Question about Agilent (HFBR-5601) Transceiver
Dow Technology Co. A Value Added Distributor in the UAE, GCC, Middle East, Africa, Europe, and South America that offers a complete line of wireless solutions from top tier manufacturers. Dear Customer Please review our Product List which we have it in our Stock GSM Repeaters For Mobile SOPO CIT-08 Model So-R01//SO-R02 Mobile Phone Repeater | Mobile Phone Signal Booster Amplifier / Repeater kit captures and boosts a weak mobile signal through a high gain antenna and amplifier and boosts coverage for areas up to 800 square meter We are the specialized telecommunication products and we provide signal repeater series, signal booster series, telecom accessories and etc. Install instruction: 1. Outdoor antenna: 2. REPEATER: Install the transmission junction which is from outdoor antenna into REPEATER socket.(TO BS). 3. Connect transmission from REPEATER port to indoor antenna. Mobile communication repeater works theorem instruction: outdoor antenna receives the mobile comrnunicatroh signal from Launch base station. The signal from outdoor antenna 'transmitted by antenna to launch after amplified by REPEATER signal amplifier. Antenna and amplifier mainframe are both work. Also; Senao + RCC 4Line + SP922 EnGeniuse + Alcon picture Product Name RCA 4-Line Corded/Cordless System PBAX SENO/SN 356 New one cordless phone long range /till 25 km Cordless Phone SP-922 Long Range Telephone System EnGeniuse till 5km -- For the SP-922 it can Support 4 Line from the PSTN Line Analogue and you can Program up to 90 Handset the range between the handset up to 1.5KM and the Communication can be done through Multiple Channel So practically all the handset can communicate with each Other in the same and it is Full Duplex and the range between the handset and the Base up to 5 ? 6KM SENAO/ Cordless Phone _358_SKYPE_Long_Range /till 25 km--- The Senao is Supporting one Analogue line and you can Program on the Base up to 90 Handset but the communication between all the handset half Duplex through one channel and that is mean one Call you can make in the same time either between two handset Or between one handset and the Base and the Communication between the handset and the Base is full Duplex SENAO/ Cordless Phone 358 Plus Long-Range / till 25 km --- The Senao is Supporting one Analogue line and you can Program on the Base up to 90 Handset but the communication between all the handset half Duplex through one channel and that is mean one Call you can make in the same time either between two handset Or between one handset and the Base and the Communication between the handset and the Base is full Duplex SENAO SN 258+New1 - Long Range Cordless phone / till 25 km SENAO SN 1258 SMART - Long Range Cordless phone / till 25 km Cordless Phone Long range, EP-801 EnGenius Extreme Range single line system 1 Line Wireless 800 MHz PBX. This is the answer to the available DECT phones without enough long reach connectivity Alcon Super Private Mobile / Fixed Telephone Line System Model Specifications Range Alcon CT45 SS Base + Remote + Omni Dir Antenna 100km to 200km Output Power: 45W Alcon CT88 SS Base + Remote + Omni Dir Antenna 50km to 100km Alcon CT-458 New Design for High Speed Data Transmission & Telephone Line System Output Power: 45W Range: 100 to 200Km Middle Range Wireless Models ALCON-7SS ( Data) Super Private Mobile / Fixed Telephone Line System Output Power: 5W Range: 20 to 40Km PBAX Phone System LOHUIS ; 1- LHVP12 Wi-Fi IP; All in One Design; -SIP Proxy Server (RFC 3261) - Analog Telephone FXO / FXS Interface - Internet Router WAN / LAN - Wireless A.P. 2- + WIFI Desktop phone LHVF 105 PHONE FEATURES LCD display +Four way directional key for menu navigation Message Waiting Indicator (MWI) light +Voicemail message retrieval button 10 Feature keys +Volume control button Standard 12 button dialling keypad +Programmable speed dials Speaker phone +Phone book +Multiple ring tones Multiple user accounts - up to 3 +Multiple lines - up to 2 3- + wifi phone model LHVF133 VoIP Protocol : SIP v2 (RFC 3261) / DTMF (RFC 2833) VoIP Codecs : G.711 (a-law, μ-law) Call Features : Send/Receive calls - Dial from contacts - Speed dial Network Features : IEEE 802.11b/g - WMM - WMM-PS - STUN Client - Voice Signaling Protocol: SIP v2 - RTP Voice Process Features : Call progress tones , DTMF tones in RTP , Voice activity , detection (silence detection level) , Comfort noise generation , Automatic gain control , Echo cancellation Phone Features : Phonebook 50 entries - Call history - WLAN signal strength level - Battery level - Caller ID - Key Lock - Contacts - Clock - MIDI / WAV ring tone - Three ring tone melodies - Key tones -Firmware upgrades via USB port Panasonics PBX Hybrid IP System; KX-TDA600 + KX-TDA 200 + KX-TDA 100 � Panasonic KX-T30810 for very small applications � Panasonic KX-T616H for small hospitality related applications � Panasonic KX-T61610 for small applications � Panasonic KX-T123210 for medium size applications � Panasonic KX-T123211 for medium size applications � Panasonic KX-T123211D for medium size applications � Panasonic KX-T336 for large applications � Panasonic KX-TA308 for very small applications � Panasonic KX-TA624 small applications � Panasonic KX-TA1232 medium size applications VOIP IP970/ IP phone portfolio of cutting-edge SIP-based telephony devices are recognized for their rugged commercial grade performance, reliability and ease of interoperability which has made snom the VoIP handset partner of choice for the industry?s leading VoIP service providers, hosted VoIP, IP PBX and Unified Communications solution vendors. Walkie Talkie Product DESCRIPTION Band ICOM IC V8 VHF ICOM IC V82 VHF ICOM IC V85 VHF ICOM 2200 STATION VHF KENWOOD TK 378 UHF KENWOOD TH K2AT VHF KENWOOD TK 2107 VHF KENWOOD TK 3107 (SMALL) UHF KENWOOD TK 3107 (BIG) UHF KENWOOD TK 3207 (SMALL) UHF KENWOOD TK 3207 (BIG) UHF KENWOOD TK 6177 VHF KENWOOD TK 6277 UHF KENWOOD TM 271 A STATION VHF MOTOROLA 5720 UHF MOTOROLA 5920 UHF MOTOROLA GP 328 VHF MOTOROLA GP 340 VHF MOTOROLA GP 98 VHF MOTOROLA MT 328 VHF MOTOROLA GP 360 VHF MOTOROLA MT 777 VHF MOTOROLA MT 777 UHF MOTOROLA GP 380 VHF MOTOROLA GM 338 VHF Zcom W/T AM-777 (UHF) UHF YAESU VX 177 UHF YAESU VX 7R VHF/UHF YAESU VX 3R VHF/UHF WEIRWEI UHF GE (SMALL) UHF YAESU FT 1802 STATION VHF YAESU FT 7800 VHF/UHF We are able to give you a Warranty for one Year. Distribution of Wireless Broadband Equipments and Voice Solutions 1. Phone Systems + PBX ? ShoreTel IP Telephony ? Commax Intercom System ? EnGenius Durafon ? Walkie Talkie (Motorola, ICOM, Kenwood) ? Senao ? Alcon ? ??????????. 2. Access Points ? Lohuis Network ? Alfa Networks ? EnGenius ? MikroTik ? Senao ? Ubiquiti ? HyperLink Wireless ? Wireless interactive communications ? VOIP Phone ????????????????????????????????. 3. Accessories o Adapters / Accessories o POE o Tools o ???????.. 4. Amplifiers 5. Antennas ? HyperLink Wireless L-com 6. Backhaul Radios o LigoWave o ????????.. 7. Bridge Kits 8. Cables 9. Camera Systems 10. Clearance 11. Client Bridges 12. Mesh Radios o LigoWave Mesh o Tranzeo Mesh o Firetide Mesh o ???????. 13. Network Management 14. WiMAX Please don't hesitate to Contact or email us with any questions or comments. We look forward to helping your business grow! Dow Technology Co LLC P.O.Box 5780 Dubai, UAE Mobile: +971507363319 Fax: +971 84 481450 E-mail: sales@dowtechnology-me.com
Hi i need schematic diagram motorola gp-98
pleas send me
thank you
Posted on Sep 09, 2010
Region code
When a DVD disc is created, it is encoded with a "Region number." The disc will only play on DVD players with the same Region number - for instance, a Region 3 disc won't play on a Region 1 player.
Region 1: U.S. and U.S. Territories, Canada
Region 2: Japan, Western Europe, Middle East, South Africa
Region 3: South Korea, Hong Kong, Taiwan, Southeast and East Asia Region 4: New Zealand, Australia, Pacific Islands, Mexico, Central/
South America
Region 5: Russia and the former Soviet Union, Africa, Indian
subcontinent, North Korea Region 6: China
There are computer programs capable of remove the region code from a DVD, but the result should be burned on a new DVD. Most players don't allow a change in the region code more than once. So on your player nothing to hack. Sorry
For all other options, please use Google.
Jul 16, 2014 | Televison & Video
Tip
Change region on DVD
As I'm sure you know, DVDs are coded to a region of the world. Here's how it breaks down:
REGION 1 -- USA, Canada
REGION 2 -- Japan, Europe, South Africa, Middle East, Greenland
REGION 3 -- S.Korea, Taiwan, Hong Kong, Parts of South East Asia
REGION 4 -- Australia, New Zealand, Latin America (including Mexico)
REGION 5 -- Eastern Europe, Russia, India, Africa
REGION 6 -- China
REGION 7 -- Reserved for Unspecified Special Use
REGION 8 -- Resevered for Cruise Ships, Airlines, etc...
REGION 0,9 or REGION ALL -- Discs are uncoded and can be played Worldwide
So here we go...
  1. Power on
  2. Open tray
  3. Push the info on remote once (with supplied remote) You will see numbers.
  4. Press 9 for multi-region. keep trying until you see the number 9 appear in upper left corner
  5. Power off
  6. Power on
on Feb 08, 2010 | Computers & Internet
Multi-region code for a bush BTVD31217S2
Seven regions (also called locales or zones) have been defined, and each one is assigned a number. Players and discs are often identified by their region number superimposed on a world globe. If a disc plays in more than one region it will have more than one number on the globe.
1: U.S., Canada, U.S. Territories
2: Japan, Europe, South Africa, and Middle East (including Egypt)
3: Southeast Asia and East Asia (including Hong Kong)
4: Australia, New Zealand, Pacific Islands, Central America, Mexico, South America, and the Caribbean
5: Eastern Europe (Former Soviet Union), Indian subcontinent, Africa, North Korea, and Mongolia
6: China
7: Reserved
8: Special international venues (airplanes, cruise ships, etc.)
Hope this helps
Apr 13, 2011 | Televison & Video
How do i change the unsupported format to play a dvd
DVD players have 5 regions. And on the back of every DVD you buy the region code is marked in side a circle ( like a globe ).
Region 1 is North America
Region 2 is Europe . Middle East & South Africa
Region 3 is South East Asia,
Region 4 is South America, Mexico, Australia
Region 5 is India , USSR, Africa.
To change the region code of your Lifestyle 38 DVD player follow the steps given below.
Make sure you familiarize yourself with the buttons on the remote and not fumble while keying in the sequence given below.
Make sure there is no disc in the tray of the player and it is closed ( tray ).
First step - Press RIGHT arrow, UP arrow, SHUFFLE, STOP, MUTE
To change to a specific region code
Step two --- Open the disc tray
Step three --Press STOP
Step four --- Press SHUFFLE
Step five ---. Press # key for desired region from the list given above.
Step six ---- Press ENTER.
Turn off the DVD player wait for a 10 seconds and restart. It should work.
Enjoy your foreign DVD's. Cheers!!.
Mar 25, 2011 | Bose Lifestyle 38 DVD Home Entertainment...
What is the names of earths continents to day
By most standards, there are a seven continents - Africa, Antarctica, Asia, Australia, Europe, North America, and South America. Most students in the United States are taught that there are seven continents.
In Europe and other parts of the world, many students are taught of six continents, where North and South America are combined to form a single continent of America. Thus, these six continents are Africa, America, Antarctica, Asia, Australia, and Europe.
Mar 21, 2011 | Computers & Internet
American Blu ray dic not playing in my malaysian sony bdp -s370
BD media does have region codes. But, unlike current DVD players, the region codes for BD media use letters instead of numbers to indicate a particular zone or region where the discs can be played.
The BD region codes are as follows:
  • Region A: North America, South America, U.S. Territories, Japan, South Korea, Taiwan, and other areas of Southeast Asia
  • Region B: Europe, Africa, Middle East, Australia, and New Zealand.
  • Region C: Asia (except for Japan, Korea, Taiwan, and other areas of Southeast Asia)
Jan 21, 2011 | Sony BDPS370 BluRay Player
What is the country code for australia - lg dvd recorder
The geographical regions are as follows:
REGION 6 -- China
REGION 8 -- Reserved for Cruise Ships, Airlines, etc...
REGION 0 or REGION ALL -- Discs are uncoded and can be played Worldwide, however, PAL discs must be played in a PAL-compatible unit and NTSC discs must be played in an NTSC-compatible unit.
The end result is that DVDs encoded for regions other than Region 1 cannot be played on a region 1 DVD player, also, players marketed for other regions cannot play region 1-stamped DVDs.
Hope this information is useful to you.
Nov 27, 2010 | LG Televison & Video
How do I change region on dvd player
REGION 6 -- China
So here we go..
  1. Power on
  2. Open tray
  5. Power off
  6. Power on
Best of luck.
Feb 08, 2010 | Televison & Video
I have just bought a Toshiba SD590EKB dvd player and it will not play certain discs, it keeps on saying wrong regional code. How can I solve this problem?
Check the back of the dvd player and it will have a small sticker with a small picture of a globe (or earth) and it will have a number being one through to six, this will determine what region discs you can play in you machine. Ill list the regions and their codes, i hope this helps.
Region 1 - The U.S., U.S. territories and Canada.
Region 2 - Europe*, Japan, Middle East, Egypt, South Africa, Greenland.
Region 3 - Taiwan, Korea, the Philippines, Indonesia, Hong Kong .
Region 4 - Mexico, South America, Central America, Australia, New Zealand, Pacific. Islands, Caribbean
Region 5 - Russia (former USSR), Eastern Europe, India, most of Africa, North Korea, Mongolia
Region 6 - China
Good luck.
Nov 25, 2009 | Televison & Video
My Sony Blu ray can't play normal DVDs in my region - Africa. How do I change the region coding just for DVDs?
It's not possible to change the region code in the Blu-ray Player.
Jun 16, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Agilent (HFBR-5601) Transceiver Logo
1,907 people viewed this question
Top Agilent Computers & Internet Experts
David Payne
David Payne
Are you an Agilent Computer and Internet Expert? Answer questions, earn points and help others
