Question about Amana Washing Machines
How do you get the dial off of the timer so you can change it out with a new one. I tried pulling it off but it will not budge. my model # is nav2335aww
  • Amana Master
  • 8,220 Answers
On the backside of the timer is a stick that slides inside the hollow timer shaft. When it is shoved all the way in it spreads the tip and retains the timer knob. Back the rod out a about a half inch and the knob will come off.how do you get the dial off of the timer so you - bd28a28.jpg
Posted on Sep 05, 2010
I bought a new timer the model # is 59382 I have tried setting and it didn't work. I called the store were I bought it and a guy told me how over the phone it still didn't work. I am getting very...
http://waterheatertimer.org/Woods-timers-and-manuals.html#59382
Quote:
Maximum load 500 watts, used for indoor or outdoor
Set current time, rotate dial until current time lines up with black triangle.
Around outer edge of dial are segments.
Pull up all segments for times you want timer OFF
Leave segments down for times you want timer ON
Locate switch on timer.
Push switch toward the 'V' shape that is pointed down.
Plug into wall outlet, plug lights into timer.
End quote.
Two people have written to fixya saying their 59300 series timer had no switch.
But none of those folks sent a photo of their timer so I could see how they had the settings.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Apr 18, 2011 | Hardware & Accessories
Model 59204EV Outdoor Mechanical timer - How do I set it - The pins do not move on my timer - where are the pins located?
Different Woods timers have same model number, depending on who packaged and sold product.
Manuals are sometimes generic. They say pins when they mean segments or tabs.
Segments are small plastic divisions located around outer edge of dial.
They divide 24-hour day into 15 minute or 30 minute periods.
Link below shows sample pins and tabs.
http://waterheatertimer.org/Woods-timers-and-manuals.html#Pins-tabs
With the 15204, I believe these segments pull out or push inward; but they could also pull upward or downward.
Move a couple segments, plug in the timer and lamp, and then manually rotate dial to watch how lamp turns on-off.
Lamp must be turned ON and bulb working.
Some 15204s have a switch on face of timer, or somewhere on timer. Some do not have a switch, and some have a dial. Move switch to TIMER, or to AUTO. Or rotate dial to ON.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer, any do-it-yourself project.
Jan 13, 2011 | Woods INDUSTRIES 59204 OUTDOOR MECHANICAL...
I have 2 intermatic lamp & appliance programmable timers. On the package the model number says: TN811C and on the timer itself says: TN811. Anyways I have read the instructions and I can't figure out...
1. To Set Program:
Pull up one tripper
between hour marks
on the 24-hour dial
for each 1/2 hour of
ON time desired. For
example, if timer is to
be ON between 12-2
PM, all four trippers
between those times
must be pulled up.
2. To set time
of day: turn dial
clockwise with the
arrow head pointed
to the correct time.
The dark area
denotes PM and
the white area
denotes AM.
Straight out of the manual. Pull up trippers for all of the time that you want the device to run.
Rotate the time of day dial in the direction of the arrows.
The off/on dial will override the timer until it comes around to the on time again then the timer will control.
Good luck.
Gary
Dec 10, 2010 | Intermatic Hardware & Accessories
How do I set the woods outdoor timer model #59730
Woods 59730 is24-hour 6-outlet yard stake with dial located on top
This timer is identical to GE15107 yard stake
Manual.
http://waterheatertimer.org/pdf/GE-15107-outdoor-timer-manual.pdf
If this is not your timer, look at following page to identify your timer
Add a comment any time
Timer instructions.
Set current time by rotating dial until time lines up with arrowhead located on inner dial
There are segments located around dial.
Look at inner dial > segments are located just outside the inner dial.
Timer comes with segments pushed inward.
To set timer to turn ON, pull segments outward for hours you want timer ON.
All 6 outlets are controlled by timer.
Last step:
There is override switch located on inner dial.
Move switch to TIMER for timer to operate.
Dec 09, 2010 | Woods Outdoor Lighting Timer
We need clear instructions for setting the timer
Woods makes several outdoor timers:
Image that shows with this post is Woods model #49647.
Below are instructions for #49647 timer.
If your timer is different, add a comment with model number and I'll post instructions for that timer.
Woods model #49647 is outdoor timer with photoelectric control that turns timer ON at dusk.
There are 4 possible settings that show on dial.
Rotate dial to make timer selection.
OFF = timer is OFF full-time until you change dial.
ON = timer is ON full-time until you change dial.
Dusk-Dawn = timer turns ON at dusk and OFF at dawn
2, 4, 6, 8 hours = timer turns ON at dusk, and turns OFF 2, 4, 6, or 8 hours later.
Nov 26, 2010 | Woods Outdoor Lighting Timer
I have woods lighting timer model 59200 and can not program it. every I set the time according to the instruction light stays on. What I am doing wrong?
See Woods timers:
Are you sure about that model number?
59200 is a plug-in dial-type timer.
Timer does not have a light.
The dial is rotated to set current time.
And segments located around dial are pulled up and pushed down to set timer function.
http://waterheatertimer.org/pdf/Woods-59200.pdf
Add a comment with description of your so I can locate manual and help.
Nov 21, 2010 | Woods 2C 24 Hour Indoor Mechanical Timer...
How do I set the ge timer model #15119. husband
I tried to pull the whole dial and doing that I discovered that the border of the dial is composed by pins that you can pull it up each independently, with your nail or with any pointing device. The rest is easy: get sure the switch is set at "timer on", turn the dial to the current time using the black triangle mark and pull the pin up in the time you want your device to disconnect.
Dec 08, 2009 | General Electric GE 24-Hour Timer, 2-Pin...
Trying to physicaly locate defrost timer model# F44N21CEWO
Hello, This model has a mechanical timer which is located inside the console where the cold controls are located. You will find this inside the fridge. There is a small dial on the timer for advancing the timer into defrost cycle. Most of the time there is an opening/hole for access to the dial without pulling the console out. If you can't locate the hole pull the cosole out, should be a few screws. Good Luck!!!! If you have any further questions or concerns please feel free to comment again. Mike
Jul 24, 2009 | Frigidaire Refrigerators
Removing the busted dial
if it is the timer dial just pull the heck out of it but some have a clip on the backside of the dial itself remove this pin and it will come off in your hand you can contact Ge aor repair clinic.com or even a local appliance dealer ( Used or parts dealer) in your area can order it for ya
Dec 22, 2007 | GE WBSR3140DW Top Load Washer
RRemoving the washer starter dial
Yes, stop pulling on it. Axcess the rear of the timer there will be a smaller hole with a black piece of plastic inside where the knob shaft would be if it went all the way through. use needle nose pliers to grab the plastic piece and pull out. it is easier if the knob is pushed in is gets recessed a little more when you pull out the knob. The new timer comes with a new plastic piec pull it out then push back in to lock on the knob again.
Nov 23, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
43 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
