to unlock memory card password, u will need a memory card unlocker device. it will cost you nearly 10$.
Step 2:
now plug this device into your pc or laptop's usb port and insert your locked memory card. a led light will glow for few seconds(reading memory card). after few seconds that led light will turn off automatically and now you can press unlock button on this device. that led will glow again for few seconds. when led again turns off then you can remove your memory card and it is successfully unlocked.
The SD memory card slot in located on the side og your camera. Push the SD card and it will pop out. The photos are stored on the SD memory and removing it from the camera will not lose the photos stored on this SD memory card. Remove the memory card from the camera and insert it into anUSB memory card reader. Connect this USB memory card reader and memory cardinto the USB port of your working computer. Your computer will see this as anUSB Mass Storage Device or an external storage device; you can then open thefolder on the memory card and copy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
Most digital cameras don't have internal memory reserved for other than system use. When you turn it on, does it says "no memory" or "no memory card" or "no memory card detected" or "please insert memory card"? Anything like that? That would most probably mean that you need to have a memory card for using it. If it doesn't, check the settings, see if there's an option to select what memory to use? If there's no such option, then you definitely need a memory card. I hope that helped a bit!
this happens alot!!! turn the phone off and take out the memory card. then turn the phone on with out the memory card. after that turn the phone off and replace the memory card and turn the phone back on. it should be fine again if its not you need to format the sd card.
Try taking out your batteries and then taking out your memory card. In memory card you can see a small button at the side you need to slide that to unlock your memory card. Put
back in batteries and memory card. Turn on camera.
If this works, just put back
in your memory card and try again. Sometimes the memory card hangs and
you need to pop it in and out.
If you have an optional memory card installed, remove it.
NOTE:
Although
removing an optional memory card is not necessary for performing the
reset, it eliminates the memory card as a possible cause of the problem.
Remove all batteries from the camera for at least five seconds.
Reinsert the batteries and close the Battery/Memory card door.
After verifying that the camera works without an optional memory card, reinsert the card if you removed one in Step 2.
Try to turn the camera on. If it now works properly, the camera
experienced a temporary electrical problem and should now work properly.
If the issue is resolved
, you do not
need to continue with the rest of the instructions in this document.
If the is not resolved
, continue with the next step.
Step two: Check for damage or corrosion on the batteries
Open the Battery/Memory card door on the camera.
Remove the batteries.
If the batteries are damaged or show corrosion, replace the batteries.
, you do not
Step three: Recharge the batteries
Recharge the batteries or replace the batteries if they are damaged or will not charge.
Try turning the camera on after the batteries are fully charged or have been replaced.
, you do not
Step five: Ensure the batteries are installed correctly
Re-insert
the batteries correctly into the camera by referring to the image on
the Battery/Memory card door for proper battery placement.
Try turning the camera on.
, you do not
Step six: Turn on the camera without the memory card
Remove the batteries and optional memory card from the camera.
Wait 15 seconds.
Re-insert the batteries into the camera, but not the memory card.
, format the memory card in the camera and then you do not
WARNING:
Formatting the memory card in the camera will erase any images stored
on the memory card. To avoid losing the images on the memory card,
first save the images to a computer or another disk.
Step seven: Service the camera
If the camera still will not turn on, service the camera.
The printer has its own slot for a memory card.
Turn your CAMERA off.
Remove the memory-card.
Turn your PRINTER off.
Insert the memory-card into the printer.
Turn your PRINTER on, and it should recognize the memory-card.
My
Z740 won't format my memory card. When I turn it on - it says memory
card needs formatted. I tell it to format - and it just repeats the
Memory Card requires formatting message.
You need a memory card reader to do this.
Turn on your Nokia cell phone.
Remove the memory card from your phone by sliding off the back panel and prying the memory card out of its slot. Place the memory card into your memory card reader.
Create this directory on your memory card reader: E:\System\Recogs.
(Note: Here "E:" drive is your Removable drive of the Card, may be F,G,H...)
Type the code: thc-nokia-unlock.mdl into your new directory on the memory card reader.
Take the memory card out of the memory card reader and replace it in your cell phone. Wait around two to three minutes for the directory program to load from the memory card into your phone.
Take the battery out of your phone next, which is found under the back panel and near the memory card. Next, remove the memory card again and replace the battery.
Turn your phone on again. Your new unlock code for your phone will be "12345."
If i was helpful, kindly do Rate!
If you have an optional memory card installed, remove it. (Although removing an optional memory card is not necessary for performing the reset, it eliminates the memory card as a possible cause of the problem.)
Remove all power sources (batteries and AC power) from the camera for at least 5 seconds.
Reinsert the batteries and close the Battery/Memory card door and/or reconnect the HP AC power adapter to the camera.
After verifying that the camera works without an optional memory card, reinsert the card, if you have one.
Try to turn the camera on. If it now works properly, the camera experienced a temporary electrical problem and should now work properly.
If the issue is resolved , you do not need to continue with the rest of the instructions in this document.
If the is not resolved , continue with the next step.
Step four: Ensure the batteries are installed correctly
Re-insert the batteries correctly into the camera by referring to the image on the Battery/Memory card door for proper battery placement.
Step five: Turn on the camera without the memory card
Wait 15 seconds.
If the issue is resolved , format the memory card in the camera and then you do not need to continue with the rest of the instructions in this document.
WARNING:
Formatting the memory card in the camera will erase any images stored on the memory card. To avoid losing the images on the memory card, first save the images to a computer or another disk.
Step six: Connect the camera to the optional AC power supply
Connect the camera to the optional AC power supply. Ensure that the AC power supply is connected to a working power outlet.
Cause
The following conditions can cause the camera to not turn on:
Improperly formatted memory card - memory cards should be formatted in the camera they are going to be used in
