Question about VillaWare V00143100 Blender
I need to replace the pitcher as it has cracks around the blade fixture. I can't find anyone selling them online or in Canada.
I have the same problem. Anyone have an answer?
Posted on Sep 25, 2010
How to replace the blade assembly on my Vitamix commercial 4000 (stainless steel pitcher) I have the blade assembly but it's more complicated to replace than I thought. HELP.
there is a wrench (by Vitamix) for under $10. you can get it from amazon. it makes the job of removing a blade assembly much easier.
Jul 01, 2016 | Vitamix Blenders
Need replacement jar for model #14074 purchased 2003
If it cannot be purchased right from the maufacturer (which it likely won't as it is 11 years old), you can get nice blenders for around $20 at super stores like Walmart that work well and last for a while.
Jul 08, 2014 | Ultrex 834-334 Die Cast Work Top Blender
Broken blade housing
I have the whole blender. White with a red glass pitcher. I have only used it twice. For ice. What would you pay for the whole blender? You would then have a back up of it all. Works fine. Just too heavy for me.
Jun 18, 2013 | Jenn-Air JBL800 Work Top Blender
Smoothie maker 600
Check to see if the jar has any cracks or if the blade assembly or collar have any cracks.
Is it possibly leaking from the tap valve?
If the blades or tap lever are cracked I would recommend replacing them, however if the jar is cracked i would just buy a new blender. These are great for smoothies but they are all discontinued and parts wont be available for much longer.
May 05, 2013 | Back to Basics 600 Smoothie Plus Work Top...
How do I fix or replace my kitchenaid blender blade KSB560BF (Polycarb Jar)? It's leaked thru the blade assembly.
Make sure the blade assembly is put together in the correct order. The blade needs to go through the gasket so that the order is pitcher glass, gasket, and metal blade base. Then the final plastic cap threaded onto the pitcher. If the gasket is not between the pitcher and the metal blade assembly, you will have leaks.
Also, check the gasket to be sure it's not cracked and that it doesn't have residue on it.
I hope this helps. If it does, please come back and rate my suggestion!
Jun 15, 2011 | KitchenAid KSB560 5 Speed Blender
The blades stopped turning in the middle of blending a batch of hummus Its is a Kitchen Aid blender about 10 years old
Does the motor still work if you take the pitcher off of the base? If so, the rod that's in the blade assembly is probably corroded. The blades are connected to a metal rod that passes through a brass tube through to the piece that makes contact with the motor when you put the pitcher on the base. The grease wears down eventually and if you don't pulse and run the motor for a long time at once, the heat can corrode the bar and cause the blade to stop spinning. You can either disassemble the blade unit, or buy a new blade unit online. google blender parts and you can get one for $10
Dec 22, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
I need a replacement pitcher for my Bobby Flay blender but can't find one...
I actually have the pitcher, it comes w/the chigger and the blade that connects to the bottom of it.
this part is brand new, let me know if you still need one.
Jun 16, 2009 | Blenders
How to know a NEW from the old polycarbonate jug\pitcher that cracks near blades.
The "code" you are seeking is found in the serial number, which has a specific way of noting when the unit is manufactured.
Buy with confidence and hang on to your dated sales receipt. If the blender leaks, take advantage of Kitchenaid's 1 Year warranty by calling into Kitchenaid Customer Service.
Their toll-free telephone number is 1-800-541-6390.
May 24, 2009 | KitchenAid KSB560WH 5-Speed Blender
Looking for Metal blade in Black and Decker -BL12475G
If it is 2 yrs old,Just call the customer service,they will give you the parts for blender for lesser price or else go for new one.
Apr 27, 2008 | Blenders
i have the double machine and need two replacement pitchers. where can they be found?
Oct 03, 2007 | VillaWare 5787 Double Smoothee Work Top...
VillaWare V00143100 Blender Logo
90 people viewed this question
Top VillaWare Blenders Experts
Steve
Andrew Taylor
Andrew Taylor
ray gallant
Are you a VillaWare Blender Expert? Answer questions, earn points and help others
