Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Randomly flashes F1 during various stages of washing & machine stops working
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error code F1 indicates primary control failure and to resolve this you’ll have to replace the machine control assembly. Yes you are right, this error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 05, 2010
E8 front loader washing machines
OVER CURRENT ERROR - Display shows 8E.IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
IPM: Integrated power module. The IPM controls the motor.
If the fault (low signal) happens to be sensed even once during the washing/rinsing stage, the motor stops immediately. However, during the dehydrating stage the signal is to be sensed, when the number of signals reads more than 6 per 500ms during the Washing or Rinsing cycle action.
If the motor stops working, in one direction ten times, "8E" Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error "8E" is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power Switch OFF can clear the overload error.
HOWEVER, the UK White goods website says:
E8
Temp too high on low temp washesNormally this will be the wash temperature thermistor or NTC that's faulty, please contact us if you need the thermistor with the model and serial number.
You can find more about your Samsung Washing Machine error codes at:
http://www.keepingupappliances.com/repair-help/appliance-repair/washing-machine-help/samsung-washing-machine-error-codes/
or
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3069-samsung-washing-machine-fault-codes.html
Jun 21, 2011 | Samsung Washing Machines
I have a Whirlpool Cabrio top load washer. When I load the clothes and start the washer and it begins to run I hear an alarm, it stops and a F1 flashes on the display. What does this mean?
F1 (F60-68)
Primary Control Failure F then 1 flashes when there is a primary control failure. Replace the machine control assembly.
See Accessing & Removing the Electronic Assemblies.
F1 flashing on the display indicates a primary control failure.
"F then 1 flashes when there is a primary control failure. Replace the machine control assembly."
The link below lists Cabrio failre codes.
http://www.advantagesupplyfl.com/WhirlpoolCabrioWasherFaultCodes.html
Dec 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Anussi ZWD 1271W stops at beginning of program
Did you fix this problem? We have the same with Zanussi ZWD 1472 W. It takes some water and stops after 2 minutes. We need to shut machine down and fill water manually. It works fine then.
Feb 02, 2010 | Zanussi Washing Machines
Whirlpool 6th sense front load washing machine stopping mid cycle. Have to turn power off to reset & restart
I have the same problem. Stops randomly during the cycle and turning off the power for a second re-starts it.
I think it is one of the sensors is faulty - for example the sensor that detects if the load is un-balanced, or if the machine has enough water.
Seems to be a common poblem for these machines.
I'm going to try to find which one later today.
Dec 20, 2009 | Whirlpool AWM6120 Front Load Washer
My Bosch WFL 1220 MAXX F/L washing machine stops during a cycle
The diagnostics are finding a proble. Usually a time out on the fill or empty. Check water supply is clear and that the drain filter is clean
Dec 08, 2009 | Washing Machines
My samsung washing machine model WA13513 13.5kg load had 8E error message popping out from the screen. Is the computer board damaged?
OVER CURRENT ERROR – Display shows 8E. IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
If the motor stops working, in one direction ten times, “8E” Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error “8E” is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power SIW OFF can clear the overload error.
would advise calling a tech... hope this helps.
Oct 25, 2009 | Washing Machines
E8 error code
8E - OVER CURRENT ERROR
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 02, 2009 | Washing Machines
Washer stops with an F1 Code during rinse cycles.
Well I have the same problem the only way I have found that my washer works is that on the soiler level make sure you put that on the heavy. And that should work I know its a pain but thats what I do and my washer washs with out stopping
Dec 04, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
35 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
