Warranty item replacement
Hello, I need a replacement ac adapter for my laptop and i have your PSP. How do I go about ordering one?
    Champion:
  • 230 Answers
You need to tell us the output for the laptop. You can find this infor on the back of the laptop. Your looking for something with a "V" output. Also make and model.
Posted on May 12, 2008
HP screen goes black 5 seconds after ac adapter is plugged in or out
This may not be the ac adapter itself. the metal prongs on the side of your HP Laptop to connect to the wire of your ac adapter may be bent or shortciruited. try to get a replacement which may be hard depending on what type of HP Laptop you own. or you may just have to send it back if you dont know how, in order to avoid breaking the warranty policy by mistakenly damaging it.
Apr 18, 2013 | Computers & Internet
Laptop Won't Boot
You'll need to troubleshoot your laptop in order to know what the exact problem is. First try to plug it in with the battery on and try turning the laptop on. Next would be to remove the battery and plug the computer. If this doesn't work then it's definitely the AC Adapter and you'll probably need to call toshiba to purchase a new one from them or if you're still under warranty then have it replaced. They also have some qualifiers on whether an AC adapter or battery is qualified for replacement even if it's under warranty. Just call them on 1-800-457-7777 and ask their technical support reps about this.
Sep 17, 2008 | Toshiba Satellite A105 Notebook
Psp 1001 charging really slow using usb to ac adapter
You have to buy ac adapter I was same I don't have ac adapter but I have powerbank so I can charge it
Feb 22, 2013 | Sony PlayStation Portable (PSP) Console
No power
Hello, If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems. 1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose Hope this helps
http://www.chargerbuy.com/laptop-ac-adapter/toshiba-ac-adapters.html
Nov 10, 2012 | Toshiba Computers & Internet
Netbook charging indicator light won't light and battery won't charge. AC adapter works on other computers
Hope this helps...
Sep 15, 2011 | Gateway LT2021u Netbook
My HP ac adoptor broke and I need a replacement. part. "HP Spare 402018-001" I found this on several web site for $ 13 or so with shipping charges about $20.00. no problum. my question is...
All the local shops will probably order the item from HP direct, which would cost you about $80. Ebay works pretty good and if you use paypal.. pretty safe. I've purchased many adapters, batteries, and computer parts off ebay.
Chris
Aug 10, 2011 | HEWLETT-PACKARD 380467-005 AC Adapter - 65...
Not charging
1.Check the power outlet if it's working.
2.Try to also change the power cord with good one. If it works then the problem is the power cord.
3.Try to use a good know ac adapter to check if the only problem is the ac adapter. If it works then the problem is the ac adapter. If your still in warranty, you can go to this website to get a replacement ac adapter acclaim.toshiba.com or go to toshibadirect.com to order replacement for non-warranty.
4.If could borrow a battery that has same specs and size of your battery , you may put that on your laptop and try if the laptop will power ON. If the laptop won't turn ON, meaning there is a system board problem, if it turns ON the only problem is the ac adapter.
If your still under warranty, you may contact Toshiba, you may send it at no cost.
Mar 16, 2011 | Toshiba Computers & Internet
Replacement AC Power Adapter Not Charging Battery
Its not an adapter problem. its not a battery problem as well.
Here is what you can try to solve it.
1. we need to update the BIOS of the cmputer/ for that. go to the website. support.dell.com and then click on drivers and downloads. click on enter the service tag. and then enter your computer service tag and then it will take you to the downlaod page and then you would see a downlaod for BIOS. downlaod it and install it. 60% it will fix the problem.
Note:- the battery charge must be 10% in order to continue. else it wont work.
2nd thing. the port where you connect the adapter to the computer which can be called as a mother board that has gone bad and needs to be replaced.
and replacing the motherboard is not economical it a very costly item. so you might need to think of purchasing another laptop.
3. if you even donot want to buy another laptop. call dell if you are in warranty they will replace the motherboard else they will connect you to Out of warranty repairs and they will fix it. its a hardware problem and it is a costly item. be aware.
i can understand its sad, but if this information was helpful please rate this solution.
Sep 24, 2009 | Dell Inspiron 6000 Notebook
PSP Power light is green but screen is black
BIOS is corrupted on the mainboard inside of the PSP. Unplug the battery and also unplug the ac adapter.
After about 5 minutes plug up just the ac adapter and turn on the psp and see if you get video of any kind. If you can't get into any menus or any video to come up then your motherboard is corrupted and would need to be replaced. Hopefully if your psp is still convered under warranty you can get a replacement.
Jun 29, 2009 | Sony PlayStation Portable (PSP) Console
Adapter for AC is broken
Your post title says the adapter for "AC" is broken but your description mentions the cigarette adapter. The cigaretter adapter is DC. An AC adapter plugs into the wall outlet in your home.
If you are looking for a replacement car adapter, try Ebay:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=150279323123
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=310072797582
Jul 31, 2008 | Garmin nuvi 350 GPS Receiver
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
