Question about BUSlink 4PORT IROCKS USB 2.0 HUB SILVER ILLUMINATED
Lost power supply
I have an i-rocks IR-8100m hub reader and have lost the power supply what input voltage do I need?
  • 84 Answers
DC 5V
Posted on May 12, 2008
I look for the driver for I-Rocks IR-4650 3+1 ports USB 2.0
Hi
The I-Rocks hub is a USB hub and needs no drivers for Windows XP or later, as they are included in Windows and loaded as necessary when the hub is plugged into the computer.
If you are having problems, I suggest you go here:
http://www.manualshelf.com/download/i-rocks/ir-4650/0AlBUfl5HfUV--3rO8rt4zmuK8o/technology-rapid-usb-31-port-hub-quick-installation-guide.pdf
and save the full manual to your computer. There is a troubleshooting section in particular which may help you.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 25, 2014 | i-rocks Computers & Internet
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
I misplaced the power adaptor, and found one the fits in, but don't know if has the coorect powers output.. the power adaptor I have for this I rocks IR 4300 is an eblue mainstay with an output of 5.0...
as per irocks page this is the power info for your device:
Power : Self Power : 5V
Adapter : (input)100~240 VAC , (output)5 VDC
you probably may want to check with someone at radioshack if the adapter you found matches above specs
info on your device can be found here
Dec 26, 2009 | i-rocks IR-4300 4-Port USB Hub
Lost mt power supply cable, can you tell what the input voltage is for the HUB 4U is?? Also can his be used om a Mac OX 10.4.11 Dave
Since the manufacturer is out of business, it is hard to find any information on this hub, but you can find more details here or here (for Mac).
The voltage for the adapter has to have an output of +5VDC with minimum 2.5A.
Important!!! - The inner post is positive and the barrel is negative.
And - yes - it can be connected to a Mac since both versions are technically identical.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Nov 04, 2009 | Entrega (HUB-4U) Networking Hub
My irocks enclosure only came with 98 drivers where can i get xp
Xp does not need them but check the information below before you panic.
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
Aug 30, 2009 | i-rocks External Hard Drive Enclosure -...
Power supply for Targus 4 hub usb 2
Most USB hubs do not need an external power supply, except when a connected USB device draws more power than the computer/laptop USB port can supply. In this case an external power supply will need to be connected to the USB hub.
Normally this would be a 5 volt power supply, but make sure the polarity on the connector matches the power connector on the hub, check the label on the hub, sometimes it states to power requirements of the hub as well as the polarity on the connector. Normally the pin on the hub's power connector is positive (ie. +5V)
Nov 13, 2008 | Targus PAUH217U 4-Port USB Hub
Entrega Hub 4U
The adapter that works on my machub4u y Entrega Technologies has a output of +5VDC at 2.5A with the inner post being positive and the barrel being negative.
Sep 01, 2008 | Entrega (HUB-4U) Networking Hub
I-rocks IR-4300 4-Port USB Hub doesnt work
You shouldn't need a driver for it, Windows has bundled native drivers that will be enough to make it work.
Does anything else work in the port you plug the hub into?
Jul 11, 2008 | i-rocks IR-4300 4-Port USB Hub
7 port usb hub
5V DC 3.7A  center + Adapter : )      Jay........
Dec 30, 2007 | Entrega (HUB-7U) Networking Hub
Not Reading Peripherals - i-rocks IR-4100 4-Port USB Hub
If your looking for a good quality USB hub, i would go with a Belkin. They do cost more than most other hubs, but from the 8 years i have been at my retail store, they have had the lowest return rate of all that I have sold.
Aug 25, 2007 | i-rocks IR-4100 4-Port USB Hub
BUSlink 4PORT IROCKS USB 2.0 HUB SILVER ILLUMINATED Logo
175 people viewed this question
Top BUSlink Computers & Internet Experts
David Payne
David Payne
Are you a BUSlink Computer and Internet Expert? Answer questions, earn points and help others
