Question about Acer Aspire5100 Notebook
Laptop wont turn on, with battery one light flashes green for a second without battery and connected to the mains it does nothing.
  • 2,567 Answers
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Sep 06, 2010
Hi, the three green lights on my dell 100l flashes when ever i plug it in.when i press the switch button it stops flashing but does not come on. please help
Take the battery out, connect the power plug and see if the laptop runs without the battery connected, the main battery may need to be replaced.
Aug 28, 2010 | Dell Latitude 100L Notebook
The laptop will not start up on mains or battery power we get one flashing green light .I am unsure how to charge the battery but that seems to be ok. it has been working fine has not been dropped or...
Remove the battery, remove the ac adapter, remove any USB device.
Press and hold down Power button for 10 seconds.
Connect the ac adapter without the battery.
Turn the computer ON.
If the system still won't power ON, Reseat the Memory Modules.
If the system, STILL doesn't power ON, you need to replace the motherboard.
Jun 10, 2010 | Dell Latitude D600 Notebook
Battery light flashes 4times orange then 1green
We had the same problem. I figured out it was NOT the main battery, but the auxilary battery. The batter life WITH the auxiliary was 68% total, when I removed the 2nd battery the battery life shot back up to 98% AND the flashing orange / red lights were gone (both on the power source and off). I then replaced the auxiliary battery with a spar back up to make SURE that it was not a fluke and with the new backup battery firmly in place the lights still did not flash. Problem solved.
Jun 17, 2009 | Dell Inspiron 6000 Notebook
Dell Precision M60 won't start up
Without battery connected it wont work. Better buy a new batterry connect it and plug it for charging for 8Hrs conitnuosly without switching on the laptop.
Apr 20, 2009 | Dell Precision M60 Notebook
Dell inspiron 1100 wont stay on
Normally the battery light will rapidly flash orange if the battery is defective. It will alternate between orange and green if it is too hot to charge. Or it will either flash orange or be a steady orange if the battery is low or completely discharged. Based on this and the fact that you cannot get it to stay on for more than 7 seconds, I would have to say that you need to recharge the battery by plugging the laptop into an AC outlet. After all, it can't run without the juice.
Apr 14, 2009 | Dell Inspiron 1100 Notebook
My DS will not switch on with or without the charger connected. When i plug into the charger the orange light flashes for 1/2 a second and goes out again, but no other reaction. My ds won't switch on but...
try to charge it with another battery,if that does not solve the problem then there is a blown fuse inside the board.its besibe the battery terminal to the right.but first you have to open the unit using a triwing screwdriver and a small precision phillips screwdriver.
Dec 18, 2008 | Nintendo DS Lite Console
Powers on immediately powers off
ok well there is somwhere to start i would see if you can get it to take a charge ok and if it does than try to start it without the ac power on and see what it does if it wont take a charge your battery may be bad or your charging circuit may not be connected correctly ok lrt me know best regards mike
Aug 27, 2008 | Dell Inspiron 5160 Notebook
Boot up problem
Has the power connector at the rear been damaged at all? It sounds like there is no power getting to the laptop.
Dec 29, 2007 | Computers & Internet
Acer 5630 wont turn on
Have you performed any hardware changes recently?
Nov 27, 2007 | Acer Aspire 5630 Notebook
Open Questions:
See all Acer Aspire5100 Notebook Questions
Acer Aspire5100 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
