Question about Canon PowerShot A590 IS Digital Camera
A590 is card locked - Canon PowerShot A590 IS Digital Camera
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 20, 2010
How do I unluck the PowerShot A590 IS card?
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 14, 2011 | Canon PowerShot A590 IS Digital Camera
I have a canon A590 it always says the memory card is locked. Please Help we are going on vaction....
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
If that doesn't work, try another card.
BTW, if you're about to go on vacation, get a second memory card anyway. Would you drive a car without a spare tire in the trunk?
Apr 17, 2011 | Canon PowerShot A590 IS Digital Camera
I have a Canon Power Shot A590 and everytime i try to take a picture it says card locked. What do i do?
Take the memory card out of the camera. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Nov 29, 2010 | Canon PowerShot A590 IS Digital Camera
My Canon Power Shot A590s card is locked and I have absolutely no clue how to unlock it. Please help
Take out your SD card. SD cards have a small sliding switch on the side of the card. The switch moves up and down and is probably in the lock position. 5748d99.jpg
Sep 04, 2010 | Canon PowerShot A590 IS Digital Camera
My a590 says no memory card
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the switch on the side of the card, or the switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Jul 28, 2010 | Canon PowerShot A590 IS Digital Camera
Card locked
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jul 23, 2009 | Canon PowerShot A590 IS Digital Camera
Canon a590 Card (not really) Locked
Remove the SD card from the camera. Slide the tiny switch on the side of the card to its other "unlocked" position. Reinsert the card in the camera. But if you've already tried this, see this link for additional things that you can try.
Memory card error
Am assuming that you verified that the slide switch on the cards were all in the unlocked position.
If so, the A590 is still a relatively new camera. If the camera is still under a year old, then it's still under warranty. Call 1-800-OK-CANON to resolve the issue.
Jun 04, 2009 | Canon PowerShot A590 IS Digital Camera
Card locked problem on canon powershot A590
Alix
I am pretty sure when you dropped the camera the simcard reader was damaged and can no longer read your cards properly!
The camera can be fixed but it must be sent back to the manufactorer for repair! (this is a common problem when thses type of cameras are dropped or shaken!
I hope I was of help!
Jan 26, 2009 | Canon PowerShot A590 IS Digital Camera
Canon PowerShot A590 IS Digital Camera Logo
97 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
