Question about Microwave Ovens
I have a sharp above the stove microwave model R-1450 that just shut off. Is there a circuit breaker on this model?
  • Microwave Ovens Master
  • 9,098 Answers
A microwave can be dead for many reasons.
If the fuse is good, it may be an open thermal cutout / themral fuse on or near the magnetron or on top of the cavity / body of the oven.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can probably find an exploded view by entering your FULL model number here: http://www.searspartsdirect.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 12, 2008
My frigidaire microwave fan turned on by it self. Won't turn off. Blowing air above Microwave
Try unplugging it for a few seconds or turning off the circut breaker to it. This usually resets the unit.
Jan 03, 2015 | Microwave Ovens
I have a Sharp R-1450 and am trying to take it out but don't have the paperwork ou how it was mounterd. Any suggestions. In the dark in GA
Hello, I am assuming this is a microhood above the range. This link will take you to Sharp website and a viewable set of installation instructions. The model number may be different but most will install with these.
http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx
Nov 16, 2009 | Sharp R-1480 Microwave Oven
I have a Sharp Carousel II microwave oven mounted above the range. It went dead when I pushed the start switch. The circuit breaker to the unit was not tripped. I don't know where to find the model number...
Model number is on the side of the control or along he bottom of the frame. The control panel should be removable with a screw or 2 and sliding up to unlatch. the fuse is behind there. To remove it off the wall there is 2 screws coming down from the cabinet above and the unit tips towards you and lifts up off a lip on the back plate. Eric
Aug 11, 2009 | Sharp R-530BS Microwave Oven
How do I uninstall an old Sharp R-1450 Carousel over the stove microvave oven? I removed the screws from the top that it hangs on and it still won't move. Help and Thanks.
You need to remove the grill above the door to find two more screws that go straight to the back wall plate. They will be on the left and right side. That is the only other way that they mount to the wall.
Good Luck
Dec 18, 2008 | Sharp R-1480 Microwave Oven
Whirlpool over the Stove Microwave
This sounds like the unit is defective and if I were you I would return for replacment!
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
There is no power to the unit at all circuit breaker not tripped
blown fuse-easy fix -find book-it is shown behind service panel
Nov 04, 2008 | GE JVM1651 Microwave Oven
We have Sharp miocowave, over the stove carousel, model R-1480, manufatured march 1998. When we touch the start button on the microwave, about 1/2 of the times the circuit breaker breakes. After we...
A blown breaker is usually a problem with a door switch or door switch mount.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
In fact, I have uploaded the entire service manual for this to our site here.
If you find a bad switch, it's best to replace them all.
Please write back with more details if you need further help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Apr 21, 2008 | Microwave Ovens
No power
Usually they do have fuses in side as well as the one in the mains plug. With microwaves I would get an engineer rather than take it apart yourself.
Mar 11, 2008 | Microwave Ovens
Microwave Ovens Logo
57 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
