Question about HP Compaq Evo Notebook N600c
When the laptop boots up the active window is only 60% of the available screen
2 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: display does not expand to size of screen
This problem occurs when :-
1. The screen resolution has been set too low, try setting it to 1024X768
2. The video driver is wrong.
Go to Control Panel, then Display, then Settings to check the screen resolutiuon (change if required), then Advance, then Adapters to check what video has been installed, (you may need to download the correct video driver from HP/Cpmpaq)
Posted on Nov 30, 2008
Confusion installing drivers on Dell Latitude 120L laptop running XP
to run duel screens you will need a graphic board that has 2 outlets
I run a nvidia board and it has a dvi and vga outlets connected to 2 monitors
open up the control panel and go to display
that will show 2 screens and they will be identified as 1 and 2
the printing will be for one screen and it will say -make this my main screen
further down will be a dropdown box that will have extend screen
click on that
as for the screen size or pixal settings click and drag the slide button up to the top and click on apply
any way in that display section you can move and click on different settings to get what you want, always apply to fix the settings selected
it will come back with a message --do you want to retain the settings and if you are happy --click on yes
regardless of what you choose , you can always reset at a later time
Feb 26, 2017 | Aoc Monitors AOC e2752Vh Glossy Black...
Missing Operating System on D: partition Bootup
Follow the steps from this site http://www.wikihow.com/Change-the-Active-Partition-of-Your-Hard-Disk-with-Parted-Magic. When you changed the active partition you told the computer to look for information from the wrong partition. Using the program from that site will allow you to make the other partition active again. You'll then be able to boot into Windows again. As far as making backup discs, I believe you hit F11 while booting to access the recovery partition. From there you can make your recovery discs. Not 100 percent sure on that though. And you will need to get the windows partition set back as active first.
Jun 19, 2013 | HP ProBook 4510s FM849UT Notebook
Screen
Try pushing no. Your windows version hasn't been Activated. Use your activation key when you get booted up. Is this a Windows OS upgrade? A reinstall? It would be helpful if you posted the Make and model of Laptop and the OS you are using.
Apr 02, 2013 | Computers & Internet
How to format compaq presario CQ 60 204NR LAPTOP WITH WINDOWS VISTA
When you boot from your Vista dvd, it will show all your partitions.
Then you can format, delete and much more...
I've you dont have a Vista dvd, you should use Hirens Boot CD.
Tutorial + Download links:
http://www.youtube.com/watch?v=3oXmwMIJLoo
Note:
You can't format your harddrive when Windows is active, so you must use a bootable cd/dvd.
I've you have any questions, feel free to post them here.
Jun 25, 2011 | Compaq Presario CQ60-204NR Notebook
I have an Acer laptop with windows vista. I've forgotten my logon password. Can you help?
just download and make a cd boot from cd .
click here
Click here
or another
Download the iso file from =http://www.fullandfree.info/software/hirens-bootcd-v100/
Write the iso in blank cd
Boot from cd
DONT PANIC follow all the steep It is very simple ,
Use the down arrow key.
1.INSERT CD TO CD TRAY
2.Boot from cd
FOR PASSWORD BREAK
3.Select start boot cd
4.Coice Password and Registry Tools>enter
5.Choice Active password Changer for (NT/2000/XP/2003/VISTA)ADMINISTRATOR PASWRD RESET.
If you change the HDD PASSWORD, Seclect ATAPWD 1.2(HDD password Uttility)
wait >all will be AUTO
HERE YOU can see the option 1.Logical drve and 2.Search for all HDD and logical.
If you have one HDD choice 1. Logical drive
You you Have More then One Choice search for all hdd.
Just Choice the no and put it on the Your Choice [ ] >enter
Now Choice the partition
Either "0" or "1" which is your active partion for your Opereting System. If you have two "OS" in the same HDD,
should choice all.
If you have one "OS" choice "0" to "1" press the number .Generally would be "0"
Only the reason, every laptop has the option ,for one HDD.
So Choice "0" >enter
Follow the steep on screen text > enter
From here, you can see the option for Administrator or Usser .
Generally Administrator will be "0"
Hope it will you.
Jan 05, 2011 | Computers & Internet
Wont boot up,black screen.message on screen says,invalid partitio
When you power up your computer, the system examines the master partition table to determine what volume to use to boot up the operating system, and detected invalid information within it. This is caused by an incorrect or missing active partition.
To resolve this issue, consider the following steps:
  • Boot up the computer with a Microsoft Windows 98 boot up disk or Windows XP recovery console. Select the correct bootup device before you do that.
  • At the DOS command prompt, type in: fdisk
  • Question - Do you wish to enlarge large disk support (Y/N) ?
  • Enter: Y
  • Now to check for active partition, enter: 2
  • Look under the Status column. The active partition is usually assigned to the drive which contains your operating system.
  • If there's no active partition set, enter the number of the partition to make active
This must solve your problem.
Apr 15, 2010 | HP Compaq Presario 2200 Notebook
Guru, I cannot restore the system and I have no warranty, it is over 3 years old. Is it worth fixing or should I just buy a new computer? Thx for your quick reply!
If you know someone that has a windows disc you can try to use to make certain that yours is not damage. I would not finish loading, because you will not activate it, it will but it will ruin a activition on windows. Dell used Hitachi drives they are junk compare to western digital as far as shock absorbing.
If that doesn't load then your hard drive is bad, and that is inexpensive to repalce. My dell laptop crashed, and I bought mine for $60 at bestbuy. I went from 80 to 120 gigs. I would go with a western digital scorpio. They have a highest rading on shock absobing.
Nov 24, 2009 | Computers & Internet
Long time to boot nearly 60 times
RUN  The REGEDT in registry editor find these kei: COMPUTER\HKEY_CURENT_USER\CONTROL PANEL\DESKTOP in the right screen look for MENU SHOW DELAY klik on it and change the value to ZERO  type there ZERO insted of 150- 200- 400 depend of what falue is there .
Jan 17, 2009 | Computers & Internet
Display does not expand to size of screen
Nov 30, 2008 | HP Compaq Evo Notebook N600c
Trying to do a repair installation
OK, that screen is the bios for the laptop. Don't do anything in there. (except check under boot and make sure the boot order is cd then hard drive) Once the boot order is correct, just boot from the cd rom, and to do a repair, just keep continuing past where you are asked to enter F-8, the next screen will offer a repair for the windows installation- press R. That keeps your files and programs, but reinstalls windows. Good luck
Aug 11, 2007 | Acer Aspire 3680 Laptop
HP Compaq Evo Notebook N600c Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
