Hi, how do I unjam stuck paper? I need specific instructions...I am mechanically challenged...that's putting it lightly...
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 100 Answers
If it is a laser jet printer, first remove the Catridge, and then remove the papers present in it. Pull it out slowly else it may tear and it may leave residue.
If it is a Deskjet printer, remove the paper from the pulling side, by swithing of the printer.
Posted on Sep 05, 2010
Shredder jammed and will not back up - how do I unjam it?
Carlo, unplug shredder, patiently use pick, scissors etc to remove stuck paper. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Unjam Paper Shredder
How To Fix Paper Shredder Jam Video
How To Clear Jammed Paper Shredder ABC Office
Best Way to Clear Out Jammed Shredder Ask Ozone
Jun 30, 2016 | Shredder Office Equipment & Supplies
What do I do when printer shows paper jam error without actual jam?
Hi there. Although you can't see the "paper jam" it doesn't mean that something isn't lodged in there. Often times children will drop fragments of cereal or paper clips and such into the paper feed mechanism. Other likely scenarios are the rollers haven't been cleaned in a while and have become stuck or a sliver of paper inadvertently broke off inside without your knowledge. What make/model is your printer? Canon? HP? Go to their respective website to the support/troubleshooting section for specific instructions pertaining to your model. They will most likely have you remove the paper cartridge (if you have one) as well as inspecting the internal rollers that feed the paper throught the printing process. Apparently this is a nasty one if you can't use any of the buttons. Most modern printers have cleaning cycles for the different parts of your printer that should be used on a monthly/regular basis to keep things running smooth. I'm sure you've tried powering it on/off, but also try unplugging it for about 20-30 seconds to clear out the memory and see if you can then get to the maintenance menu of your printer to run the cleaning cycles. If not, I'll be waiting for your make/model so I can get the specific instructions for your printer. Good luck!
Apr 24, 2014 | Lexmark X5450 All-In-One InkJet Printer
MY CAR WONT START AND I AM BEING TOLD I MIGHT NEED A NEW CRANK SENSOR (NOT BY A MECHANIC) IS THERE ANY OTHER POSSIBLE REASON AND ARE CRANK SENSORS EXPENSIVE?
Hi, your crank sensor is about $60 at autozone, but there could be other reasons for the car not to start. If you'd like to do some troubleshooting, please see my tip at http://www.fixya.com/cars/r5821173-doesnt_car_start_gasoline_engines . These are generic instructions. If you get stuck or need specific instructions for your car, please get back to me with your engine size.
Apr 21, 2011 | Hyundai Motor 2004 Sonata
My service engine light is on also, could this be from a blown fuse also or is it just a mechanical indicator?
Hi, the light indicates the computer has detected a fault.
Please see my tip at http://www.fixya.com/cars/r5932051-check_engine_light_check. These are generic instructions. If you get stuck or need specific instructions for your car, please get back to me with model, year and engine info.
Mar 12, 2011 | 1999 Ford Taurus
How do I unjam paper in HL 2142
You open your printer (use your manual to correctly do this)
check all paper paths to see if any paper is stuck
Next take out the toner and drum and check again for any stray scraps of paper that may have been stuck there.
Also open the paper tray and look inside there to see if anything is stuck there.
If your printer has a single sheet tray check there too
If your printer has a back opening, check there too
I recomend that you also purchase "paper path cleaning sheets" to keep the unit clean and paper jam free (once a week if you print constantly and twice a month if a casual user)
NEVER NEVER NEVER get mad and RIP out stuck paper. Such an action will break internal mechanisms inside your laser printer.
Hope this helps Have a great day
Mar 06, 2010 | Brother HL-2040 Laser Printer
HP Officejet 6310 All in One - small paper being faxed is jammed. How do I unjam the paper?
Lift the scanner lid, then lift the black part of the fax - pull up hard for it to lift. Unjam the paper either still on top or gently lift the inner section and retrieve your jammed paper. Then put everything back together and you're right to go again.
Oct 08, 2009 | HP Officejet 6310 All-In-One InkJet...
Paper jam
Hi! In you case, you have to put not thick photo paper in your printer.
Mar 20, 2009 | Kodak EASYSHARE Printer Dock Thermal Photo
47 people viewed this question
jasbo
jasbo
