Question about Simba Toys Simba My Music World
My simba 23 key keyboard...how do you get it to play the self playing test songs
Yamaha YPT 400: ALL re are not working
Hi, If by "re" not working you mean note D then try the following.
Keyboard off, hold down top C key while turning on. This factory resets. Does D key now work - if not. Has it ever worked - if not then it could possibly be the ribbon connector between the keyboard and the motherboard. If one of the cables gets bent then this would stop all notes associated with that connection to stop working. This will only have occured if the keyboard has never played these notes or if it has been taken apart.
You could also try the self test mode : Keyboard off, hold C#,F, G# in the 2nd octave up whilst turning on, cycle through tests to sound if it plays all the notes one at a time then the sound chip is ok and it points to keyboard switching. If test mode does not come up in 2nd octave try 3rd octave ( cant remember which one it is from memory )
Let me know how you get on.
yamaha-ypt-400-all-re-not-working#solution-section-o0etyz1v3mt3zyequ52mc4su-5-2_0.jpg
Feb 07, 2016 | Yamaha YPT-320 Keyboard
I have a casio lk-44. I want to be able to play a song from the songbank, but just hear the background rhythm and not the melodies. I want to play the melody myself from the songbank. When I pick a song...
Not sure if your "booklet" is the full user manual... if not go to this site and go through their "hoops" and download the full user manual. It shows how to put the unit in the mode that merely lights the keys and plays the rhythm, unlike the "demo" mode.
http://www.retrevo.com/support/Casio-LK-100-Music-Keyboards-manual/id/467dj395/t/2/
Note the manual is free via the Retrevo site... just have some of those annoying hoopps like email address and entering numbers.
Mar 21, 2011 | Casio LK100 Lighted Keyboard With LCD...
Hi The first 11 keys of our keyboard have not woked since new. If my girls press the play/pause button then it works. Is this a fault of the keyboard or are we doing something wrong? Thanku
Check the switch to be sure the keyboard is in normal mode and not chord mode. This will cause there to be no sound unless you play a chord on those first 11 keys. Pressing play activates whatever song is loaded at the time, allowing full keyboard use.
I have an older Casio, and the same thing happens all the time, especially when I'm in a hurry and don't check where I put the switch.
Hope that helps!
Feb 05, 2011 | Casio Ctk 496 Electronic Keyboard with 61...
How to play minor chords on Bontempi MS40?
easy:
- the lowest key gives the chord C for C major (do majeur)
- add a key on the right (up) for exemample D or E or (it doesn't a matter) gives you the minor chord.. (here Cm = do mineur)
- add a third one ( always on the right side) gives you the 7 here C7 (do septieme)
enjoy!
what a pity we can't easily disable this auto chord function in orfer to get real notes for the left hand!!!
Jan 22, 2010 | Bontempi Toys
Midi vs. Sound
Think of MIDI like the old time player pianos where you put a roll into it and the punches on the paper roll told the piano what notes to play. MIDI is a way for computers and musical instruments to communicate what is being played. When you plug your keyboard into your computer and enable it in Cakewalk, then Cakewalk records what notes you are playing on your keyboard (makes a piano roll file). Then when you tell Cakewalk to play this file back it communicates to your keyboard and says play these notes just like a person was sitting there playing these notes. The distinction here is you are recording and playing back your performance (which keys you pressed, how hard you struck the keys, how long you held the keys for sustain, etc...). No sound is actually being recorded, just the PERFORMANCE. When you play it back, the keyboard regenerates the sounds on the fly just as if you were actually sitting there performing the music again. Same thing applies to other MIDI enabled instruments (drums, guitar, saxaphone, etc...). This opens up all kinds of possibilities, you can redirect the recorded MIDI file to a completely different sound or instrument. Example... you record MIDI of you playing piano song, then you have Cakewalk play this MIDI back to your keyboard but you change the sound on your keyboard to guitar, it will play the same song, but now you will hear guitar instead of piano. Get it?
Feb 02, 2009 | Cakewalk Music Creator 2 for PC
Ensoniq MR-61 keyboard
reset that piano by giving it 20 min with power!!
plz aret this post
Aug 21, 2008 | Computers & Internet
Songs wont change
It is stuck on "Repeat One" - refer to p.23 of your user's manual -
You can set your player to play music tracks randomly (Shuffle All ) or repeatedly (Repeat One or
Repeat All ).
1. From the main menu, select Settings > Play mode.
2. Use the VERTICAL TOUCH STRIP to scroll up or down the options.
3. Press § to select an option.
4. Press § again to deselect an option.
While you are playing music you can see the following active play mode screen.
-Tha Mp3 Doctor
Oct 30, 2007 | Philips HDD1630 MP3 Player
Playing individual songs
no you can play individual songs go to your manule and you will see how to do it i havent one my self so i can,t exsplain how to do it ?
Oct 06, 2007 | Nextar MA7151B MP3 Player
Simba Toys Simba My Music World Logo
74 people viewed this question
Top Simba Toys Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Simba Toys Toy Expert? Answer questions, earn points and help others
