Question about Kenwood KDC-MP435U CD Player
How do I install kenwood head unit wiring to a Mitsubishi galant 2001
4 Suggested Answers
dna_killer
  • 34 Answers
SOURCE: installing kenwood 3026
if it the speaker wire`s you need to find out, just take a AA battery touch the +\- on the speaker wires if it makes a scratching sound threw the speakers its the right wire
i hope this answers your question
craig:)
Posted on Jan 20, 2008
logosc75
  • 625 Answers
SOURCE: what wire is the REM
The standard remote turn on wire color is blue with a white stripe.
Posted on Apr 13, 2011
iadame
  • 676 Answers
SOURCE: I just purchased a new
The following will help you out. The first is for the vehicle and the second for the stereo. Good Luck.
Constant 12V+ Orange/Black Switched 12V+ Yellow/Green Ground Black/Green Illumination n/a Dimmer White/Green Front Speakers 6" Doors Left Front (+) White/Black Left Front (-) Gray/Black Right Front (+) White/Red Right Front (-) Gray/Red Rear Speakers 6" x 8" Side Panels Left Rear (+) White/Purple Left Rear (-) Gray/White Right Rear (+) White Right Rear (-) Gray
Posted on May 17, 2011
2001 galant es shakes when you put it in drive. I changed all motor mounts,spark plugs and wires. What else could it be
If its a shake it may be a head gasket that is out. Did the cars radiator get hot ? Check the radiator and dipstick for signs of oil. The dipstick will be milky. You can usually smell oil in the radiator.
Feb 21, 2015 | 2001 Mitsubishi Galant
I got a boss head unit and i need help to install it
best option is to go to your local auto parts store and get the harness that matches your car, it is much easier than cutting into the car harness and try to figure out what wires go where.
Sep 30, 2012 | 2001 Mitsubishi Galant
Mitsubishi galant es ecu location images
What coloure is the wire that ignite the ecu
Jun 06, 2012 | 2001 Mitsubishi Galant
I have a 2000 mitsubishi galant it came out in october of 2000 with a 2.4lL engine i can not find the computer does anyone know where to find it. i do know that it is not on the firewall
The computer is located on the passenger side firewall under the dashboard behind the glove box and the blower housing unit. Take the 10 millimeter screw off the ground wire. uplug the wire from computer and pull the computer downward to the floor board...... Just follow the wires on the firewall.
May 11, 2011 | 2001 Mitsubishi Galant
Where is the door pin trigger wire of Mitsubishi Galant VRG 1996
the door trigger wire is inside the chassis. it goes to the fuse box underneath the dash, where you can tap your alarm. it is usually the fuse for the dome/door light.
Sep 20, 2009 | 2002 Mitsubishi Galant
I having trouble finding the crank position sensor on my mitsubishi galant.
You did not specify year or engine size, but...
The crank position sensor is located inside the timing cover, behind the crank pulley.
The wiring for it extends out of the timing cover by the motor mount upwards to a three wire triangular connector. On four cylinders the connector is mounted by the front corner of the head. V6 models the connector is mounted in the valley between the heads.
Later 4cyl models integrate the connector into the lower cover, but the sensor location is still the same.
Aug 11, 2009 | 2001 Mitsubishi Galant
I need a car stereo color coded wiring guide mitsubishi galant ES
They are very easy to find online. Just google wiring diagram for the make and model.
Aug 09, 2009 | 2001 Mitsubishi Eclipse
I am having trouble finding the cam shaft positioning sensor on our 2001 2.4L Mitsubishi Galant
The CMP sensor is mounted on the left end{opposite end from the timing belt}of the cylinder head...
Jul 12, 2009 | 2001 Mitsubishi Galant
Kenwood KDC-MP435U CD Player Logo
119 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
