Question about Cameras
I have an Olympus E500. My problem is that the lense won't focus and despite making all the right noises no photo appears (pitch black). Tried to reset to the default setting but cursor by passes the setting mode! Help! Aubrey
    Master:
  • 788 Answers
Go to the menu, select "Custom Reset Settings" then choose "Reset". This will reset the camera to default factory settings and hopefully by-pass any settings you set to cause your current situation. See page 118 in the advanced user's guide found here: http://www.olympusamerica.com/files/EVOLT%20E-500%20Advanced%20Manual.pdf
Posted on May 12, 2008
    President:
  • 2,712 Answers
Hello Aubrey
There is 2 possibilities:
1) you have focusing on MF or S-AF+ MF- it can sometimes stop focusing
2) second possibility is that body has "forgotten" lens- mostly it happens when you change the lens when body is switched ON, so you can try- switch OFF- unscrew lens- screw lens back and switch ON.
You may also want to visit THIS link form a different forum..
If all else fails, then its best to get the camera serviced..
Hope that helps!
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
  • Swilin Sampson
    Swilin Sampson May 18, 2008
    Just checking to see if your issue is resolved. If it is, please assign
    a Fixya rating for the Expert whose advice guided you to a fix.
    Cheers!
  • Swilin Sampson
    Swilin Sampson May 23, 2008
    Is it just the screen that is black, or the picture output is black as well?
    Try taking a picture (even though you cant see anything in the screen) and transfer this to a PC and see if it shows up.
    1. If it shows up as a regular picture, then the fault is with the LCD screen.
    2. If the picture is black as well, then the issue is more likely with the CCD or main board.
    In either case, you will have to take the camera in for servicing.
    Hope that helps! Should you have any further questions,
    please post them here.
    If you are satisfied with my solution or have no further queries, please take a
    moment to "Accept" this solution.
    Thank you for using Fixya!
    Cheers!
    IrishDruid
  • 13,433 Answers
Hello Aubrey
Sorry to say there is not much we can do, you have to get it repaired
you can get a free repair estimate from
http://www.advancecamera.com/repair
If you have any questions Il gladly answer them
Olympus e420 no live view black images
are the photos on the memory card? LCD could be shot or loose.
Mar 12, 2014 | Olympus Cameras
E520 LENSES
Yes.
Feb 03, 2014 | Cameras
I cannot focus one of the lenses (14-45mm) for my Olympus E500 camera, the other lens focuses fine so the problem is not with the camera.
There is nothing you can do to fix this, the lens must be sent to an Olympus service centre for repair.
Repairs are normally done on a fixed-fee basis unless the lens is still under the manufacturer's warranty, so if you visit the Olympus website for your country you can check out the fee and determine whether you're better off buying a good used lens (still a gamble, but typically £45-£60) or a brand new one. Given that you have the kit 14-45mm you might decide that the repair costs are better invested towards the far better but far more expensive 14-54mm which is a vastly better lens in terms of optical and build quality, but most casual users won't notice any difference except for the extra weight.
Sep 01, 2010 | Olympus Cameras
Noise + lens problem
Not necesarely a lens problem. It could be, but also it could be a software or mecanical problem. You have to take the camera to a local Olympus dealer for repair. You cannot repair this on your own.
Apr 09, 2010 | Olympus FE-20 Digital Camera
Adapter
it depends what mount your vivitar lenses have - you can easily search ebay for mount adaptors that will allow you to use most older lenses on the 4/3 body, but you will only be able to use manual focus and need to work in aperature priority or fully manual mode. A generic adaptor for a OM, Nikon, Pentax or Contax mount should cost around $20. you should read up on them as there are some differences with how they are made and function, but basically are just mechanical coupling devices that fit the lense to the camera. remember, you lose all automatic features
Dec 18, 2008 | Vivitar Cameras
Olympus fe-230
lens appears to be off track and needs repair
Oct 06, 2008 | Olympus FE-230 Digital Camera
Olympus FE-220 will not let me take pictures
I am having same problem. View is black/blank, digital shutter appears to work but not photo taken. Returning camera to dealer as this appears to be an Olympus manufacturer error.
Jun 13, 2008 | Olympus FE-220 Digital Camera
Black line on photographs
check whether your lenses (on both sides) and the cameras sensor are clean...
Aug 23, 2007 | Olympus EVOLT E-410 Digital Camera
Epson 3000Z in "sports" mode
With the telephote lens, I am assuming that the camera is a bit more sensitive to any form of camera shake. My suggestion, when using the telephoto lens, is to manually set the shutter speed to its fastest setting (that, or set it to "sports mode"). Also, experiment with the telephote lens using your tripod. Set the camera up on a table and use the timer so that the camera will snap the image automatically. See if the picture is still blurry. If you don't have a tripod, just place it flat on the table.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Cameras Logo
51 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
