Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
What does error LD mean - Whirlpool Cabrio WTW6600SBT Top Load Washer
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine and replace the part that has gone bad.Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 05, 2010
Again and again got a error of sc329 .......how to fix
this error code came from the LD unit which means the seconder LD is not synchronized on the machine but try to clean the mirror if it came agin the replace the LD board
Aug 14, 2015 | Gestetner DSm745 Black and White Copier
LD error
LD is long drain time. Be sure there is no blockage in the drain line and clear the filter if there is one. What is the model number of the unit?
Nov 28, 2012 | Westinghouse Washing Machines
Won,t spin
A LD (Long Drain) error code means that (more or less), the drain pump is failing.
May 11, 2012 | Bosch Washing Machines
We have a Kenmore Elite Calypso, it is not washing
"Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
Press STOP/CANCEL to clear the display.
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Here is a manual:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0102048.pdf
See page 17.
Sep 15, 2009 | Washing Machines
Whirpool cabrio error ld
Hi
Error ld means Long drain. Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. Press STOP/CANCEL to clear the display.
If it doesn't clear the error then check whether your drain is kinked or clogged with lint and debris. If not then there is definetly some problem with your drain filter and/or drain pump.
Please do rate the solution as FixYa and Revert for further assistance.
Thanks
Rylee
Jul 04, 2009 | Whirlpool Washing Machines
''LD'' error
“LD” stands for “long drain,” meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I’ve even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the “LD” error code springs forth from such anomalies.
for more information follow the below link --
http://fixitnow.com/wp/2009/03/11/whirlpool-calypso-washer-full-of-suds-wont-drain-and-throwing-an-ld-error-code/
Mar 20, 2009 | Whirlpool WTW6600SW Top Load
What does ld mean on my washer?
op is probably ob, off balance, the ld is long discharge, most likely the pump is bad or full of junk, the origional pumps were updated to a better design so as not to get stopped up.
Aug 02, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Model No- LD-12AW2 LE Error showing what does this mean
LE error code means that there is a problem with the motor.  One thing to check is to remove the front door panel and check the wiring harness to see if there are any broken wires.  If there is, repair the wire connections and see if the dishwasher returns to normal.  If not, then the motor assembly will need to be replaced.
Apr 20, 2008 | LG 24 in. LD-12BW5 Free-standing...
LG dishwasher model LD-14AT2
normally means not heating check element and use less soap
Nov 25, 2007 | LG 24 in. LD-12BW5 Free-standing...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
244 people viewed this question
Dan Webster
Dan Webster
Sal De
