Question about MSI Wind U100-280US Netbook
My computer keeps restarting. the battery light blinks red. bug i also get an error message about a serious problem found
  • 2,567 Answers
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
If none of this solves the problem, or is not the case, then you might have a bad motherboard.
Posted on Sep 20, 2010
The red light on my mouse keeps on blinking
Here's a guide;
What do the battery lights mean on my mouse? Some keyboard and mouse models feature a battery light that shows the current status of the batteries. The following table describes the different lights and states.
Light
Device Model Status Single long green blink Rechargeable Batteries are good. This occurs when batteries are first installed or every time that the device is turned on. Slow green blink Rechargeable Device is docked in the charging station and is charging properly. Steady green Rechargeable Device is docked in the charging station and does not need additional charging. Steady green Presenter Mouse (Japanese version) Laser pointer is on. Red/green blink Wireless Device is discoverable (trying to connect to the transceiver). Slow red blink Non-rechargeable Batteries are low and need to be replaced. Slow red blink Rechargeable Batteries are low and need recharging. Fast red blink Rechargeable Device is docked in the charging station, but there is a charging error.
Reasons for errors: The wrong type of battery is installed; the battery or batteries are missing; or the battery connection is bad.
Solutions: Make sure that the correct battery or batteries are installed, and are installed correctly. If necessary, remove the batteries, wipe them with a clean cloth, and reinsert them. Steady red Presenter Mouse (Standard version) Laser pointer is on.
Oct 18, 2014 | Computers & Internet
Two red light are blinking and show general error
Hi. My epson T50 printer is flashing together two orange lights showing general error, have reset ink pad with software but still the same problem. Any ideas would be great. Thanks Jim
Mar 13, 2012 | Epson T50 InkJet Printer
Windows explorer (windows 7) keeps on stopped working and restarting every second
Windows 7 Restarting maybe because of serious computer errors. If you see a blue screen error message for a few seconds before the computer restarts then this is likely to be the cause then it might be a hardware error.
Jun 07, 2011 | Computers & Internet
Blinking red light.Checked all cables. I replaced Hard drive...still problem exists. Wondering if power supply could be problem
When one light from the four lights ring itself changes from green to red, it means that a general hardware failure has occurred or is imminent. Blinking of one red light with an error message like E66, E67, E68, E71, E74 or E77 means a repairable problem while the one red light blinking without error message means some critical or irrepairable problem. The problem can be avoided by restarting the Xbox 360 console but if you have not received any error message with one blinking red light then the problem is irrepairable. The console will behave the same way and you should understand that one or more of the hardware components in your console have stopped functioning due to hardware failure. If you receive an error message with one red light blinking then the problem is reparable and the system will definitely start working. It means that there is some hardware problem with the Xbox 360 console connection occurring due to the misplacing of cables in the ports. Turn off your Xbox 360 and disconnect all cables, now reconnect the cables and switch on the Xbox hope this helps.
Dec 01, 2010 | Sony Playstation 3 (PS3) Console
Unable to connect to internet on broadband, keep getting error message 651, Win 7. No problem prior to loading Win 7, used to have Vista Ultimate.
This a well known bug in Windows 7 specially when you migrate from Windows Vista to Windows 7.
The cause is a file "raspppoe.sys". This file will be found on the partition you have installed your operating system If it is C: partition then it is found on C:\Windows\System32\drivers.
To fix this bug simply rename it as shown as follows
(1)Rename this file from "raspppoe.sys" to raspppoe.old or any name it any name of your choice.
(2)Once this done simply restart
Nov 11, 2010 | Microsoft Windows Vista Ultimate Edition
The HP Photosmart R707 Viewfinder video light keeps blinking in red even when the Camera is switched off.
If you actually mean the power light, that is supposed to blink when you plug it in and it is charging.
If you mean the one in the viewfinder, that is an error condition, and an error message is supposed to show up in the back image display viewer.
There may not be enough battery voltage left to display, so plug it into the AC adapter to be sure.
Aug 14, 2010 | HP Photosmart R707 Digital Camera
Have presario 6000. Would not boot but received message that new keyboard needed. Purchased "universal" aftermarket keyboard. New message "Hard drive failure imminent" and still would not boot to allow...
Prepare to Diagnose the Computer
Perform the following actions to prepare the computer for troubleshooting a startup problem.
1. Remove the battery and AC adapter from the notebook.
2.Remove any optical disks (CD or DVD), and disconnect any external devices or peripherals such as USB devices, printers, docking stations etc.
3.Plug the AC adapter directly into a functioning wall socket.
4.Press the Power button to turn on the computer.
NOTE:After the battery, optical media and peripherals are removed, the Notebook PC may startup normally. If this occurs see Windows starts after the battery, optical media and peripherals are removed .
Symptoms and Resolutions
When the notebook stops responding or displays an error message, let me know what symptom that most closely resembles what is seen on the Notebook PC screen.
* Screen is blank with no cursor or text
*An error message is displayed on a black background
*An error message is displayed on a blue background
*PC stops responding on a red Compaq or blue HP logo screen
*PC Stops responding on the Windows logo screen
* The Microsoft Windows 'Advanced Options Menu' is displayed
* PC stops responding with a blinking cursor is displayed in the upper left corner of a black screen.
*Password is requested but password is forgotten or lost.
*Microsoft Windows starts, but a 'serious error' message is displayed that prompts you to send an error report to Microsoft for evaluation.
* Microsoft Windows starts , but the PC stops responding or restarts automatically
*Display is very dim during and after startup
*Microsoft Windows starts, but runs abnormally slow
Jan 28, 2010 | HP Pavilion dv9000z Notebook
Red screen says a serious error has occurred
Well, when you have your ps 3 system on stanby with the solid red light and then hold the on/off button till you here a 2nd beep. It should go beep (when you turn it on) then about 3-5 seconds later you should here another one. Then you can take your finger off the button. This resets the display settings. Or you could try the recovery console do the same thing except you continue to hold the ps button passed the soft restart. I think thats 2 quick beeps when you come to it? Don't hold me to it for how many beeps you get but just keep holding the button and you should get to the recovery console.
Let us know if this works......
Thanks
Sep 26, 2009 | Sony Playstation 3 (PS3) Console
Red light keeps blinking and phone keeps vibrating for no reason
If you have Weather Bug its telling you that their it a weather report.
Oct 19, 2008 | Verizon Communications BlackBerry Pearl...
Minolta Dimage multi pro
Initially, I get a green flashing light when unit turned on, but after a minute or so, it turns to a red flashing light. It will take in the film tray only when blinking red, not when blinking green. My iMac has a hard time seeing the scanner, keep getting "scanner not found" messages. I have to go to system profiler and have it refresh and then it finds it, then the scanner software sees it too. But I have been unable to one preview out of it, says LED error and that's it. Using 10.4.10 on an iMac 20" with 2.5gb of RAM, using Pshop CS2 or going through Minolta Driver of OSX I got off of VersionTracker. I did remove the screw for transport right away. Will feed in 35mm tray with red blinking light, will not feed in 120 tray except partially with red blinking light, and only a couple times out of maybe ten tries.
Aug 23, 2007 | Konica Minolta Dimage Scan Multi PRO Film...
MSI Wind U100-280US Netbook Logo
152 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
