutions for you.
1: No water coming in from inlet valve. Check voltage on inlet if you have voltage and no water then replace valve.
2:Icemaker not cycleing. Lift the arm on the icemaker to shut it off and leave it for about an hour. Come back in and turn the icemake back on by lowering the arm. If the icemaker does not begin a new cycle and the arm start rising then the problem is most likely an icemaker. Replace Icemaker
3:Refrigerator not cold enough. If the freezer is not getting cold enough the icemaker will not cycle. Check the temperature in the freezer and make sure it is getting down to 0 degrees. If not then you may have another problem with your refrigerator. I hope this helps you, Let me know if you have any other questions or symptoms. Mike
May 08, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
62 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Lawrence Oravetz
okcchemist
Level 1 Expert
