Question about Toshiba 1370 Black and White Copier
Wrench light on and c7 code appear
Wrench light is consistently on and and when I press the clear button and 8, I get C7 - as you have said- but what do I do now?
    Problem Solver:
  • 4 Answers
C7 is a Fuser Error......The hot part where the paper passes through before exiting the machine is known as the Fuser or Fixing unit etc.
There are 3 parts involved and any of which when they fail will give a C7 error code. The Heating Lamp,Thermisor or Thermal Fuse.
This is a live area of the machine so you wouldnt be advised to attempt a repair without at least a restricted electrical license.
More than likely one of the parts mentioned will need to be replaced and then the C7 error count reset through "08"
Posted on May 14, 2008
I need unlock code for nokia c7 movistar spain locked
u can get the unlock code for your nokia c7 model from by using this link http://www.theunlockarena.com/
following instructions makes u easy to unlock your mobile
1 - Switch on your Nokia C7 without any sim card.
2 - Don't bother as to what is displayed on your Nokia C7.
3 - Compose #pw+CODE+1#.
4 - The Nokia C7 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia C7 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia C7
Each Nokia C7 mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia C7 mobile phone using the form above.
Feb 21, 2011 | Nokia C7 (8 GB) Smartphone
I have a toshiba 1370 copier....the repair wrench is flashing and won't let me continue, how do i get the wrench to stop blinking?
switch on the machine, holding down 0 & 8 buttons, type in 89, press the green button, enter a 0, press green button again to accept the new value. switch off & then just switch back on as normal.
good luck.
Nov 13, 2009 | Toshiba 1370 Black and White Copier
I HAVE THE WRENCH ERROR; DO NOT KNOW WHAT TO DO FROM HERE
If you push clear and 8 does it say C7? Push 0 and 8 as you turn on the copier it should say ad on the display push 89 and start and (I bet 3 is displayed) push 0 and start this resets the "c7 counter"
Jun 18, 2009 | Toshiba 1370 Black and White Copier
Toshiba 1360 Copier
"C7" Faulty thermistor, thermal fuse, or heater element
Sep 16, 2008 | Toshiba 1360 Black and White Copier
Toshiba 1360 copier
Turn it on holding down 0 and 8. Key in 89, press start. press 0, press start. Turn it off and on.
Mar 18, 2008 | Toshiba 1360 Black and White Copier
Error c7
You can reset the C7 code, hold down 0&8 power machine up. Then push 87 & print, change the number to 0 with number keys press interupt key, then press 0&9 @ the same time to exit. This should clear the C7. Let me know if you need more help.
Oct 26, 2007 | Toshiba 1360 Black and White Copier
Toshiba 1360 C7 Error Code
TOSHIBA 1310 C7 Fusing unit warm-up error, defective thermistor, fusing lamp or thermofuse
The codes are good for several models.
Oct 25, 2007 | Toshiba 1360 Black and White Copier
Toshiba 1360
You should be able to retrieve a code for a malfunction by pressing down the clear/stop and 8 keys. then let me know what you get, and we will go from there.
Oct 22, 2007 | Toshiba 1360 Black and White Copier
Red "wrench" indicator always on
Press the clear and the 8 button at the same time . This will give you a error code. I will guess that you have a "C7". If you still want to fix let me know error code.
Oct 25, 2006 | Toshiba 1370 Black and White Copier
Toshiba 1370 Black and White Copier Logo
401 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
