Question about Braun Syncro 7680 Electric Shaver
Bbraun 7680 LCD displays message about adding oil? Where is the oil added and what type of oil is used for this purpose.
  • Braun Master
  • 1,625 Answers
You will find the oil at shaveroutlet.com.  Seelink below
http://shaveroutlet.com/shaver-accessories/braun/braun-shaver-oil-p-465.html
Oil is applied to the foils.  About a drop per week
Posted on Sep 05, 2010
How to Add a Board on the MA5600?
You can add a board on Huawei MA5600 in the following two ways:
· Adding a board offline: Run the board add command to add a board to an vacant slot (in this case, the system generates the "Board Fault" alarm). Then, insert a board to the slot (in this case, if the type of the inserted board is the same as the type of the board added offline, the system generates the "Board Recovery" alarm; if the type of the inserted board is different from the type of the board added offline, the system generates the "Type Mismatch" alarm).
· Automatically discovering a board: Insert a board to an vacant slot (in this case, the system displays a message indicating that a board is automatically discovered, and the board is in the auto-find state). Then, run the board confirmcommand to confirm the board that is automatically discovered.
This way is also can be adopted by Huawei MA5616 equipment.
Apr 27, 2017 | The Computers & Internet
Tip
Stop spilling oil when adding.
One of the best things I've found for adding oil to my vehicles, is an empty Ketchup bottle. (squeeze type) I simply pour oil from larger jugs into the Ketchup bottles for clean and easy adding of oil to my vehicles. Saves me looking for a funnel every time, and the clear bottle allows me to see how much I've added. The bottles are usually in 1 quart, or 1 liter sizes, so that makes measuring the amount easier too. Simply write on the bottle, what grade or type of oil is in it, and it's an easy way to keep them organized as well. Want to add just a little, squeeze a little, add a lot, keep squeezing.
No more pouring it all over engine, trying to hit that hole. They last for ever, and your doing your part to recycle as well. Handy when adding oil to any vehicles, lawnmowers etc, or even when you just need a drop on a squeaky door hinge.213d910.jpg
on Dec 26, 2009 | Chrysler Town & Country Cars & Trucks
Dixie Chopper 2460 Magnum got done with mowing I noticed an error message on my small display panel saying "Oil Low" or "Change Oil." added enough oil to show full mower will not respond to starting.
Probably seizing up from running low on oil. And or the rings are worn out from low oil. These are splash fed so keeping oil level up is a must!!
Jul 06, 2016 | Garden
How do i turn on my necvox re 7680 dvd screen
Hi, Just bought a car with drop down Necvox re-7680 connected to ad 6865 and vhs player, can you tell me where the lead from the video out on the 6865 should go please?
Jul 24, 2011 | Car Audio & Video
Error message sd
Sorry to read about your problem, I hope this helps you out.
"Sd" fault code in the image below. The "Sd" usually displays when too much detergent is used or the wrong type of detergent is used. High Efficient (HE) detergent is recommended. You clothes may have detergent in them that has not fully rinsed out and when you wash them the added detergent causes over sudsing.
I recommend washing the type of loads that generally causes the "Sd" to display without adding any detergent to see if it develops suds.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 05, 2011 | Kenmore HE2 Plus Front Load Washer
My 2006 C280 was due for service B , and I just did the oil change only. How can I reset service B message on the car computer ?
Reset process should be listed in the owners manual.
Should be something like turn car to on(not running) press trip button twice, turn to off and hold trip button till it resets.
Apr 19, 2010 | 2007 Mercedes-Benz ML320 CDI
Burning oil, but dont know why
Nowdays 1 Qt. in 3000 miles, really isn't that bad, even some new vehicles claim that's normal. I know with my current vehicles, both at approx. 150,000-160,000 miles, they won't use any for first while after an oil change, but then after mileage starts adding up again, they start to use a little, approx.I Qt, every 1000 miles or so, until it's changed again. I've switched to the high mileage oil, just for piece of mind, as they say it revives seals, and has added protection for the higher mileage engines.This time around I'm thinking of adding "Lucas" & see how it works, as I've heard some pretty good reports on it, just to see if it will prolong that oil breakdown, at mid change.
Feb 06, 2009 | 1999 Pontiac Grand Prix
Shaver shows "oil" How do I do so? nothing in owners manual .
http://www.service.braun.com/home.asp?rg=NA&c=US&l=GB&typ=ui&s=&seite=&sString=
The above in a link to brauns website. You can view or download the user manuals for all their products.
Steve
PS. It just says to put some oil on your finger and apply to the outside of the foil.
Dec 22, 2008 | Braun Syncro 7680 Electric Shaver
Have a Staples SPL-XC200d Paper Shredder. The 'add oil' light is on...but have added oil repeatedly. Does not need more oil. Have also unplugged overnight, thinking that would 'reset' the computer, no...
After you have added the shredder oil, you have to hold down the "Lubricate" button for about 5 seconds. This resets the counter and it will remind you to add oil when you have gone through about 250 more pages. Note: holding down the "Lubricate" button for 5 seconds will reset the counter and make the message disappear whether you add the oil or not, but it is highly recommended that you use the oil.
Apr 23, 2008 | Office Equipment & Supplies
Braun Synchro 7680 - "Oil" message
Had the same problem on my shaver too. Bought this product:
http://www.onlineshavers.com/pd_braun_8000_activator_foil_cutter_pack31.cfm
(I know the link says foil cutter, but it takes you to Braun lubricating oil!)
I apply the lubricating oil to the foil etc, then the word "oil" disappears. Then after a while the word "oil" comes back and I apply the oil again and so on, my shaver still performs normally.
Hope this helps.
Feb 12, 2008 | Braun Syncro 7680 Electric Shaver
Braun Syncro 7680 Electric Shaver Logo
408 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
