Question about Whirlpool Refrigerators
I have mislaid my fridge/freezer manual. The led unit is giving me a flashing message "F01%" which I can not check without the manual. Could you please forward a copy, in either soft or hard copy. The model I have is an American style two door side by side one. It is either a 20 or 25 RI 4D model. Thanks, Diarmuid P.Maguire, Athlunkard, Corbally, Limerick.
dididsaythat
  • 291 Answers
SOURCE: SAMSUNG AMERICAN STYLE FRIDGE FREEZER MODEL RS21DCNS
Sounds like u need to replace fan motor
Check fan motor for continity IF none replace fan motor
Posted on Oct 12, 2007
  • 833 Answers
SOURCE: Freezer defrost LG american style
Defrost the unit for two days with the doors open...I know you're going to lose your contents. You may have ice on the coils internally. Next make sure you've cleaned the external coils under the unit. Leaving liquids open inside the unit or setting it colder than required will both cause issues like the ones you've got. Also, be sure all air vents inside the unit are unblocked and the door closes tightly all around.
Posted on Mar 09, 2008
SOURCE: SAMSUNG RS20CCMS AMERICAN STYLE FRIDGE FREEZER
my freezer has defrosted itself and my fridge is not working, have turned it off and back on but no luck, will not get cold at all is only 3 years old!!
Posted on May 30, 2008
  • 833 Answers
SOURCE: No light in fridge compartment, Not freezing. Light in freezer co
Your door switch is bad.  When doors are opened, the fan stops.  No cooling.  When it closes, fan starts.  Bulb is just an indicator of no power to unit...probably burned out contact in switch.
Posted on Nov 12, 2008
in the freezer section there is a 6 screws. unscrew them and remove the back panel. there will be 2 wires attached to the panels, remember where they go. you will see a metal evaporator which will be filled with ice. this is the problem. use a hairdryer to melt the ice. this is essential as you mustn't puncture the wall of the fridge with any sharp item. before replacing the panel ensure that everything is dry or ice will reform, and also ensure that the fan blades are turning properly or cold air will not be blown into the fridge.
Posted on Dec 10, 2008
Model zx97/5si fridge freezer. Why are the interior light and compressor not working?
My question is whether these three LEDs steady light or flashing during normal mode?
25836454-ucy4wx0s13wzivwce2sy2wdr-4-0.jpg If all three LEDs flash, that means NTC sensors failure!
NTC evaporator sensor is placed on back side of battery evaporator and NTC ambient sensor is placed on front side of batery evaporator.
Battery evaporator is placed in freezer compartment.
Dado
Aug 25, 2015 | Zanussi Refrigerators
How to stop the flashing (strobing) lights inside both the fridge and freezer?
I had the same problem but instead of throwing a couple hundred dollars away I decided to let my lights stay on all the time inside the fridge. All I did was pop the filter switch out so it wouldn't trigger when the door was closed. No more flickering and the hole doesn't irritate me like the rave party inside my fridge did????
Apr 01, 2015 | Whirlpool WRS325FDAM 25.4 cu. ft. Side by...
My whirlpool sixth sense fridge freezer is reading F01% (fridge side) the motor seems to be overworking(making noise) but doesn't;t do so when fridge door is open. The freezer seems to be fine and...
the motor is suppose to stop when the door opens and turns on when closing the noise could be ice building up and the fun blade rubbing the ice if unit is empty you should leave the unit disconnected so ice melts and noise will go away when reconnecting if no motor replacement is needed.
Dec 26, 2014 | Whirlpool Refrigerators
Fridge not cooling
Sometimes the air duct bewteen the fridge and freezer becomes blocked with snowy ice what forms when the freezer has been running without an operative fan - solution switch the unit off with the doors open for 24hrs then clean close it up and switch it on - if it was snow problem will be gone - cheap and easy to give it a try
Feb 21, 2014 | Electrolux Refrigerators
Fridge temperature shown is +14. Unsure how to set temp to say +6
Usually the model number and info is on a sticker on the back of the fridge , you will more than sertainly have to move your fridge to find this info.
Feb 08, 2013 | Refrigerators
Both Lights flashing and fridge not getting cold
I turned the fridge and freezer off using the circular dials, I then turned the unit off at the mains. Left it for a few minutes and then turned the power back on. I then turned the circular dials to "max" and then depressed the super cool and super freeze buttons to turn this facility on. This time they came on normally (not flashing) and no alarm sounded. The fridge and freezer then started to get cold. Once the unit had been running for several hours I then turned the dials to the 3/4 mark and depressed the super cool and super freeze buttons again to turn them off. Over night the fridge and the freezer appear to be working properly so I hope that my problem is solved. Maybe the unit just needed to "settle" before being switched on?
Sep 03, 2009 | Freezers
Weve lost the instruction manual for our Hotpoint Fridge-Freezer
Sorry, no secret. The fan wasnt working so we called an engineer who bypassed a sensor. Now it works perfectly again.
Mar 22, 2009 | Bosch Freezers
Fridge freezer
fully defrost it 48 hrs with the doors open and that can often cure it.
Feb 11, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Hotpoint wd420 problems
we had this problem had to clean out the "self cleaning filter" this solved it for us
Dec 15, 2007 | Washing Machines
Refrigerators Logo
16 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
