Question about HP DeskJet F380 All-In-One Printer
Printer Problems-Hp Deskjet F380
I am having some problems with my printer. It is printing a white horizontal line across the page. All prints are coming out with weird spaces and I was wandering if the printer head could be the problem. However, I have no instructions to clean the heads. Please advise how to help rectify this problem.
  • Jus Call May 12, 2008
    Can it be a problem with the Printer Head or Ink Cartridge?
  • HP Master
  • 5,568 Answers
It isn't really 'printing' a white line but rather NOT printing at all. These are generally called 'voids' in the copier trade.
About the only thing that can cause this is the momentary loss of contact of a 'common' electrical pathway.
Removing the the cartridge, you will find a pattern of contacts, normally on the back of the cartridge.
Try using a cotton swab moistened (not dripping) with rubbing alcohol to scrub the contacts and reinstall after it is dry again. You can safely wipe any remaining moisture away with another swab.
If the loss of contact is caused by any contaminents, this is enough to remove them.
Avoid touching the nozzle area to prevent other problems.
This may not apply to you but this kind of problem can be caused by tobacco smoke which produces a sticky film often causing electrical problems in paths handling low currents.
Posted on May 12, 2008
  • Steve Allison
    Steve Allison May 12, 2008
    Not likely, BUT, the fact that the unit uses separate cartridges for black and color, makes my suggested probably useless too.
    It is possible, but not likely, that the 'common' (this is kind of like the negative for a car battery, serving as a return path for everything) for each cartridge is separate.
    I would still try the simple cleaning I suggested in case they (the cartridges) do share a return path.
    Other than my suggestion, there may be plug-in cables inside the printer that are losing contact temporarily and if the F380 is like most HP units, the case may be mostly snapped together and require the removal of few screws, but some very careful prying to avoid shattering the plastic of the housing.
Horizontal lines on page
Your printer head - the ink cartridge in case of most HP deskjet printes, in most cases is defective and you need to replace it to have a clean print.
Anyway, read this tutorial, has some good tips:
HP Deskjet D2500 Printer Series Horizontal Streaks or Lines in the Printed...
For Epson printers, read this
Epson Stylus Color Ink Jet Printer
Epson Printer Horizontal lines
Same for Cannon priters
Horizontal lines when printing with Canon ip4500 Forum Thread
Aug 23, 2015 | Office Equipment & Supplies
HP DeskJet F380 All-In-One Printer catridge problem
Try with another cartridge, If the same error, the printer head is bad.
Jul 04, 2012 | HP DeskJet F380 All-In-One Printer
Paper jamming problems with HP DeskJet F380 All-In-One Printer . The paper feeds into the paper feeder but then it seems to get off line and the paper get stuck and actually tears in the feeder. The...
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
Thanks
Newton
Aug 29, 2009 | HP DeskJet F380 All-In-One Printer
My HP Deskjet F380 Series Won't Print
If you are not using an HP factory new cartridge, then that may be your problem.
Jun 14, 2009 | HP DeskJet F380 All-In-One Printer
Lines rule across my print out paper at photocopying mode
Make sure you don't have a scratch on the glass of the scanner. If you have a mark, or scratch that matches the line ruled on your print, then there is your problem.
It;s also possible the scanner is jerking as it goes across the bed, which is causing the line. Is the line solid, dashed, bold, thin or just kinda there?
Mar 14, 2009 | HP DeskJet F380 All-In-One Printer
Deskjet F380 is normaly printing but it will print blank
If the printer is printing blank pages, make sure you are using the correct printer driver and make sure the paper size is correctly selected in the driver. If the printer is printing black only, the Ink option in the printer driver may be set to Black instead of Color or a setting in the software may be set to print black only. Also, the print head nozzles may be clogged. From the Utility section found in the printer driver, clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Performing up to 6 cleaning cycles is not uncommon if the print heads are severly clogged.
Feb 04, 2009 | HP DeskJet F380 All-In-One Printer
HP Deskjet F380 won't print
i think the inside printer have dirt or obstacles that blocken the cartridges while printing.
try to clean manually the printer by using powerful air blower,repeatedly.
Sep 14, 2008 | HP DeskJet F380 All-In-One Printer
Horizontal lines in pictures
If you are using original cartridges then there should not be a problem. The horizontal lines come from the cartridge. Can you pinpoint if it is a color or black line that is missing? My guess is that during the alignment procedure, you are asked to choose a number or letter that corresponds to picture of a the lines that show the best alignment. If you did this correctly, may I ask how many pictures you printed before seeing that line. Is it on the first print or 10th printing? Cuz if it is on the 5th or more full color picture, then the problem is that you you really have the wrong printer. The F380 capacity for printing full color pictures is miniscule. 1 ml per color. So usually after the 3rd color picture, the ink starts to run out. Let me know if this helps.
Apr 23, 2008 | HP DeskJet F380 All-In-One Printer
HP DeskJet F380 All-In-One Printer Logo
224 people viewed this question
Seeker5211
Seeker5211
